Whether KW45 's VDD_RF PIN can be float if no use RF
nicosuki
we just want to use kw45 as a simple mcu only ,don't need RF function . Which components  can be deleted and Whether the VDD_RF pin can be Float? It would be nice to have a block diagram about how to config kw45 as a without RF.
Christine_Li
Hi, @nicosuki
I checked our KW45's datasheet, it mentioned that:
VDD_RF Supply voltage for OSC and radio analog
So it means, VDD_RF not only supply voltage for Radio analog, but also for OSC.
I do not recommend to float it even no use RF.
Christine.
Christine_Li
Hi, @nicosuki
Will you use our KW45 to do COB designs? Or you will use our KW45-EVK in your project?
Christine.
