BeyondStudio for NXP installation problem again
5,500 次查看
ffonck96
I had installed BeyondStudio for NXP a week ago. I was following BeyondStudio for NXP installation guide and when i reached section 1.2.3 i wasn't able to install the two mandatory plugins. The output says: "The operation cannot be completed" followed by:
Cannot complete the install because one or more required items could not be found.
  Software being installed: NXP ZBPro Configuration Editor 2.0.0 (com.jennic.sdk.zbpro.external.feature.feature.group 2.0.0)
  Missing requirement: ZBPro Config Edit Support 2.0.0 (com.jennic.zps.configeditor.edit 2.0.0) requires 'bundle org.eclipse.emf.edit 0.0.0' but it could not be found
  Cannot satisfy dependency:
    From: NXP ZBPro Configuration Editor 2.0.0 (com.jennic.sdk.zbpro.external.feature.feature.group 2.0.0)
    To: com.jennic.zps.configeditor.edit [2.0.0]
Then i tried uninstalling BeyondStudio as @mario_castaneda suggests on this forum post but nothing changed.
What gives?
5,487 次查看
EduardoZamora
Hello @ffonck96
Hope you are doing well.
Please, take a look at the document that is attached to this post, there you can find the steps that I followed to replicate this behavior and how to try to solve it.
Eduardo.
5 回复数
5,476 次查看
ffonck96
Thanks for the reply @EduardoZamora , it worked!.
Although, part of my issue is solved I'm still wondering if Jennic RTOS Configuration Editor is available for install.
Thanks for the file it was useful, regards!
5,474 次查看
EduardoZamora
It seems that the Eclipse cloud has changed the structure of multiple dependencies packages in their repository, making older plugin versions no longer available for Beyond Studio IDE.
I apologize for any inconveniences this might cause you.
Eduardo.
5,488 次查看
EduardoZamora
Hello @ffonck96
Eduardo.
3,157 次查看
dfrank
Hi Eduardo,
I encounter the same problem, while I can not find any attachment in this post. Could you pls post it again? Thank you very much.
4,558 次查看
villasmart
where is document that is attached to this post?
%3CLINGO-SUB%20id%3D%22lingo-sub-1754457%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EBeyondStudio%20for%20NXP%20%E5%AE%89%E8%A3%85%E9%97%AE%E9%A2%98%E5%86%8D%E6%AC%A1%E5%87%BA%E7%8E%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1754457%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%B8%80%E5%91%A8%E5%89%8D%EF%BC%8C%E6%88%91%E5%AE%89%E8%A3%85%E4%BA%86%20BeyondStudio%20for%20NXP%E3%80%82%E6%88%91%E6%8C%89%E7%85%A7%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FJN-UG-3098.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EBeyondStudio%20for%20NXP%20%E5%AE%89%E8%A3%85%E6%8C%87%E5%8D%97%E8%BF%9B%E8%A1%8C%E5%AE%89%E8%A3%85%3C%2FA%3E%EF%BC%8C%E4%BD%86%E5%9C%A8%E5%AE%89%E8%A3%85%E5%88%B0%E7%AC%AC%201.2.3%20%E8%8A%82%E6%97%B6%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%AE%89%E8%A3%85%E4%B8%A4%E4%B8%AA%E5%BF%85%E8%A3%85%E6%8F%92%E4%BB%B6%E3%80%82%E8%BE%93%E5%87%BA%E7%BB%93%E6%9E%9C%E6%98%BE%E7%A4%BA%22%E6%93%8D%E4%BD%9C%E6%97%A0%E6%B3%95%E5%AE%8C%E6%88%90%22%20%EF%BC%8C%E7%84%B6%E5%90%8E%E6%98%AF%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3ECannot%20complete%20the%20install%20because%20one%20or%20more%20required%20items%20could%20not%20be%20found.%0A%20%20Software%20being%20installed%3A%20NXP%20ZBPro%20Configuration%20Editor%202.0.0%20(com.jennic.sdk.zbpro.external.feature.feature.group%202.0.0)%0A%20%20Missing%20requirement%3A%20ZBPro%20Config%20Edit%20Support%202.0.0%20(com.jennic.zps.configeditor.edit%202.0.0)%20requires%20'bundle%20org.eclipse.emf.edit%200.0.0'%20but%20it%20could%20not%20be%20found%0A%20%20Cannot%20satisfy%20dependency%3A%0A%20%20%20%20From%3A%20NXP%20ZBPro%20Configuration%20Editor%202.0.0%20(com.jennic.sdk.zbpro.external.feature.feature.group%202.0.0)%0A%20%20%20%20To%3A%20com.jennic.zps.configeditor.edit%20%5B2.0.0%5D%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E7%84%B6%E5%90%8E%EF%BC%8C%E6%88%91%E6%8C%89%E7%85%A7%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F86938%22%20target%3D%22_blank%22%3E%40mario_castaneda%3C%2FA%3E%E5%9C%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FWireless-Connectivity%2FBeyondStudio-for-NXP-installation-problem%2Ftd-p%2F1055106%22%20target%3D%22_self%22%3E%E8%AE%BA%E5%9D%9B%E5%B8%96%E5%AD%90%3C%2FA%3E%E4%B8%AD%E7%9A%84%E5%BB%BA%E8%AE%AE%EF%BC%8C%E5%B0%9D%E8%AF%95%E5%8D%B8%E8%BD%BD%20BeyondStudio%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%8F%98%E5%8C%96%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%80%8E%E4%B9%88%E4%BA%86%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2147907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20BeyondStudio%20for%20NXP%20installation%20problem%20again%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2147907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%97%A8%EF%BC%8C%E7%88%B1%E5%BE%B7%E5%8D%8E%E5%A4%9A%EF%BC%8C%3CBR%20%2F%3E%EF%BC%8C%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E6%88%91%E5%9C%A8%E8%BF%99%E4%B8%AA%E5%B8%96%E5%AD%90%E9%87%8C%E6%89%BE%E4%B8%8D%E5%88%B0%E4%BB%BB%E4%BD%95%E9%99%84%E4%BB%B6%E3%80%82%E6%82%A8%E8%83%BD%E5%86%8D%E5%8F%91%E4%B8%80%E6%AC%A1%E5%90%97%EF%BC%9F%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1977541%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20BeyondStudio%20for%20NXP%20installation%20problem%20again%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1977541%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%9C%AC%E5%B8%96%E6%89%80%E9%99%84%E6%96%87%E4%BB%B6%E5%9C%A8%E5%93%AA%E9%87%8C%EF%BC%9F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1755048%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20BeyondStudio%20for%20NXP%20installation%20problem%20again%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1755048%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E7%9C%8B%E6%9D%A5Eclipse%E4%BA%91%E5%B7%B2%E7%BB%8F%E6%94%B9%E5%8F%98%E4%BA%86%E5%85%B6%E5%AD%98%E5%82%A8%E5%BA%93%E4%B8%AD%E5%A4%9A%E4%B8%AA%E4%BE%9D%E8%B5%96%E4%BB%A3%E7%A0%81%E5%8C%85%E7%9A%84%E7%BB%93%E6%9E%84%EF%BC%8C%E4%BD%BF%E6%97%A7%E7%9A%84%E6%8F%92%E4%BB%B6%E7%89%88%E6%9C%AC%E4%B8%8D%E5%86%8D%E9%80%82%E7%94%A8%E4%BA%8EBeyond%20Studio%20IDE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%E7%BB%99%E6%82%A8%E5%B8%A6%E6%9D%A5%E4%B8%8D%E4%BE%BF%EF%BC%8C%E6%88%91%E6%B7%B1%E8%A1%A8%E6%AD%89%E6%84%8F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CBR%20%2F%3EEduardo%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1755043%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20BeyondStudio%20for%20NXP%20installation%20problem%20again%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1755043%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F200888%22%20target%3D%22_blank%22%3E%40EduardoZamora%3C%2FA%3E%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%8C%E5%AE%83%E8%B5%B7%E4%BD%9C%E7%94%A8%E4%BA%86%EF%BC%81%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%99%BD%E7%84%B6%E6%88%91%E7%9A%84%E9%83%A8%E5%88%86%E9%97%AE%E9%A2%98%E5%B7%B2%E7%BB%8F%E8%A7%A3%E5%86%B3%EF%BC%8C%E4%BD%86%E6%88%91%E4%BB%8D%E7%84%B6%E6%83%B3%E7%9F%A5%E9%81%93%20Jennic%20RTOS%20%E9%85%8D%E7%BD%AE%E7%BC%96%E8%BE%91%E5%99%A8%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E5%AE%89%E8%A3%85%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%8C%E5%AE%83%E5%BE%88%E6%9C%89%E7%94%A8%EF%BC%8C%E9%97%AE%E5%A5%BD%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1754478%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20BeyondStudio%20for%20NXP%20installation%20problem%20again%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1754478%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F225495%22%20target%3D%22_blank%22%3E%40ffonck96%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E4%BD%A0%E4%B8%80%E5%88%87%E9%A1%BA%E5%88%A9%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E6%9F%A5%E7%9C%8B%E6%9C%AC%E5%B8%96%E6%89%80%E9%99%84%E7%9A%84%E6%96%87%E6%A1%A3%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%85%B6%E4%B8%AD%E6%89%BE%E5%88%B0%3CSPAN%3E%E6%88%91%E5%A4%8D%E5%88%B6%E8%BF%99%E7%A7%8D%E8%A1%8C%E4%B8%BA%E7%9A%84%E6%AD%A5%E9%AA%A4%E4%BB%A5%E5%8F%8A%E5%A6%82%E4%BD%95%E5%B0%9D%E8%AF%95%E8%A7%A3%E5%86%B3%E5%AE%83%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CBR%20%2F%3EEduardo%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
