[RW612] How to analyze Stability Issue
1,339件の閲覧回数
AlexLiang
Background:
I'm using the RW612 EVK(with freeRTOS) to do pre-evaluation.
And is trying to make the wifi-bt coex work well. During this process, I encountered some stability issue but has no knowledge how to debug further.
I have searched the NXP docs for RW612 platform, but didnot find some documents/trainings guide me how to do stability issue analyzing.
Could you help to share any infos about how to do stability issue analyzing with rw612 platform ?
BTW, I'm using the SDK 1.2.3 SDK_25_06_00_FRDM-RW612
Thanks a lot!
タグ(3)
1,311件の閲覧回数
Ricardo_Zamora
Hope you are doing well. Are you using any of the coexistence examples from the SDK?
I would recommend checking this Application Note: Coexistence Overview for RW61x
Also, you could check section 8 of this User Manual: NXP Wi-Fi and Bluetooth Demo Applications for RW61x
Hope this helps!
Ricardo
3 返答(返信)
1,305件の閲覧回数
AlexLiang
Hi Ricardo,
Thanks a lot for you infos! And yes, I did checked these 2 docs previously for wifi & bt coex cases.
And further background is, while developping basing SDK_25_06_00_FRDM-RW612, there is a stability issue that EVK board will run into crash, log print like below,
call_socket_task_init
Creating new socket.
socket_task_init socket thread created
do while
tcp_connect_thread wifi tcp Connecting...
tcp_connect_thread wifi tcp Connecting... IPv4
[2025-08-26 21:43:05.933]# RECV ASCII>
do while
[2025-08-26 21:43:06.922]# RECV ASCII>
do while
[2025-08-26 21:43:07.922]# RECV ASCII>
do while
[2025-08-26 21:43:08.930]# RECV ASCII>
do while
[2025-08-26 21:43:09.931]# RECV ASCII>
do while
[2025-08-26 21:43:10.261]# RECV ASCII>
AS
And the last "AS" print, I guess should be assert, but I did not get a method from the SDK / User Manual docs can help to do further root causing this issue.
So could you help to share some guide help me to find a easy way to debug this stability issue?
Alex
1,281件の閲覧回数
Ricardo_Zamora
Hi Alex,
Could you please specify what SDK example are you using as a base?
Did you modify something on the example? How are you testing this "stability issue"?
I would recommend checking this Application Note: NXP Wi-Fi and Bluetooth Debug Feature Configuration for RW61x Evaluation Board
Ricardo
1,312件の閲覧回数
Ricardo_Zamora
Hope this helps!
Ricardo
%3CLINGO-SUB%20id%3D%22lingo-sub-2158410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5BRW612%5D%20%E5%AE%89%E5%AE%9A%E6%80%A7%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%88%86%E6%9E%90%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%90%E3%83%83%E3%82%AF%E3%82%B0%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%3A%3C%2FP%3E%3CP%3E%E4%BA%8B%E5%89%8D%E8%A9%95%E4%BE%A1%E3%81%AB%E3%81%AF%20RW612%20EVK%20(freeRTOS%20%E4%BB%98%E3%81%8D)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81Wi-Fi-BT%20COEX%20%E3%81%8C%E3%81%86%E3%81%BE%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%8A%AA%E3%82%81%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E4%B8%AD%E3%81%AB%E3%80%81%E5%AE%89%E5%AE%9A%E6%80%A7%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%95%E3%82%89%E3%81%AB%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ERW612%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AE%20NXP%20%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%AE%89%E5%AE%9A%E6%80%A7%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E5%88%86%E6%9E%90%E6%96%B9%E6%B3%95%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%99%E3%82%8B%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%84%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Erw612%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%E5%AE%89%E5%AE%9A%E6%80%A7%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%88%86%E6%9E%90%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E6%83%85%E5%A0%B1%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%A1%E3%81%AA%E3%81%BF%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AFSDK%20%3CSTRONG%3E1.2.3%20SDK_25_06_00_FRDM-RW612%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2159368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BRW612%5D%20How%20to%20analyze%20Stability%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2159368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%A2%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%83%99%E3%83%BC%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%20SDK%20%E3%81%AE%E4%BE%8B%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E4%BE%8B%E3%81%AB%E4%BD%95%E3%81%8B%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E3%81%93%E3%81%AE%E3%80%8C%E5%AE%89%E5%AE%9A%E6%80%A7%E3%81%AE%E5%95%8F%E9%A1%8C%E3%80%8D%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-manual%2FUM11797.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ERW61x%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AENXP%20Wi-Fi%E3%81%8A%E3%82%88%E3%81%B3Bluetooth%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%A9%9F%E8%83%BD%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%AA%E3%82%AB%E3%83%AB%E3%83%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BRW612%5D%20How%20to%20analyze%20Stability%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%AA%E3%82%AB%E3%83%AB%E3%83%89%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%83%85%E5%A0%B1%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%81%E3%81%AF%E3%81%84%E3%80%81%E4%BB%A5%E5%89%8D%E3%80%81Wi-Fi%20%E3%81%A8%20BT%20%E3%81%AE%20COEX%20%E3%81%AE%20CASE%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%202%20%E3%81%A4%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%20%3CSTRONG%3ESDK_25_06_00_FRDM-RW612%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E9%96%8B%E7%99%BA%E4%B8%AD%E3%81%AB%E3%80%81%3C%2FSTRONG%3E%20EVK%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%AD%E3%82%B0%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E5%AE%89%E5%AE%9A%E6%80%A7%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%82%BF%E3%82%B9%E3%82%AF%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%82%BF%E3%82%B9%E3%82%AF%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Esocket_task_init%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%81%97%E3%81%AA%E3%81%8C%E3%82%89%E8%A1%8C%E3%81%86%3CBR%20%2F%3Etcp_connect_thread%20wifi%20tcp%20%E6%8E%A5%E7%B6%9A%E4%B8%AD...%3CBR%20%2F%3E%20tcp_connect_thread%20wifi%20tcp%20%E6%8E%A5%E7%B6%9A%E4%B8%AD...%20IPv4%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%5B2025-08-26%2021%3A43%3A05.933%5D%23ASCII%20%E3%82%92%E5%8F%97%E4%BF%A1%26gt%3B%3CBR%20%2F%3E%E3%81%97%E3%81%AA%E3%81%8C%E3%82%89%E8%A1%8C%E3%81%86%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%5B2025-08-26%2021%3A43%3A06.922%5D%23ASCII%20%E3%82%92%E5%8F%97%E4%BF%A1%26gt%3B%3CBR%20%2F%3E%E3%81%97%E3%81%AA%E3%81%8C%E3%82%89%E8%A1%8C%E3%81%86%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%5B2025-08-26%2021%3A43%3A07.922%5D%23ASCII%20%E3%82%92%E5%8F%97%E4%BF%A1%26gt%3B%3CBR%20%2F%3E%E3%81%97%E3%81%AA%E3%81%8C%E3%82%89%E8%A1%8C%E3%81%86%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%5B2025-08-26%2021%3A43%3A08.930%5D%23ASCII%20%E3%82%92%E5%8F%97%E4%BF%A1%26gt%3B%3CBR%20%2F%3E%E3%81%97%E3%81%AA%E3%81%8C%E3%82%89%E8%A1%8C%E3%81%86%3C%2FP%3E%3CP%3E%5B2025-08-26%2021%3A43%3A09.931%5D%23ASCII%20%E3%82%92%E5%8F%97%E4%BF%A1%26gt%3B%3CBR%20%2F%3E%E3%81%97%E3%81%AA%E3%81%8C%E3%82%89%E8%A1%8C%E3%81%86%3C%2FP%3E%3CP%3E%5B2025-08-26%2021%3A43%3A10.261%5D%23ASCII%20%E3%82%92%E5%8F%97%E4%BF%A1%26gt%3B%3CBR%20%2F%3E%3CSTRONG%3E%E3%81%A8%E3%81%97%E3%81%A6%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E6%9C%80%E5%BE%8C%E3%81%AE%E3%80%8CAS%E3%80%8D%E3%83%97%E3%83%AA%E3%83%B3%E3%83%88%E3%81%AF%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%88%E3%81%A7%E3%81%82%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81SDKs%20%2F%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%20%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8B%E3%82%89%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%82%92%E3%81%95%E3%82%89%E3%81%AB%E7%AA%81%E3%81%8D%E6%AD%A2%E3%82%81%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A4%E6%96%B9%E6%B3%95%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ESO%E3%80%81%E3%81%93%E3%81%AE%E5%AE%89%E5%AE%9A%E6%80%A7%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E7%B0%A1%E5%8D%98%E3%81%AA%E6%96%B9%E6%B3%95%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%A2%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BRW612%5D%20How%20to%20analyze%20Stability%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%AA%BF%E5%AD%90%E3%81%8C%E8%89%AF%E3%81%84%E3%81%A8%E3%81%84%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%82SDK%20%E3%81%AE%E5%85%B1%E5%AD%98%E4%BE%8B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14121.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%80%8CRW61x%E3%81%AE%E5%85%B1%E5%AD%98%E3%81%AE%E6%A6%82%E8%A6%81%E3%80%8D%3C%2FA%3E%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%81%93%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B38%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-manual%2FUM11799.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%80%8CRW61x%E7%94%A8NXP%20Wi-Fi%E3%81%8A%E3%82%88%E3%81%B3Bluetooth%E3%83%87%E3%83%A2%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%8D%E3%82%82%3C%2FA%3E%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A4%E3%81%93%E3%81%A8%E3%82%92%E7%A5%88%E3%82%8A%E3%81%BE%E3%81%99!%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%AA%E3%82%AB%E3%83%AB%E3%83%89%3C%2FP%3E%3C%2FLINGO-BODY%3E
