[RW612] How to analyze Stability Issue
AlexLiang
Background:
I'm using the RW612 EVK(with freeRTOS) to do pre-evaluation.
And is trying to make the wifi-bt coex work well. During this process, I encountered some stability issue but has no knowledge how to debug further.
I have searched the NXP docs for RW612 platform, but didnot find some documents/trainings guide me how to do stability issue analyzing.
Could you help to share any infos about how to do stability issue analyzing with rw612 platform ?
BTW, I'm using the SDK 1.2.3 SDK_25_06_00_FRDM-RW612
Thanks a lot!
Tags (3)
Ricardo_Zamora
Hope you are doing well. Are you using any of the coexistence examples from the SDK?
I would recommend checking this Application Note: Coexistence Overview for RW61x
Also, you could check section 8 of this User Manual: NXP Wi-Fi and Bluetooth Demo Applications for RW61x
Hope this helps!
Ricardo
AlexLiang
Hi Ricardo,
Thanks a lot for you infos! And yes, I did checked these 2 docs previously for wifi & bt coex cases.
And further background is, while developping basing SDK_25_06_00_FRDM-RW612, there is a stability issue that EVK board will run into crash, log print like below,
call_socket_task_init
Creating new socket.
socket_task_init socket thread created
do while
tcp_connect_thread wifi tcp Connecting...
tcp_connect_thread wifi tcp Connecting... IPv4
[2025-08-26 21:43:05.933]# RECV ASCII>
do while
[2025-08-26 21:43:06.922]# RECV ASCII>
do while
[2025-08-26 21:43:07.922]# RECV ASCII>
do while
[2025-08-26 21:43:08.930]# RECV ASCII>
do while
[2025-08-26 21:43:09.931]# RECV ASCII>
do while
[2025-08-26 21:43:10.261]# RECV ASCII>
AS
And the last "AS" print, I guess should be assert, but I did not get a method from the SDK / User Manual docs can help to do further root causing this issue.
So could you help to share some guide help me to find a easy way to debug this stability issue?
Alex
Ricardo_Zamora
Hi Alex,
Could you please specify what SDK example are you using as a base?
Did you modify something on the example? How are you testing this "stability issue"?
I would recommend checking this Application Note: NXP Wi-Fi and Bluetooth Debug Feature Configuration for RW61x Evaluation Board
Ricardo
Ricardo_Zamora
Hope this helps!
Ricardo
%3CLINGO-SUB%20id%3D%22lingo-sub-2158410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5BRW612%5D%20How%20to%20analyze%20Stability%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EBackground%3A%3C%2FP%3E%3CP%3EI'm%20using%20the%20RW612%20EVK(with%20freeRTOS)%20to%20do%20pre-evaluation.%3C%2FP%3E%3CP%3EAnd%20is%20trying%20to%20make%20the%20wifi-bt%20coex%20work%20well.%20During%20this%20process%2C%20I%20encountered%20some%20stability%20issue%20but%20has%20no%20knowledge%20how%20to%20debug%20further.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20have%20searched%20the%20NXP%20docs%20for%20RW612%20platform%2C%20but%20didnot%20find%20some%20documents%2Ftrainings%20guide%20me%20how%20to%20do%20stability%20issue%20analyzing.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ECould%20you%20help%20to%20share%20any%20infos%20about%20how%20to%20do%20stability%20issue%20analyzing%20with%20rw612%20platform%20%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBTW%2C%20I'm%20using%20the%20SDK%3CSTRONG%3E%26nbsp%3B1.2.3%20SDK_25_06_00_FRDM-RW612%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%20a%20lot!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2159368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BRW612%5D%20How%20to%20analyze%20Stability%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2159368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Alex%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ECould%20you%20please%20specify%20what%20SDK%20example%20are%20you%20using%20as%20a%20base%3F%3C%2FP%3E%0A%3CP%3EDid%20you%20modify%20something%20on%20the%20example%3F%20How%20are%20you%20testing%20this%20%22stability%20issue%22%3F%3C%2FP%3E%0A%3CP%3EI%20would%20recommend%20checking%20this%20Application%20Note%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-manual%2FUM11797.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ENXP%20Wi-Fi%20and%20Bluetooth%20Debug%20Feature%20Configuration%20for%20RW61x%20Evaluation%20Board%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ERicardo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BRW612%5D%20How%20to%20analyze%20Stability%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Ricardo%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%20a%20lot%20for%20you%20infos!%20And%20yes%2C%20I%20did%20checked%20these%202%20docs%20previously%20for%20wifi%20%26amp%3B%20bt%20coex%20cases.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EAnd%20further%20background%20is%2C%20while%20developping%20basing%20%3CSTRONG%3ESDK_25_06_00_FRDM-RW612%2C%20%3C%2FSTRONG%3Ethere%20is%20a%20stability%20issue%20that%20EVK%20board%20will%20run%20into%20crash%2C%20log%20print%20like%20below%2C%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Ecall_socket_task_init%3CBR%20%2F%3Ecall_socket_task_init%3CBR%20%2F%3ECreating%20new%20socket.%3CBR%20%2F%3Esocket_task_init%20socket%20thread%20created%3CBR%20%2F%3Edo%20while%3CBR%20%2F%3Etcp_connect_thread%20wifi%20tcp%20Connecting...%3CBR%20%2F%3Etcp_connect_thread%20wifi%20tcp%20Connecting...%20IPv4%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%5B2025-08-26%2021%3A43%3A05.933%5D%23%20RECV%20ASCII%26gt%3B%3CBR%20%2F%3Edo%20while%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%5B2025-08-26%2021%3A43%3A06.922%5D%23%20RECV%20ASCII%26gt%3B%3CBR%20%2F%3Edo%20while%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%5B2025-08-26%2021%3A43%3A07.922%5D%23%20RECV%20ASCII%26gt%3B%3CBR%20%2F%3Edo%20while%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%5B2025-08-26%2021%3A43%3A08.930%5D%23%20RECV%20ASCII%26gt%3B%3CBR%20%2F%3Edo%20while%3C%2FP%3E%3CP%3E%5B2025-08-26%2021%3A43%3A09.931%5D%23%20RECV%20ASCII%26gt%3B%3CBR%20%2F%3Edo%20while%3C%2FP%3E%3CP%3E%5B2025-08-26%2021%3A43%3A10.261%5D%23%20RECV%20ASCII%26gt%3B%3CBR%20%2F%3E%3CSTRONG%3EAS%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3EAnd%20the%20last%20%22AS%22%20print%2C%20I%20guess%20should%20be%20assert%2C%20but%20I%20did%20not%20get%20a%20method%20from%20the%20SDK%20%2F%20User%20Manual%20docs%20can%20help%20to%20do%20further%20root%20causing%20this%20issue.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ESo%20could%20you%20help%20to%20share%20some%20guide%20help%20me%20to%20find%20a%20easy%20way%20to%20debug%20this%20stability%20issue%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EBest%20Regards%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EAlex%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BRW612%5D%20How%20to%20analyze%20Stability%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHope%20you%20are%20doing%20well.%20Are%20you%20using%20any%20of%20the%20coexistence%20examples%20from%20the%20SDK%3F%3C%2FP%3E%0A%3CP%3EI%20would%20recommend%20checking%20this%20Application%20Note%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14121.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ECoexistence%20Overview%20for%20RW61x%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EAlso%2C%20you%20could%20check%20section%208%20of%20this%20User%20Manual%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-manual%2FUM11799.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ENXP%20Wi-Fi%20and%20Bluetooth%20Demo%20Applications%20for%20RW61x%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHope%20this%20helps!%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ERicardo%3C%2FP%3E%3C%2FLINGO-BODY%3E
