[RW612] How to analyze Stability Issue
1,429 次查看
AlexLiang
Background:
I'm using the RW612 EVK(with freeRTOS) to do pre-evaluation.
And is trying to make the wifi-bt coex work well. During this process, I encountered some stability issue but has no knowledge how to debug further.
I have searched the NXP docs for RW612 platform, but didnot find some documents/trainings guide me how to do stability issue analyzing.
Could you help to share any infos about how to do stability issue analyzing with rw612 platform ?
BTW, I'm using the SDK 1.2.3 SDK_25_06_00_FRDM-RW612
Thanks a lot!
标记 (3)
1,401 次查看
Ricardo_Zamora
Hope you are doing well. Are you using any of the coexistence examples from the SDK?
I would recommend checking this Application Note: Coexistence Overview for RW61x
Also, you could check section 8 of this User Manual: NXP Wi-Fi and Bluetooth Demo Applications for RW61x
Hope this helps!
Ricardo
1,395 次查看
AlexLiang
Hi Ricardo,
Thanks a lot for you infos! And yes, I did checked these 2 docs previously for wifi & bt coex cases.
And further background is, while developping basing SDK_25_06_00_FRDM-RW612, there is a stability issue that EVK board will run into crash, log print like below,
call_socket_task_init
Creating new socket.
socket_task_init socket thread created
do while
tcp_connect_thread wifi tcp Connecting...
tcp_connect_thread wifi tcp Connecting... IPv4
[2025-08-26 21:43:05.933]# RECV ASCII>
do while
[2025-08-26 21:43:06.922]# RECV ASCII>
do while
[2025-08-26 21:43:07.922]# RECV ASCII>
do while
[2025-08-26 21:43:08.930]# RECV ASCII>
do while
[2025-08-26 21:43:09.931]# RECV ASCII>
do while
[2025-08-26 21:43:10.261]# RECV ASCII>
AS
And the last "AS" print, I guess should be assert, but I did not get a method from the SDK / User Manual docs can help to do further root causing this issue.
So could you help to share some guide help me to find a easy way to debug this stability issue?
Alex
1,371 次查看
Ricardo_Zamora
Hi Alex,
Could you please specify what SDK example are you using as a base?
Did you modify something on the example? How are you testing this "stability issue"?
I would recommend checking this Application Note: NXP Wi-Fi and Bluetooth Debug Feature Configuration for RW61x Evaluation Board
Ricardo
1,402 次查看
Ricardo_Zamora
Hope this helps!
Ricardo
%3CLINGO-SUB%20id%3D%22lingo-sub-2158410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5BRW612%5D%20%E5%A6%82%E4%BD%95%E5%88%86%E6%9E%90%E7%A8%B3%E5%AE%9A%E6%80%A7%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%83%8C%E6%99%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20RW612%20EVK%EF%BC%88%E5%90%AB%20freeRTOS%EF%BC%89%E8%BF%9B%E8%A1%8C%E9%A2%84%E8%AF%84%E4%BC%B0%E3%80%82%3C%2FP%3E%3CP%3E%E5%B9%B6%E8%AF%95%E5%9B%BE%E8%AE%A9%20Wifi-bt%20coex%20%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E5%9C%A8%E6%AD%A4%E8%BF%87%E7%A8%8B%E4%B8%AD%EF%BC%8C%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E7%A8%B3%E5%AE%9A%E6%80%A7%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E4%B8%8D%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E8%BF%9B%E4%B8%80%E6%AD%A5%E8%B0%83%E8%AF%95%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E6%90%9C%E7%B4%A2%E4%BA%86%E6%81%A9%E6%99%BA%E6%B5%A6%20RW612%20%E5%B9%B3%E5%8F%B0%E7%9A%84%E6%96%87%E6%A1%A3%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E6%8C%87%E5%AF%BC%E6%88%91%E5%A6%82%E4%BD%95%E8%BF%9B%E8%A1%8C%E7%A8%B3%E5%AE%9A%E6%80%A7%E9%97%AE%E9%A2%98%E5%88%86%E6%9E%90%E7%9A%84%E6%96%87%E6%A1%A3%2F%E5%9F%B9%E8%AE%AD%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%82%A8%E8%83%BD%E6%8F%90%E4%BE%9B%E6%9C%89%E5%85%B3%E5%A6%82%E4%BD%95%E5%88%86%E6%9E%90%20rw612%20%E5%B9%B3%E5%8F%B0%E7%A8%B3%E5%AE%9A%E6%80%A7%E9%97%AE%E9%A2%98%E7%9A%84%E4%BF%A1%E6%81%AF%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%A1%BA%E4%BE%BF%E8%AF%B4%E4%B8%80%E4%B8%8B%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%3CSTRONG%3E%20SDK%201.2.3%20SDK_25_06_00_FRDM-RW612%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2159368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BRW612%5D%20How%20to%20analyze%20Stability%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2159368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E4%BA%9A%E5%8E%86%E5%85%8B%E6%96%AF%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AF%B7%E5%85%B7%E4%BD%93%E8%AF%B4%E6%98%8E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%20SDK%20%E7%A4%BA%E4%BE%8B%E4%BD%9C%E4%B8%BA%E5%9F%BA%E7%A1%80%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E4%BF%AE%E6%94%B9%E4%BA%86%E7%A4%BA%E4%BE%8B%E4%B8%AD%E7%9A%84%E6%9F%90%E4%BA%9B%E5%86%85%E5%AE%B9%EF%BC%9F%E6%82%A8%E6%98%AF%E5%A6%82%E4%BD%95%E6%B5%8B%E8%AF%95%22%E7%A8%B3%E5%AE%9A%E6%80%A7%E9%97%AE%E9%A2%98%E7%9A%84%22%20%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E6%9F%A5%E7%9C%8B%E6%AD%A4%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-manual%2FUM11797.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ERW61x%20%E8%AF%84%E4%BC%B0%E6%9D%BF%E7%9A%84%E6%81%A9%E6%99%BA%E6%B5%A6Wi-Fi%E5%92%8C%E8%93%9D%E7%89%99%E8%B0%83%E8%AF%95%E5%8A%9F%E8%83%BD%E9%85%8D%E7%BD%AE%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E9%87%8C%E5%8D%A1%E5%A4%9A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BRW612%5D%20How%20to%20analyze%20Stability%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E9%87%8C%E5%8D%A1%E5%A4%9A%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E4%BB%AC%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%81%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E4%B9%8B%E5%89%8D%E7%A1%AE%E5%AE%9E%E6%9F%A5%E7%9C%8B%E4%BA%86%E8%BF%99%E4%B8%A4%E4%BB%BD%E6%96%87%E6%A1%A3%EF%BC%8C%E4%BB%A5%E4%BA%86%E8%A7%A3%20wifi%26amp%3B%20bt%20coex%20%E7%9A%84%E6%83%85%E5%86%B5%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%9B%E4%B8%80%E6%AD%A5%E7%9A%84%E8%83%8C%E6%99%AF%E6%98%AF%EF%BC%8C%E5%9C%A8%E5%BC%80%E5%8F%91%E5%9F%BA%E4%BA%8E%20%3CSTRONG%3ESDK_25_06_00_FRDM-RW612%20%E6%97%B6%EF%BC%8C%E5%AD%98%E5%9C%A8%E7%A8%B3%E5%AE%9A%E6%80%A7%E9%97%AE%E9%A2%98%EF%BC%8CEVK%20%E6%9D%BF%E4%BC%9A%E5%B4%A9%E6%BA%83%EF%BC%8C%E6%97%A5%E5%BF%97%E6%89%93%E5%8D%B0%E5%A6%82%E4%B8%8B%3C%2FSTRONG%3E%E6%89%80%E7%A4%BA%EF%BC%8C%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Ecall_socket_task_init%3CBR%20%2F%3Ecall_socket_task_init%3CBR%20%2F%3E%E5%88%9B%E5%BB%BA%E6%96%B0%E5%A5%97%E6%8E%A5%E5%AD%97%E3%80%82%3CBR%20%2F%3Esocket_task_init%20%E5%88%9B%E5%BB%BA%E5%A5%97%E6%8E%A5%E5%AD%97%E7%BA%BF%E7%A8%8B%3CBR%20%2F%3Edo%20while%3CBR%20%2F%3Etcp_connect_thread%20wifi%20tcp%20Connecting...%3CBR%20%2F%3Etcp_connect_thread%20wifi%20tcp%20Connecting...IPv4%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%5B2025-08-26%2021%3A43%3A05.933%5D%23RECV%20ASCII%26gt%3B%3CBR%20%2F%3E%20do%20while%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%5B2025-08-26%2021%3A43%3A06.922%5D%23RECV%20ASCII%26gt%3B%3CBR%20%2F%3E%20do%20while%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%5B2025-08-26%2021%3A43%3A07.922%5D%23RECV%20ASCII%26gt%3B%3CBR%20%2F%3E%20do%20while%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%5B2025-08-26%2021%3A43%3A08.930%5D%23RECV%20ASCII%26gt%3B%3CBR%20%2F%3E%20do%20while%3C%2FP%3E%3CP%3E%5B2025-08-26%2021%3A43%3A09.931%5D%23RECV%20ASCII%26gt%3B%3CBR%20%2F%3E%20do%20while%3C%2FP%3E%3CP%3E%5B2025-08-26%2021%3A43%3A10.261%5D%23recv%20ascii%26gt%3B%3CBR%20%2F%3E%3CSTRONG%3Eas%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E8%80%8C%E6%9C%80%E5%90%8E%E7%9A%84%22AS%22%20%E6%89%93%E5%8D%B0%EF%BC%8C%E6%88%91%E6%83%B3%E5%BA%94%E8%AF%A5%E6%98%AF%E6%96%AD%E8%A8%80%EF%BC%8C%E4%BD%86%E6%88%91%E6%B2%A1%E6%9C%89%E4%BB%8E%20SDK%2F%E7%94%A8%E6%88%B7%E6%89%8B%E5%86%8C%E6%96%87%E6%A1%A3%E4%B8%AD%E6%89%BE%E5%88%B0%E5%8F%AF%E4%BB%A5%E5%B8%AE%E5%8A%A9%E8%BF%9B%E4%B8%80%E6%AD%A5%E6%A0%B9%E9%99%A4%E5%AF%BC%E8%87%B4%E6%AD%A4%E9%97%AE%E9%A2%98%E7%9A%84%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%82%A8%E8%83%BD%E5%90%A6%E4%B8%8E%E6%88%91%E5%88%86%E4%BA%AB%E4%B8%80%E4%BA%9B%E6%8C%87%E5%8D%97%EF%BC%8C%E5%B8%AE%E5%8A%A9%E6%88%91%E6%89%BE%E5%88%B0%E4%B8%80%E7%A7%8D%E7%AE%80%E5%8D%95%E7%9A%84%E6%96%B9%E6%B3%95%E6%9D%A5%E8%B0%83%E8%AF%95%E8%BF%99%E4%B8%AA%E7%A8%B3%E5%AE%9A%E6%80%A7%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%BA%9A%E5%8E%86%E5%85%8B%E6%96%AF%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BRW612%5D%20How%20to%20analyze%20Stability%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E4%BD%A0%E4%B8%80%E5%88%87%E9%A1%BA%E5%88%A9%E3%80%82%E6%82%A8%E6%98%AF%E5%90%A6%E4%BD%BF%E7%94%A8%E4%BA%86%20SDK%20%E4%B8%AD%E7%9A%84%E5%85%B1%E5%AD%98%E7%A4%BA%E4%BE%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%A0%E6%9F%A5%E7%9C%8B%E8%BF%99%E7%AF%87%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14121.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ERW61x%20%E5%85%B1%E5%AD%98%E6%A6%82%E8%BF%B0%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%82%A8%E8%BF%98%E5%8F%AF%E4%BB%A5%E6%9F%A5%E7%9C%8B%E6%9C%AC%E3%80%8A%E7%94%A8%E6%88%B7%E6%89%8B%E5%86%8C%E3%80%8B%E7%AC%AC%208%20%E8%8A%82%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-manual%2FUM11799.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E7%94%A8%E4%BA%8E%20RW61x%20%E7%9A%84%E6%81%A9%E6%99%BA%E6%B5%A6%20Wi-Fi%20%E5%92%8C%E8%93%9D%E7%89%99%E6%BC%94%E7%A4%BA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%EF%BC%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E9%87%8C%E5%8D%A1%E5%A4%9A%3C%2FP%3E%3C%2FLINGO-BODY%3E
