question when there was Wakeup interrupt before WFI instruction practice.(In LPSTOP3 mode)
1,132件の閲覧回数
soichiyamamoto
Contributor V
It is a question from My customer.
In LPSTOP3 mode. It is a question when there was Wakeup interrupt before WFI instruction practice.
①Does MPU carry out WFI?
I understand it as the following but is this correct?
 - It changes in LPSTOP3 mode, and does wakeup.
soichi
2 返答(返信)
834件の閲覧回数
timesyssupport
Senior Contributor II
Hello Soichi,
I apologize, I do not quite understand your question. Are you inquiring about a wakeup interrupt when just one core has been issued the WFI instruction? This should cause the Vybrid to resume from LPSTOP3 mode, regardless of the GPC IMR register values. There is a thread that discusses this here:
Vybrid low power wakup source
Can you please clarify if this does not answer your question?
Timesys Support
833件の閲覧回数
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport can you attend this case?
