VF6xx VYBRID Cortex-M4 Cache sample code
4,592 次查看
wushengjiang
Is there any sample for VF6xx VYBRID Cortex-M4 cache operation?
It seems data cache operation is not success when debug with network on Cortext-M4, network packet loss when data cache is on, after disable data cache on Cortex-M4, no packet loss.
The same code works well on Cortex-A5 side which has PL310 L2 cache.
标记 (2)
4,319 次查看
CommunityBot
Community Manager
This an automatic process.
We are marking this post as solved, due to the either low activity or any reply marked as correct.
If you have additional questions, please create a new post and reference to this closed post.
NXP Community!
5 回复数
4,320 次查看
CommunityBot
Community Manager
NXP Community!
4,320 次查看
timesyssupport
Senior Contributor II
Hello Wu,
Presumably you are working with MQX in this case? There is the following, which tests some cache operations: mqx/examples/benchmrk/codesize/main.c
karinavalencia​ - if this is MQX, can the MQX team review?
Thank you,
Timesys Support
4,320 次查看
wushengjiang
Thanks for all your help, I found the cache.c under folder mqx\source\psp\cortex_m, I will compare it with current driver.
4,320 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
Lets wait the update from Wu.
4,320 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport​ an you help here?
