NAND Boot with Linux 3.13
1,504 次查看
Nouchi
Senior Contributor II
I'm beginning to play with Linux-3.13 and u-boot-2013.07 on tower board, and I'm looking for a good "Howto" to configure the system booting on NAND flash.
I've few questions :
- Where and how to write device tree block on flash?
- How partitioning NAND flash, the old way don't work any more? ( mtdparts=NAND:  etc.....)
- From timesys factory, how to rebuild the device tree?
Emmanuel
标签 (4)
5 回复数
1,226 次查看
alejandrolozan1
I am sure Timesys will provide more information in regards their BSP I just wonder if you have checked this :
https://linuxlink.timesys.com/docs/projects/engineering/wiki/NAND_Boot_for_Vybrid_Tower
Alejandro
1,226 次查看
Nouchi
1,226 次查看
timesyssupport
Thank you for following up - yes, we are in the process of updating the Vybrid documentation to reflect changes for the 3.13 release.
The HOWTO Ubifs document is somewhat general; typically we suggest reviewing the MTD documentation located here for management of UBIFS rootfs:
http://www.linux-mtd.infradead.org/doc/ubifs.html
The Vybrid-specific information we will review and update. We will follow up in this thread once the process has been documented.
Timesys Support
1,226 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport do you have an update?
1,226 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport can you help to check this case?
