How to initialize a DMA channel for a circular buffer?
5,788 次查看
dieterfalk
I want to initialize a DMA channel to transfer input capture values (e.g. FTM2_CH0) to a circular destination buffer using the modulo feature. This DMA should run continuously. The buffer will be checked periodically (reading the DADDR register value to determine the current write pointer.
I am not clear about the initialization of the DOFF register and minor-/major loop operation register if I want to use the continuous running DMA with the modulo feature. Can you help me with an example code? Thank you.
标签 (2)
5,176 次查看
dieterfalk
thanks for these examples. They mainly show the general use of DMA in different examples. The modulo feature is not used.
In any case I think these example will help me to find a solution for my problem. Therefore I will close this task.
Dieter
7 回复数
5,175 次查看
rendy
please try attached example code which should demonstrate using of DMA. Let me know in case of any problems. Project are created with IAR version 7.10, will not work withe lesser version. You can download 30 day trial here: http://supp.iar.com/Download/SW/?item=EWARM-EVAL
Rene
5,177 次查看
dieterfalk
Dieter
5,175 次查看
timesyssupport
Senior Contributor II
Hello Dieter,
Are you looking to do this in MQX or Linux? Let me know, and I will see if there is any similar code available.
Timesys Support
5,175 次查看
dieterfalk
the code should be independent on any OS.
Dieter
5,175 次查看
timesyssupport
Hello Dieter,
I have reviewed all Linux driver source for the Vybrid Tower that uses eDMA (serial, dspi, asrc, sound), but unfortunately, none of these use the eDMA modulo feature.  karinavalencia, does the Freescale team have any input about how the DMAx_TCDn_DOFF, DMAx_TCDn_NBYTES*, DMAx_TCDn_BITER*, and DMAx_TCDn_CITER* registers should be configured when using the modulo feature of eDMA (bits 3-7 of DMAx_TCDn_ATTR set)? Dieter, feel free to clarify if this is not what you are looking for.
Timesys Support
5,175 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
rendy can you review  previous update  from Timesys and share your comments?
5,175 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport can you help with this case?
