Circuit review documents
3,086 次查看
Hiroki
Would you have a plan to provide any circuit review documents?
Hiroki
标签 (3)
2,838 次查看
naoumgitnik
Senior Contributor V
Dear Hiroki,
Thanks for referring me to the document. Now I understand what you mean, although first I thought you meant a special document describing how to treat the unused pins.
We are planning something similar to that App. Note but we call it "Design Guide"; meanwhile, please, use the relevant information from the Datasheet, Reference Manual, and Reference Platform schematic.
Sincerely, Naoum Gitnik.
10 回复数
2,838 次查看
Hiroki
Hi Naoum,
I'd like to know each pins' treatment of Vybrid, for example PTA0 needs a pull-up. Some customers require FSL to review their board. And I need a document of the reference for a circuit review of Vybrid.
Hiroki
2,838 次查看
naoumgitnik
Dear Hiroki,
It is clear now.
  1. Please, use our reference platforms (boards) for that kind of information, in addition to the Datasheet.
  2. Schematics are usually reviewed for Tier1 customers only (customer status defined by Marketing, I guess, based on the buying potential, etc.). There is no special form to fill for schematic review; just place it on the internal Freescale FAE_Vybrid Community or, if EXTREMELY confidential, via an SR (Service Request).
2,838 次查看
Hiroki
Hi Naoum,
I want a design check list like QorIQ.
I'd like to know non used pins' treatments.
Hiroki
2,838 次查看
naoumgitnik
Dear Hiroki,
May you refer to that specific document, please?
2,838 次查看
Hiroki
Hi Naoum,
Does that specific document mean the board schematic and the datasheet?
Hiroki
2,838 次查看
naoumgitnik
Dear Hiroki,
I meant the "design check list like QorIQ" you referred me to - unfortunately, I am not familiar with it.
2,838 次查看
Hiroki
Hi Naoum,
This is the design checklist URL.
https://www.google.co.jp/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CC4QFjAA&url=http%3A%...
I'd like FSL to prepare the document like this for Vybrid, too.
Hiroki
2,839 次查看
naoumgitnik
Dear Hiroki,
2,838 次查看
MehmetAliIpin
Dear Naoum,
When this design guide will be available?
Thanks and best regards
2,838 次查看
naoumgitnik
Dear Hiroki,
May you be a little more specific, please? - Any examples of the "circuit review documents" mentioned, please?
