Circuit review documents
4,453件の閲覧回数
Hiroki
Would you have a plan to provide any circuit review documents?
Hiroki
ラベル(3)
4,205件の閲覧回数
naoumgitnik
Senior Contributor V
Dear Hiroki,
Thanks for referring me to the document. Now I understand what you mean, although first I thought you meant a special document describing how to treat the unused pins.
We are planning something similar to that App. Note but we call it "Design Guide"; meanwhile, please, use the relevant information from the Datasheet, Reference Manual, and Reference Platform schematic.
Sincerely, Naoum Gitnik.
10 返答(返信)
4,205件の閲覧回数
Hiroki
Hi Naoum,
I'd like to know each pins' treatment of Vybrid, for example PTA0 needs a pull-up. Some customers require FSL to review their board. And I need a document of the reference for a circuit review of Vybrid.
Hiroki
4,205件の閲覧回数
naoumgitnik
Dear Hiroki,
It is clear now.
  1. Please, use our reference platforms (boards) for that kind of information, in addition to the Datasheet.
  2. Schematics are usually reviewed for Tier1 customers only (customer status defined by Marketing, I guess, based on the buying potential, etc.). There is no special form to fill for schematic review; just place it on the internal Freescale FAE_Vybrid Community or, if EXTREMELY confidential, via an SR (Service Request).
4,205件の閲覧回数
Hiroki
Hi Naoum,
I want a design check list like QorIQ.
I'd like to know non used pins' treatments.
Hiroki
4,205件の閲覧回数
naoumgitnik
Dear Hiroki,
May you refer to that specific document, please?
4,205件の閲覧回数
Hiroki
Hi Naoum,
Does that specific document mean the board schematic and the datasheet?
Hiroki
4,205件の閲覧回数
naoumgitnik
Dear Hiroki,
I meant the "design check list like QorIQ" you referred me to - unfortunately, I am not familiar with it.
4,205件の閲覧回数
Hiroki
Hi Naoum,
This is the design checklist URL.
https://www.google.co.jp/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CC4QFjAA&url=http%3A%...
I'd like FSL to prepare the document like this for Vybrid, too.
Hiroki
4,206件の閲覧回数
naoumgitnik
Dear Hiroki,
4,205件の閲覧回数
MehmetAliIpin
Dear Naoum,
When this design guide will be available?
Thanks and best regards
4,205件の閲覧回数
naoumgitnik
Dear Hiroki,
May you be a little more specific, please? - Any examples of the "circuit review documents" mentioned, please?
