Is there an email contact for problems with forum?
4,490件の閲覧回数
rkj
I would like to know if there is an email contact for problems with the forum.  I posted a question to the QorIQ community that was approved by the moderators on Fri 8/2, but it still is not showing up in the community and it still shows as a "draft" that needs approval.
4,260件の閲覧回数
RHinnen
R Johnson - This question appears to be out of the draft state and in the community as an active question. If you are seeing something different, please post a screen shot of what you are seeing within the community. Thanks!
3 返答(返信)
4,261件の閲覧回数
RHinnen
4,260件の閲覧回数
rkj
Yes, it is now an active question.  Here is what I think happened.  I had submitted a question to the QorIQ community on Fri 8/2.  I later noticed a spelling error, so I edited the post and clicked the checkbox that it was a minor edit.  I then received notice that the post was approved by the moderators on Fri 8/2.  However, by Mon 8/5, it was still not showing up in the QorIQ community and it still showed as a draft.  I then decided to edit it again and not click the box that it was a minor edit.  Soon after that I got another email that the post was approved and it then showed up in the QorIQ community.
4,260件の閲覧回数
Paul_Kuhn
Thanks for the additional detail. It sounds like we have a bug in the “minor edit” feature. We will look into it.
