Bootloader Mode
Bootloader Mode
4,289 次查看
cedricdestin
Greetings,
I am using the MPU5604B, and I am just starting to use it, and had to run an update on purpose to executed. So i entered the bootloader mode of the board, but it seems that it is stuck at the bootloader mode and does not get out unto the required mode to execute...
4,106 次查看
cedricdestin
Ok, my question was answered, by the simplest thing in the world following directions...
4 回复数
4,107 次查看
cedricdestin
4,106 次查看
FlavioStiffan
Hi Cedric,
Have you tried looking at the Knowledge Center on the Community? If stuck, please open a Technical Information support request on the Freescale site at New Service Request
I will try to get somebody to look at this.
4,106 次查看
cedricdestin
Hey Flavio, I haven't, because I got it the day the day of my post. But pretty much the problem I was having was, I did not understand what it meant as jumper pin- header. I did not know the jumper pin- header connected the pins. I am mostly familiar with simply pin headers that do not connect...
Thank you for your help i appreciate so much.
4,106 次查看
FlavioStiffan
Hi Cedric,
Can you please confirm if your question has been solved? If it has, please mark the question as answered.
