Freescale H.I.T. Project #1: MonkeyJam - A DIY Guitar Stomp Box
Project Summary
SheldonJam.pngMonkeyJam will use the FRDM-K20D50 board (which has a Cortex M4 core with DSP instructions) along with the FRDM-JAM shield so you can  make your very
own guitar /bass  stomp box.  The end result will be a functional DSP system that will allow you to do high quality amplifier simulation and effects.
The FRDM-JAM does not limit you to DSP on musical instruments!  There are 3.5mm stereo jacks to DSP filtering any type of audio signal.    You could even use the USB interface to create a USB-MIDI Synthesizer!  Lastly,  no need to bring the house down.....  a headphone amplifier circuit is provided so you can jam out without bothering the neighbors.
MBED Support coming *very soon*
Skills Developed:
  • Real Time Processing
  • DSP Algorithms
  • Fixed Point Mathematics
  • 24-bit I2S Data Converter Interfacing
  • Soldering SOIC8 and 1206 Surface mount devices
  • Cortex CMSIS DSP Library
Materials:
FRDM-K20D50
FRDM-JAM
Development Tools
Install Codewarrior 10.5 for Microcontrollers (Eclipse) Special Edition to your  machine
Example Code
Get the latest copy from Github
Step 0: Prerequisite Videos
The videos are organized into a nice YouTube playlist:
H.I.T 1: Monkey Jam - YouTube
https://www.youtube.com/playlist?list=PLWM8NW5LEukgM-D5eRMtKZ8R2WfXnqKGp
  • MonkeyJam Watch Me 1st
  • FRDM-JAM Hardware Overview
  • MonkeyJam Software Overview
  • Introduction to Fixed Point Math for Embedded Systems - Part 1 of 3
  • Introduction to Fixed Point Math for Embedded Systems - Part 2 of 3
  • Introduction to Fixed Point Math for Embedded Systems - Part 3 of 3
  • Real Time Signal Processing Part 1 of 3
  • Real Time Signal Processing Part 2 of 3
  • Real Time Signal Processing Part 3 of 3
  • q31_t (Q0.31) Number Format for the CMSIS DSP Libraries and the MonkeyJam Software
  • Guitar physics in a nutshell
  • Ideas for hacking the MonkeyJam
Step 1: Get a FRDM-JAM
MonkeyJam Build Package on the FRDM-JAM site.    Please let us know if you are interested in a pre-assembled version.  If there is enough demand we will get some preassembled for purchase, I will get a Kickstarter going!   Don't be afraid to build it yourself,  Soldering is fun!  There is plenty of good stuff on the web on how to do SMT soldering.  All of the parts on the board are fairly simply once you get the hang of it and everything can be hand soldered  The key is having some decent tools.
Step 2: Put it Together
Attach the FRDM-JAM to the FRDM-K20D50.  The FRDM-K20D50 comes with female headers that you can solder on so the boards can be easily separated.  Note that as of Rev Gamma (current version),   it is possible to connect to a K64F.    The software isn't quite there but it hardware connections are available.   If you are unsure,  stick with the FRDM-K20D50
Step 3: Download
Download the Example Software from Github.  The video "Loading and Configuring the MonkeyJam Example Software" will step you though downloading the program and doing some basic configuration.
Step 4: Hack and Slash!
Plug In and jam!
Sound Samples
Each sound sample was my Carvin Ultra-V guitar plugged direct into the MonkeyJam Board.  The output was fed to a Zoom Handy Recorder H4n (Thanks to Brandin Claar of Remodulate LLC for the recorder).  The H4N recorded the signal at 44.1KHz Sample rate @16-bit.  The sound files were converted to mono format via Goldwave.  No processing (other than a  volume boost on the files) was performed.   I listen to the recording in real-time via a line out on the H4N.
File (See Attachments)PatchNotes
STE-003-Neck-a12b12g12-mlike.wav
PATCH_TUBEY_CLEAN
Neck Pickup
Alpha Pot - 12 O'Cock
Beta Pot - 12 O'Cock
Gamma Pot - 12 O'Cock
Pattern Similar to Metallica Sanitarium
STE-005-Neck-a7b5g5-mlike.wav
PATCH_TUBEY_CLEAN
Neck Pickup
Alpha Pot - 7 O'Cock
Beta Pot - 5 O'Cock
Gamma Pot - 5 O'Cock
STE-006-Neck-a12b7g5-mlike.wav
PATCH_TUBEY_CLEAN
Neck Pickup
Beta Pot - 7 O'Cock
STE-007-Neck-VariousSettings-d-g-em_strum.wav
PATCH_TUBEY_CLEAN
Neck Pickup
The pots were moved around throughout the file
Strummed D-Major, G-Major and E-Minor
STE-008-Neck+Bridge-VariousSettings-d-g-em_strum.wav
PATCH_TUBEY_CLEAN
Neck + Bridge Pickup
STE-009-Bridge-VariousSettings-d-g-em_strum.wav
PATCH_TUBEY_CLEAN
Bridge + Bridge Pickup
STE-010-Neck-VariousSettings-Jammy.wav
PATCH_TUBEY_CLEAN
B-Minor Type Jam
STE-011- Bridge - Various Settings - On-Off Demo-RandomDroppedD.wav
PATCH_OVERDRIVE
Bridge Pickup
Alpha Pot - 5 O'Cock
Random Dropped D twiddling
STE-012- Neck - Various Settings - On-Off Demo-Jammy.wav
PATCH_OVERDRIVE
Neck Pickup
Beta Pot - 7 O'Cock
Gamma Pot - 7 O'Cock
Random B-Minor twiddles (bluesy)
PATCH_OVERDRIVE
  Signal In  |    IIR BiQuad    |      |      Hard Overdrive      |      |      IIR BiQuad     |  Signal Out     
             |   [Peaking EQ]   |      | [atan24pi Look Up Table] |      |  [Low Pass Filter]  |                 
                 0.1 < Q < 1.5    [Pot Alpha]                                     Q = 0                          
                 50 < Fs < 750    [Pot Gamma]                                   Fs = 2000                        
               -20 < dbGain < 20  [Pot Beta]
PATCH_TUBEY_CLEAN
  Signal In  |    IIR BiQuad    |      |      Soft Overdrive      |      |      IIR BiQuad     |  Signal Out     
             |     [LowShelf]   |      | [atan4pi Look Up Table]  |      |  [Low Pass Filter]  |                 
                 0.05 < Q < 2.58   [Pot Alpha]                                     Q = 2.0                          
                1000 < Fs < 4000    [Pot Beta]                                   Fs = 2500                        
               -15 < dbGain < 15  [Pot Gamma]
Utilities, etc:
Biquad Filter View - A IIR Biquad Filter Design &amp; Visualization Tool
附件
评论
Hi eli_hughes
Thanks For the awesome tutorial. It pretty much shows the real life implementation of DSP. I wanted to ask you about implementation of CMSIS library in codewarrior. In one of my projects I wanted to implement DSP library to implement FFT. But I am stuck in implementing CMSIS library. I saw your Video for this as well as the 2nd project i.e Project #2: Monkey Listen! Audio Spectrum Analyzer Display That was also awesome like this. But again I cannot move further as I am facing problem in implementing the library.I went through some post regarding implementing the CMSIS library but that was not compiling and was giving errors. and sometimes was exceeding the m-text limit. I went through the following links.
Tutorial: Using the ARM CMSIS Library | MCU on Eclipse
Adding the CMSIS-DSP library
移植CMSIS-DSP库到CodeWarrior的步骤以及Kinetis FPU单元应用的对比
Please look into the matter. I hope this post will be beneficial for many community users. Thanks in advance
Kind Regards
Amit Kumar
Amit:
Do you try importing the MonkeyListen project and see the settings I used?   What chip are you targeting?
Hi Eli Hughes
I Imported the MonkeyListen Project and it got compiled without any error. right now for testing I am targeting FRDM-K20D50M (MK20DX128). After this I will be targeting mk60fn1m0vlq12. What are the settings required to be done for using the library in any project ? If you can provide some snapshot of  the settings required to make it work It will be helpful for all the community members. As I went across some queries which was unanswered regarding the same. In ARM's website also I didn't find any help regarding this. When I saw your tutorial everything was well explained. So If this portion is also covered in it than it will a great help for people like me. and I am sure many people want to use it but can't use due to this implementation part.
Thanks in advance
Kind Regards
Amit Kumar
Amit:
If you click on the project properties for the library and look at processor settings, there are 2 symbols (ARM_CM4 and ARM_ROUNDING).   This is all I had to do to get it compile.
I think I covered it in one of the videos.  If not, I will certainly have to get some sort of small video for it!.
-Eli
Hi Eli
Thanks for your reply. when I am opening your project for the 1st time I am getting some warning message. Is this message of any concern?.
Kind Regards
Amit Kumar
Hi Eli Hughes
Can you provide me the link of the video in which you have demonstrated how to implement  CMSIS library with codwarrior basically I am concerned with FFT library which you have implemented? It Will be a great help. Thanks
Kind Regards
Amit Kumar
Hi Eli
I have implemented the CMSIS code and also made the document for others , kindly look if anything is incorrect in the process and please update it. https://community.freescale.com/message/414670#414670
Kind Regards
Amit Kumar
%3CLINGO-SUB%20id%3D%22lingo-sub-1120736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20HIT%20%E9%A1%B9%E7%9B%AE%20%231%EF%BC%9AMonkeyJam%20-%20DIY%20%E5%90%89%E4%BB%96%E6%95%88%E6%9E%9C%E5%99%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-H-I-T-Project-1-MonkeyJam-A-DIY-Guitar-Stomp-Box%2Fta-p%2F1120736%23toc-hId-382338843%22%20target%3D%22_blank%22%3E%E9%A1%B9%E7%9B%AE%E6%91%98%E8%A6%81%20%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-H-I-T-Project-1-MonkeyJam-A-DIY-Guitar-Stomp-Box%2Fta-p%2F1120736%23toc-hId--1425115620%22%20target%3D%22_blank%22%3E%E5%9F%B9%E5%85%BB%E7%9A%84%E6%8A%80%E8%83%BD%EF%BC%9A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-H-I-T-Project-1-MonkeyJam-A-DIY-Guitar-Stomp-Box%2Fta-p%2F1120736%23toc-hId-1062397213%22%20target%3D%22_blank%22%3E%E6%9D%90%E6%96%99%EF%BC%9A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-H-I-T-Project-1-MonkeyJam-A-DIY-Guitar-Stomp-Box%2Fta-p%2F1120736%23toc-hId--745057250%22%20target%3D%22_blank%22%3E%E6%AD%A5%E9%AA%A4%200%EF%BC%9A%E5%BF%85%E5%A4%87%E8%A7%86%E9%A2%91%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-H-I-T-Project-1-MonkeyJam-A-DIY-Guitar-Stomp-Box%2Fta-p%2F1120736%23toc-hId--64998880%22%20target%3D%22_blank%22%3E%E6%AD%A5%E9%AA%A4%201%EF%BC%9A%E8%8E%B7%E5%8F%96%20FRDM-JAM%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-H-I-T-Project-1-MonkeyJam-A-DIY-Guitar-Stomp-Box%2Fta-p%2F1120736%23toc-hId--1872453343%22%20target%3D%22_blank%22%3E%E7%AC%AC%202%20%E6%AD%A5%EF%BC%9A%E6%95%B4%E5%90%88%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-H-I-T-Project-1-MonkeyJam-A-DIY-Guitar-Stomp-Box%2Fta-p%2F1120736%23toc-hId-615059490%22%20target%3D%22_blank%22%3E%E6%AD%A5%E9%AA%A43%EF%BC%9A%E4%B8%8B%E8%BD%BD%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-H-I-T-Project-1-MonkeyJam-A-DIY-Guitar-Stomp-Box%2Fta-p%2F1120736%23toc-hId--1192394973%22%20target%3D%22_blank%22%3E%E6%AD%A5%E9%AA%A4%204%EF%BC%9A%E7%A0%8D%E6%9D%80%EF%BC%81%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-H-I-T-Project-1-MonkeyJam-A-DIY-Guitar-Stomp-Box%2Fta-p%2F1120736%23toc-hId-1295117860%22%20target%3D%22_blank%22%3E%E5%A3%B0%E9%9F%B3%E6%A0%B7%E6%9C%AC%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-H-I-T-Project-1-MonkeyJam-A-DIY-Guitar-Stomp-Box%2Fta-p%2F1120736%23toc-hId--764600942%22%20target%3D%22_blank%22%3E%E5%85%AC%E7%94%A8%E8%AE%BE%E6%96%BD%E7%AD%89%EF%BC%9A%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-382338843%22%20id%3D%22toc-hId-382338843%22%20id%3D%22toc-hId-1304250352%22%3E%3CSTRONG%3E%E9%A1%B9%E7%9B%AE%E6%91%98%E8%A6%81%20%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SheldonJam.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SheldonJam.png%22%20style%3D%22width%3A%20450px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F43727i673ECBBD80DE86A9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SheldonJam.png%22%20alt%3D%22SheldonJam.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESheldonJam.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3EMonkeyJam%20%E5%B0%86%E4%BD%BF%E7%94%A8%20FRDM-K20D50%20%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%88%E5%85%B7%E6%9C%89%20Cortex%20M4%20%E5%86%85%E6%A0%B8%E5%92%8C%20DSP%20%E6%8C%87%E4%BB%A4%EF%BC%89%E4%BB%A5%E5%8F%8A%20FRDM-JAM%20%E6%89%A9%E5%B1%95%E6%9D%BF%EF%BC%8C%E8%BF%99%E6%A0%B7%E6%82%A8%E5%B0%B1%E5%8F%AF%E4%BB%A5%E5%88%B6%E4%BD%9C%E6%82%A8%E8%87%AA%E5%B7%B1%E7%9A%84%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E8%87%AA%E5%B7%B1%E7%9A%84%E5%90%89%E4%BB%96%2F%E8%B4%9D%E6%96%AF%E6%95%88%E6%9E%9C%E5%99%A8%E3%80%82%E6%9C%80%E7%BB%88%E7%BB%93%E6%9E%9C%E5%B0%86%E6%98%AF%E4%B8%80%E4%B8%AA%E5%8A%9F%E8%83%BD%E6%80%A7%E7%9A%84%20DSP%20%E7%B3%BB%E7%BB%9F%EF%BC%8C%E5%85%81%E8%AE%B8%E6%82%A8%E8%BF%9B%E8%A1%8C%E9%AB%98%E8%B4%A8%E9%87%8F%E7%9A%84%E6%94%BE%E5%A4%A7%E5%99%A8%E6%A8%A1%E6%8B%9F%E5%92%8C%E6%95%88%E6%9E%9C%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3EFRDM-JAM%20%E4%B8%8D%E4%BC%9A%E9%99%90%E5%88%B6%E6%82%A8%E5%9C%A8%E4%B9%90%E5%99%A8%E4%B8%8A%E4%BD%BF%E7%94%A8%20DSP%EF%BC%81%E6%9C%89%203.5%20%E6%AF%AB%E7%B1%B3%E7%AB%8B%E4%BD%93%E5%A3%B0%E6%8F%92%E5%AD%94%EF%BC%8C%E7%94%A8%E4%BA%8E%20DSP%20%E8%BF%87%E6%BB%A4%E4%BB%BB%E4%BD%95%E7%B1%BB%E5%9E%8B%E7%9A%84%E9%9F%B3%E9%A2%91%E4%BF%A1%E5%8F%B7%E3%80%82%E6%82%A8%E7%94%9A%E8%87%B3%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20USB%20%E6%8E%A5%E5%8F%A3%E6%9D%A5%E5%88%9B%E5%BB%BA%20USB-MIDI%20%E5%90%88%E6%88%90%E5%99%A8%EF%BC%81%E6%9C%80%E5%90%8E%EF%BC%8C%E6%97%A0%E9%9C%80%E6%8B%86%E6%8E%89%E6%88%BF%E5%AD%90......%E9%85%8D%E5%A4%87%E4%BA%86%E8%80%B3%E6%9C%BA%E6%94%BE%E5%A4%A7%E5%99%A8%E7%94%B5%E8%B7%AF%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E4%B8%8D%E6%89%93%E6%89%B0%E9%82%BB%E5%B1%85%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%B0%BD%E6%83%85%E4%BA%AB%E5%8F%97%E9%9F%B3%E4%B9%90%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2016px%3B%20text-align%3A%20center%3B%22%3E%3CSTRONG%20style%3D%22%3A%20%3B%20color%3A%20%23339966%3B%20font-size%3A%2012pt%3B%22%3EMBED%20%E6%94%AF%E6%8C%81%E5%8D%B3%E5%B0%86%E6%8E%A8%E5%87%BA%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1425115620%22%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%20id%3D%22toc-hId--1425115620%22%20id%3D%22toc-hId--503204111%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSTRONG%3E%E5%9F%B9%E5%85%BB%E7%9A%84%E6%8A%80%E8%83%BD%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%AE%9E%E6%97%B6%E5%A4%84%E7%90%86%3C%2FLI%3E%3CLI%3EDSP%20%E7%AE%97%E6%B3%95%3C%2FLI%3E%3CLI%3E%E4%B8%8D%E5%8A%A8%E7%82%B9%E6%95%B0%E5%AD%A6%3C%2FLI%3E%3CLI%3E24%20%E4%BD%8D%20I2S%20%E6%95%B0%E6%8D%AE%E8%BD%AC%E6%8D%A2%E5%99%A8%E6%8E%A5%E5%8F%A3%3C%2FLI%3E%3CLI%3E%E7%84%8A%E6%8E%A5%20SOIC8%20%E5%92%8C%201206%20%E8%A1%A8%E9%9D%A2%E8%B4%B4%E8%A3%85%E5%99%A8%E4%BB%B6%3C%2FLI%3E%3CLI%3ECortex%20CMSIS%20DSP%20%E5%BA%93%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1062397213%22%20id%3D%22toc-hId-1062397213%22%20id%3D%22toc-hId-1984308722%22%3E%3CSTRONG%3E%E6%9D%90%E6%96%99%EF%BC%9A%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20class%3D%22jiveBorder%22%20height%3D%22295%22%20jive-data-cell%3D%22%7B%22%20color%3D%22%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20center%3B%22%3E%3CP%3E%3CSTRONG%3E%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DFRDM-K20D50M%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3EFRDM-K20D50%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22K20D50.PNG.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22K20D50.PNG.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F43682i2FF5CF5A87620E5E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22K20D50.PNG.png%22%20alt%3D%22K20D50.PNG.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EK20D50.PNG.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22text-align%3A%20center%3B%22%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100151%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3EFRDM-JAM%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FRDM-JAM-s.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FRDM-JAM-s.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F43281iD1AB62DA7D30F98A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FRDM-JAM-s.png%22%20alt%3D%22FRDM-JAM-s.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFRDM-JAM-s.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20center%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%E5%BC%80%E5%8F%91%E5%B7%A5%E5%85%B7%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Foverview.jsp%3Fcode%3DCW_SPECIALEDITIONS%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22font-size%3A%2015.555556297302246px%3B%20text-align%3A%20center%3B%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E%E5%9C%A8%E6%82%A8%E7%9A%84%E6%9C%BA%E5%99%A8%E4%B8%8A%E5%AE%89%E8%A3%85%20Codewarrior%2010.5%20%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%20(Eclipse)%20%E7%89%B9%E5%88%AB%E7%89%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22text-align%3A%20center%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%E4%BB%8E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fehughes%2FMonkeyJam%2Freleases%2Ftag%2FR0%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGithub%3C%2FA%3E%E8%8E%B7%E5%8F%96%E6%9C%80%E6%96%B0%E5%89%AF%E6%9C%AC%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--745057250%22%20id%3D%22toc-hId--745057250%22%20id%3D%22toc-hId-176854259%22%3E%3CSTRONG%3E%E6%AD%A5%E9%AA%A4%200%EF%BC%9A%E5%BF%85%E5%A4%87%E8%A7%86%E9%A2%91%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%BF%99%E4%BA%9B%E8%A7%86%E9%A2%91%E8%A2%AB%E6%95%B4%E7%90%86%E6%88%90%E4%B8%80%E4%B8%AA%E6%BC%82%E4%BA%AE%E7%9A%84%20YouTube%20%E6%92%AD%E6%94%BE%E5%88%97%E8%A1%A8%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fwww.youtube.com%2Fplaylist%3Flist%3DPLWM8NW5LEukgM-D5eRMtKZ8R2WfXnqKGp%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20title%3D%22https%3A%2F%2Fwww.youtube.com%2Fplaylist%3Flist%3DPLWM8NW5LEukgM-D5eRMtKZ8R2WfXnqKGp%22%20target%3D%22_blank%22%3E%E7%83%AD%E9%97%A8%E6%AD%8C%E6%9B%B2%201%EF%BC%9AMonkey%20Jam%20-%20YouTube%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fwww.youtube.com%2Fplaylist%3Flist%3DPLWM8NW5LEukgM-D5eRMtKZ8R2WfXnqKGp%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20title%3D%22https%3A%2F%2Fwww.youtube.com%2Fplaylist%3Flist%3DPLWM8NW5LEukgM-D5eRMtKZ8R2WfXnqKGp%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.youtube.com%2Fplaylist%3Flist%3DPLWM8NW5LEukgM-D5eRMtKZ8R2WfXnqKGp%3C%2FA%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3EMonkeyJam%20%E5%85%88%E7%9C%8B%E6%88%91%3C%2FLI%3E%3CLI%3EFRDM-JAM%E7%A1%AC%E4%BB%B6%E6%A6%82%E8%BF%B0%3C%2FLI%3E%3CLI%3EMonkeyJam%20%E8%BD%AF%E4%BB%B6%E6%A6%82%E8%BF%B0%3C%2FLI%3E%3CLI%3E%E5%B5%8C%E5%85%A5%E5%BC%8F%E7%B3%BB%E7%BB%9F%E5%AE%9A%E7%82%B9%E6%95%B0%E5%AD%A6%E7%AE%80%E4%BB%8B%20-%20%E7%AC%AC%201%20%E9%83%A8%E5%88%86%EF%BC%88%E5%85%B1%203%20%E9%83%A8%E5%88%86%EF%BC%89%3C%2FLI%3E%3CLI%3E%E5%B5%8C%E5%85%A5%E5%BC%8F%E7%B3%BB%E7%BB%9F%E5%AE%9A%E7%82%B9%E6%95%B0%E5%AD%A6%E7%AE%80%E4%BB%8B%20-%20%E7%AC%AC%202%20%E9%83%A8%E5%88%86%EF%BC%88%E5%85%B1%203%20%E9%83%A8%E5%88%86%EF%BC%89%3C%2FLI%3E%3CLI%3E%E5%B5%8C%E5%85%A5%E5%BC%8F%E7%B3%BB%E7%BB%9F%E5%AE%9A%E7%82%B9%E6%95%B0%E5%AD%A6%E7%AE%80%E4%BB%8B%20-%20%E7%AC%AC%203%20%E9%83%A8%E5%88%86%EF%BC%88%E5%85%B1%203%20%E9%83%A8%E5%88%86%EF%BC%89%3C%2FLI%3E%3CLI%3E%E5%AE%9E%E6%97%B6%E4%BF%A1%E5%8F%B7%E5%A4%84%E7%90%86%EF%BC%88%E7%AC%AC%201%20%E9%83%A8%E5%88%86%EF%BC%8C%E5%85%B1%203%20%E9%83%A8%E5%88%86%EF%BC%89%3C%2FLI%3E%3CLI%3E%E5%AE%9E%E6%97%B6%E4%BF%A1%E5%8F%B7%E5%A4%84%E7%90%86%EF%BC%88%E7%AC%AC%202%20%E9%83%A8%E5%88%86%EF%BC%8C%E5%85%B1%203%20%E9%83%A8%E5%88%86%EF%BC%89%3C%2FLI%3E%3CLI%3E%E5%AE%9E%E6%97%B6%E4%BF%A1%E5%8F%B7%E5%A4%84%E7%90%86%EF%BC%88%E7%AC%AC%203%20%E9%83%A8%E5%88%86%EF%BC%8C%E5%85%B1%203%20%E9%83%A8%E5%88%86%EF%BC%89%3C%2FLI%3E%3CLI%3Eq31_t%20(Q0.31)CMSIS%20DSP%20%E5%BA%93%E5%92%8C%20MonkeyJam%20%E8%BD%AF%E4%BB%B6%E7%9A%84%E6%95%B0%E5%AD%97%E6%A0%BC%E5%BC%8F%3C%2FLI%3E%3CLI%3E%E5%90%89%E4%BB%96%E7%89%A9%E7%90%86%E5%AD%A6%E7%AE%80%E4%BB%8B%3C%2FLI%3E%3CLI%3E%E7%A0%B4%E8%A7%A3%20MonkeyJam%20%E7%9A%84%E6%80%9D%E8%B7%AF%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1742455583%22%20id%3D%22toc-hId-1742455583%22%20id%3D%22toc-hId--1630600204%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId--64998880%22%20id%3D%22toc-hId--64998880%22%20id%3D%22toc-hId-856912629%22%3E%3CSTRONG%3E%E6%AD%A5%E9%AA%A4%201%EF%BC%9A%E8%8E%B7%E5%8F%96%20FRDM-JAM%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3EFRDM-JAM%20%E7%BD%91%E7%AB%99%E4%B8%8A%E7%9A%84%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100151%22%20target%3D%22_blank%22%3EMonkeyJam%3C%2FA%3E%3C%2FSTRONG%3E%20Build%20Package%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E5%AF%B9%E9%A2%84%E7%BB%84%E8%A3%85%E7%89%88%E6%9C%AC%E6%84%9F%E5%85%B4%E8%B6%A3%EF%BC%8C%E8%AF%B7%E5%91%8A%E7%9F%A5%E6%88%91%E4%BB%AC%E3%80%82%E5%A6%82%E6%9E%9C%E6%9C%89%E8%B6%B3%E5%A4%9F%E7%9A%84%E9%9C%80%E6%B1%82%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E6%8F%90%E4%BE%9B%E4%B8%80%E4%BA%9B%E9%A2%84%E7%BB%84%E8%A3%85%E7%9A%84%E4%BA%A7%E5%93%81%E4%BE%9B%E8%B4%AD%E4%B9%B0%EF%BC%8C%E6%88%91%E5%B0%86%E5%90%AF%E5%8A%A8%20Kickstarter%EF%BC%81%E5%88%AB%E5%AE%B3%E6%80%95%E8%87%AA%E5%B7%B1%E5%8A%A8%E6%89%8B%EF%BC%8C%E7%84%8A%E6%8E%A5%E5%BE%88%E6%9C%89%E8%B6%A3%EF%BC%81%3CA%20href%3D%22https%3A%2F%2Fwww.sparkfun.com%2Ftutorials%2Fcategory%2F2%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E7%BD%91%E4%B8%8A%E6%9C%89%E5%BE%88%E5%A4%9A%E5%85%B3%E4%BA%8E%E5%A6%82%E4%BD%95%E8%BF%9B%E8%A1%8CSMT%E7%84%8A%E6%8E%A5%E7%9A%84%E5%A5%BD%E8%B5%84%E6%96%99%3C%2FA%3E%E3%80%82%E4%B8%80%E6%97%A6%E6%8E%8C%E6%8F%A1%E4%BA%86%E7%AA%8D%E9%97%A8%EF%BC%8C%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%B8%8A%E7%9A%84%E6%89%80%E6%9C%89%E9%83%A8%E4%BB%B6%E9%83%BD%E7%9B%B8%E5%BD%93%E7%AE%80%E5%8D%95%EF%BC%8C%E6%89%80%E6%9C%89%E4%B8%9C%E8%A5%BF%E9%83%BD%E5%8F%AF%E4%BB%A5%E6%89%8B%E5%B7%A5%E7%84%8A%E6%8E%A5%EF%BC%8C%E5%85%B3%E9%94%AE%E6%98%AF%E8%A6%81%E6%9C%89%E4%B8%80%E4%BA%9B%E5%90%88%E9%80%82%E7%9A%84%E5%B7%A5%E5%85%B7%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1872453343%22%20id%3D%22toc-hId--1872453343%22%20id%3D%22toc-hId--950541834%22%3E%3CSTRONG%3E%E7%AC%AC%202%20%E6%AD%A5%EF%BC%9A%E6%95%B4%E5%90%88%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E5%B0%86%20FRDM-JAM%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20FRDM-K20D50%E3%80%82FRDM-K20D50%20%E9%85%8D%E6%9C%89%E5%8F%AF%E7%84%8A%E6%8E%A5%E7%9A%84%E6%AF%8D%E6%8E%A5%E5%A4%B4%EF%BC%8C%E4%BB%A5%E4%BE%BF%E8%BD%BB%E6%9D%BE%E5%88%86%E7%A6%BB%E7%94%B5%E8%B7%AF%E6%9D%BF%E3%80%82%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E4%BB%8E%20Rev%20Gamma%EF%BC%88%E5%BD%93%E5%89%8D%E7%89%88%E6%9C%AC%EF%BC%89%E5%BC%80%E5%A7%8B%EF%BC%8C%E5%8F%AF%E4%BB%A5%E8%BF%9E%E6%8E%A5%E5%88%B0%20K64F%E3%80%82%E8%BD%AF%E4%BB%B6%E5%B0%9A%E6%9C%AA%E5%AE%8C%E5%85%A8%E5%AE%8C%E5%96%84%EF%BC%8C%E4%BD%86%E7%A1%AC%E4%BB%B6%E8%BF%9E%E6%8E%A5%E5%B7%B2%E7%BB%8F%E5%8F%AF%E7%94%A8%E3%80%82%E5%A6%82%E6%9E%9C%E4%BD%A0%E4%B8%8D%E7%A1%AE%E5%AE%9A%EF%BC%8C%E5%9D%9A%E6%8C%81%E4%BD%BF%E7%94%A8%20FRDM-K20D50%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-615059490%22%20id%3D%22toc-hId-615059490%22%20id%3D%22toc-hId-1536970999%22%3E%3CSTRONG%3E%E6%AD%A5%E9%AA%A43%EF%BC%9A%E4%B8%8B%E8%BD%BD%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E4%BB%8E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fehughes%2FMonkeyJam%2Freleases%2Ftag%2FR0%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22font-size%3A%2015.555556297302246px%3B%20text-align%3A%20center%3B%22%20target%3D%22_blank%22%3EGithub%3C%2FA%3E%E4%B8%8B%E8%BD%BD%E7%A4%BA%E4%BE%8B%E8%BD%AF%E4%BB%B6%E3%80%82%E8%A7%86%E9%A2%91%3CSTRONG%3E%E2%80%9C%E5%8A%A0%E8%BD%BD%E5%92%8C%E9%85%8D%E7%BD%AE%20MonkeyJam%20%E7%A4%BA%E4%BE%8B%E8%BD%AF%E4%BB%B6%E2%80%9D%3C%2FSTRONG%3E%E5%B0%86%E5%BC%95%E5%AF%BC%E6%82%A8%E4%B8%8B%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%B9%B6%E8%BF%9B%E8%A1%8C%E4%B8%80%E4%BA%9B%E5%9F%BA%E6%9C%AC%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1192394973%22%20id%3D%22toc-hId--1192394973%22%20id%3D%22toc-hId--270483464%22%3E%3CSTRONG%3E%E6%AD%A5%E9%AA%A4%204%EF%BC%9A%E7%A0%8D%E6%9D%80%EF%BC%81%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%8F%92%E5%85%A5%E5%B9%B6%E5%8D%A1%E4%BD%8F%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1295117860%22%20id%3D%22toc-hId-1295117860%22%20id%3D%22toc-hId--2077937927%22%3E%3CSTRONG%3E%E5%A3%B0%E9%9F%B3%E6%A0%B7%E6%9C%AC%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%AF%8F%E4%B8%AA%E5%A3%B0%E9%9F%B3%E6%A0%B7%E6%9C%AC%E9%83%BD%E6%98%AF%E6%88%91%E7%9A%84%20Carvin%20Ultra-V%20%E5%90%89%E4%BB%96%E7%9B%B4%E6%8E%A5%E6%8F%92%E5%85%A5%20MonkeyJam%20Board%E3%80%82%E8%BE%93%E5%87%BA%E8%A2%AB%E9%A6%88%E9%80%81%E5%88%B0%20Zoom%20Handy%20Recorder%20H4n%EF%BC%88%E6%84%9F%E8%B0%A2%20Remodulate%20LLC%20%E7%9A%84%20Brandin%20Claar%20%E6%8F%90%E4%BE%9B%E5%BD%95%E9%9F%B3%E6%9C%BA%EF%BC%89%E3%80%82H4N%20%E4%BB%A5%2044.1KHz%20%E9%87%87%E6%A0%B7%E7%8E%87%20%4016%20%E4%BD%8D%E8%AE%B0%E5%BD%95%E4%BF%A1%E5%8F%B7%E3%80%82%E5%A3%B0%E9%9F%B3%E6%96%87%E4%BB%B6%E9%80%9A%E8%BF%87%20Goldwave%20%E8%BD%AC%E6%8D%A2%E4%B8%BA%E5%8D%95%E5%A3%B0%E9%81%93%E6%A0%BC%E5%BC%8F%E3%80%82%E6%B2%A1%E6%9C%89%E6%89%A7%E8%A1%8C%E4%BB%BB%E4%BD%95%E5%A4%84%E7%90%86%EF%BC%88%E9%99%A4%E4%BA%86%E5%A2%9E%E5%8A%A0%E6%96%87%E4%BB%B6%E9%9F%B3%E9%87%8F%E4%B9%8B%E5%A4%96%EF%BC%89%E3%80%82%E6%88%91%E9%80%9A%E8%BF%87%20H4N%20%E4%B8%8A%E7%9A%84%E7%BA%BF%E8%B7%AF%E8%BE%93%E5%87%BA%E5%AE%9E%E6%97%B6%E6%94%B6%E5%90%AC%E5%BD%95%E9%9F%B3%E3%80%82%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22TestSetup.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22TestSetup.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45923iEE08F05B00376700%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22TestSetup.jpg%22%20alt%3D%22TestSetup.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ETestSetup.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20class%3D%22jiveBorder%22%20height%3D%221273%22%20jive-data-cell%3D%22%7B%22%20color%3D%22%22%3E%3CTBODY%3E%3CTR%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%204px%3B%20vertical-align%3A%20middle%3B%22%20valign%3D%22middle%22%3E%3CSTRONG%3E%E6%96%87%E4%BB%B6%EF%BC%88%E8%A7%81%E9%99%84%E4%BB%B6%EF%BC%89%3C%2FSTRONG%3E%3C%2FTH%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%204px%3B%20vertical-align%3A%20middle%3B%22%20valign%3D%22middle%22%3E%3CSTRONG%3E%E8%A1%A5%E4%B8%81%3C%2FSTRONG%3E%3C%2FTH%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%204px%3B%20vertical-align%3A%20middle%3B%22%20valign%3D%22middle%22%3E%3CSTRONG%3E%E8%AF%B4%E6%98%8E%3C%2FSTRONG%3E%3C%2FTH%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3ESTE-003-%E9%A2%88%E9%83%A8-a12b12g12-mlike.wav%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%2038px%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%3CSTRONG%3E%E8%B4%B4%E7%89%87%E7%AE%A1%E6%B8%85%E6%B4%81%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%E9%A2%88%E9%83%A8%E6%8B%BE%E9%9F%B3%E5%99%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%98%BF%E5%B0%94%E6%B3%95%E9%94%85%20-%2012%E7%82%B9%E9%B8%A1%3C%2FP%3E%3CP%3EBeta%20Pot%20-%2012%20O'Cock%3C%2FP%3E%3CP%3EGamma%20Pot%20-%2012%20O'Cock%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%B1%BB%E4%BC%BC%E4%BA%8E%20Metallica%20Sanitarium%20%E7%9A%84%E5%9B%BE%E6%A1%88%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3ESTE-005-%E9%A2%88%E9%83%A8-a7b5g5-mlike.wav%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%2038px%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%3CSTRONG%3E%E8%B4%B4%E7%89%87%E7%AE%A1%E6%B8%85%E6%B4%81%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3E%3CTABLE%20border%3D%221%22%20class%3D%22jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20width%3A%20100%25%3B%22%3E%3CTBODY%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%E9%A2%88%E9%83%A8%E6%8B%BE%E9%9F%B3%E5%99%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAlpha%20Pot%20-%207%20O'Cock%3C%2FP%3E%3CP%3EBeta%20Pot%20-%205%20O'Cock%3C%2FP%3E%3CP%3EGamma%20Pot%20-%205%20O'Cock%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%B1%BB%E4%BC%BC%E4%BA%8E%20Metallica%20Sanitarium%20%E7%9A%84%E5%9B%BE%E6%A1%88%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3ESTE-006-%E9%A2%88%E9%83%A8-a12b7g5-mlike.wav%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%2038px%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%3CSTRONG%3E%E8%B4%B4%E7%89%87%E7%AE%A1%E6%B8%85%E6%B4%81%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3E%3CTABLE%20border%3D%221%22%20class%3D%22jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20width%3A%20100%25%3B%22%3E%3CTBODY%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%E9%A2%88%E9%83%A8%E6%8B%BE%E9%9F%B3%E5%99%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%98%BF%E5%B0%94%E6%B3%95%E9%94%85%20-%2012%E7%82%B9%E9%B8%A1%3C%2FP%3E%3CP%3EBeta%20Pot%20-%207%20O'Cock%3C%2FP%3E%3CP%3EGamma%20Pot%20-%205%20O'Cock%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%B1%BB%E4%BC%BC%E4%BA%8E%20Metallica%20Sanitarium%20%E7%9A%84%E5%9B%BE%E6%A1%88%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3ESTE-007-%E7%90%B4%E9%A2%88-%E5%90%84%E7%A7%8D%E8%AE%BE%E7%BD%AE-dg-em_strum.wav%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%2038px%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%3CSTRONG%3E%E8%B4%B4%E7%89%87%E7%AE%A1%E6%B8%85%E6%B4%81%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%E9%A2%88%E9%83%A8%E6%8B%BE%E9%9F%B3%E5%99%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E4%BA%9B%E7%BD%90%E5%AD%90%E5%9C%A8%E6%95%B4%E4%B8%AA%E6%96%87%E4%BB%B6%E4%B8%AD%E8%A2%AB%E7%A7%BB%E5%8A%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BC%B9%E5%A5%8F%20D%20%E5%A4%A7%E8%B0%83%E3%80%81G%20%E5%A4%A7%E8%B0%83%E5%92%8C%20E%20%E5%B0%8F%E8%B0%83%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3ESTE-008-%E7%90%B4%E9%A2%88%2B%E7%90%B4%E6%A1%A5-%E5%90%84%E7%A7%8D%E8%AE%BE%E7%BD%AE-dg-em_strum.wav%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%2038px%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%3CSTRONG%3E%E8%B4%B4%E7%89%87%E7%AE%A1%E6%B8%85%E6%B4%81%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%E7%90%B4%E9%A2%88%2B%E7%90%B4%E6%A1%A5%E6%8B%BE%E9%9F%B3%E5%99%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E4%BA%9B%E7%BD%90%E5%AD%90%E5%9C%A8%E6%95%B4%E4%B8%AA%E6%96%87%E4%BB%B6%E4%B8%AD%E8%A2%AB%E7%A7%BB%E5%8A%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BC%B9%E5%A5%8F%20D%20%E5%A4%A7%E8%B0%83%E3%80%81G%20%E5%A4%A7%E8%B0%83%E5%92%8C%20E%20%E5%B0%8F%E8%B0%83%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3ESTE-009-%E6%A1%A5%E6%8E%A5-%E5%90%84%E7%A7%8D%E8%AE%BE%E7%BD%AE-dg-em_strum.wav%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%2038px%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%3CSTRONG%3E%E8%B4%B4%E7%89%87%E7%AE%A1%E6%B8%85%E6%B4%81%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%E7%90%B4%E6%A1%A5%20%2B%20%E7%90%B4%E6%A1%A5%E6%8B%BE%E9%9F%B3%E5%99%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E4%BA%9B%E7%BD%90%E5%AD%90%E5%9C%A8%E6%95%B4%E4%B8%AA%E6%96%87%E4%BB%B6%E4%B8%AD%E8%A2%AB%E7%A7%BB%E5%8A%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BC%B9%E5%A5%8F%20D%20%E5%A4%A7%E8%B0%83%E3%80%81G%20%E5%A4%A7%E8%B0%83%E5%92%8C%20E%20%E5%B0%8F%E8%B0%83%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3ESTE-010-%E9%A2%88%E9%83%A8-%E5%90%84%E7%A7%8D%E8%AE%BE%E7%BD%AE-Jammy.wav%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%2038px%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%3CSTRONG%3E%E8%B4%B4%E7%89%87%E7%AE%A1%E6%B8%85%E6%B4%81%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%E7%90%B4%E9%A2%88%2B%E7%90%B4%E6%A1%A5%E6%8B%BE%E9%9F%B3%E5%99%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E4%BA%9B%E7%BD%90%E5%AD%90%E5%9C%A8%E6%95%B4%E4%B8%AA%E6%96%87%E4%BB%B6%E4%B8%AD%E8%A2%AB%E7%A7%BB%E5%8A%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EB%E5%B0%8F%E8%B0%83%E5%8D%B3%E5%85%B4%E6%BC%94%E5%A5%8F%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3ESTE-011-%20%E6%A1%A5%E6%8E%A5%20-%20%E5%90%84%E7%A7%8D%E8%AE%BE%E7%BD%AE%20-%20%E5%BC%80%E5%85%B3%E6%BC%94%E7%A4%BA-RandomDroppedD.wav%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%2038px%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%3CSTRONG%3EPATCH_OVERDRIVE%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%E6%A1%A5%E6%8E%A5%E6%8B%BE%E9%9F%B3%E5%99%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%98%BF%E5%B0%94%E6%B3%95%E9%94%85%20-%205%20O'Cock%3C%2FP%3E%3CP%3EBeta%20Pot%20-%2012%20O'Cock%3C%2FP%3E%3CP%3EGamma%20Pot%20-%2012%20O'Cock%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9A%8F%E6%9C%BA%E6%8E%89%E8%90%BD%E7%9A%84%20D%20%E6%91%86%E5%BC%84%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3ESTE-012-%20%E9%A2%88%E9%83%A8%20-%20%E5%90%84%E7%A7%8D%E8%AE%BE%E7%BD%AE%20-%20%E5%BC%80%E5%85%B3%20Demo-Jammy.wav%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%2038px%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%3CSTRONG%3EPATCH_OVERDRIVE%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%E9%A2%88%E9%83%A8%E6%8B%BE%E9%9F%B3%E5%99%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%98%BF%E5%B0%94%E6%B3%95%E9%94%85%20-%205%20O'Cock%3C%2FP%3E%3CP%3EBeta%20Pot%20-%207%20O'Cock%3C%2FP%3E%3CP%3EGamma%20Pot%20-%207%20O'Cock%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9A%8F%E6%9C%BA%E7%9A%84%20B%20%E5%B0%8F%E8%B0%83%E6%97%8B%E5%BE%8B%EF%BC%88%E5%B8%83%E9%B2%81%E6%96%AF%E9%A3%8E%E6%A0%BC%EF%BC%89%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%3CSTRONG%3EPATCH_OVERDRIVE%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20jive_macro_code%20_jivemacro_uid_14106251056281574%22%20jivemacro_uid%3D%22_14106251056281574%22%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E4%BF%A1%E5%8F%B7%E8%BE%93%E5%85%A5%20%7C%20IIR%20%E5%8F%8C%E4%BA%8C%E9%98%B6%20%7C%20%7C%20%E7%A1%AC%E8%BF%87%E8%BD%BD%20%7C%20%7C%20IIR%20%E5%8F%8C%E4%BA%8C%E9%98%B6%20%7C%20%E4%BF%A1%E5%8F%B7%E8%BE%93%E5%87%BA%3C%2FP%3E%0A%3CP%3E%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%26gt%3B%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%26gt%3B%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%26gt%3B%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%26gt%3B%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%7C%20%5B%E5%B3%B0%E5%80%BC%E5%9D%87%E8%A1%A1%E5%99%A8%5D%20%7C%20%7C%20%5Batan24pi%20%E6%9F%A5%E6%89%BE%E8%A1%A8%5D%20%7C%20%7C%20%5B%E4%BD%8E%E9%80%9A%E6%BB%A4%E6%B3%A2%E5%99%A8%5D%20%7C%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E0.1%20%26lt%3B%20Q%20%26lt%3B%201.5%20%5B%E5%BA%95%E6%B1%A0%E9%98%BF%E5%B0%94%E6%B3%95%5D%20Q%20%3D%200%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E50%20%26lt%3B%20Fs%20%26lt%3B%20750%20%5B%E7%94%B5%E4%BD%8D%E8%AE%A1%E4%BC%BD%E9%A9%AC%5D%20Fs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lt%3B%20dbGain%20%26lt%3B%2020%20%5B%E5%BA%95%E6%B1%A0%20Beta%5D%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%E8%B4%B4%E7%89%87%E7%AE%A1%E6%B8%85%E6%B4%81%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14106251056075068%20jive_text_macro%20jive_macro_code%22%20jivemacro_uid%3D%22_14106251056075068%22%3E%0A%3CP%3E%E2%80%89%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E4%BF%A1%E5%8F%B7%E8%BE%93%E5%85%A5%20%7C%20IIR%20%E5%8F%8C%E4%BA%8C%E9%98%B6%20%7C%20%7C%20%E8%BD%AF%E8%BF%87%E8%BD%BD%20%7C%20%7C%20IIR%20%E5%8F%8C%E4%BA%8C%E9%98%B6%20%7C%20%E4%BF%A1%E5%8F%B7%E8%BE%93%E5%87%BA%3C%2FP%3E%0A%3CP%3E%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%26gt%3B%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%26gt%3B%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%26gt%3B%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%26gt%3B%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%7C%20%5BLowShelf%5D%20%7C%20%7C%20%5Batan4pi%20%E6%9F%A5%E6%89%BE%E8%A1%A8%5D%20%7C%20%7C%20%5B%E4%BD%8E%E9%80%9A%E6%BB%A4%E6%B3%A2%E5%99%A8%5D%20%7C%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E0.05%20%26lt%3B%20Q%20%26lt%3B%202.58%20%5B%E5%BA%95%E6%B1%A0%E9%98%BF%E5%B0%94%E6%B3%95%5D%20Q%20%3D%202.0%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E1000%20%26lt%3B%20Fs%20%26lt%3B%204000%20%5B%E5%BA%95%E6%B1%A0%20Beta%5D%20Fs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lt%3B%20dbGain%20%26lt%3B%2015%20%5B%E7%94%B5%E4%BD%8D%E5%99%A8%E4%BC%BD%E7%8E%9B%5D%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%20%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--764600942%22%20id%3D%22toc-hId--764600942%22%20id%3D%22toc-hId-157310567%22%3E%3CSTRONG%3E%E5%85%AC%E7%94%A8%E8%AE%BE%E6%96%BD%E7%AD%89%EF%BC%9A%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100240%22%20target%3D%22_blank%22%3E%E5%8F%8C%E4%BA%8C%E9%98%B6%E6%BB%A4%E6%B3%A2%E5%99%A8%E8%A7%86%E5%9B%BE%20-%20IIR%20%E5%8F%8C%E4%BA%8C%E9%98%B6%E6%BB%A4%E6%B3%A2%E5%99%A8%E8%AE%BE%E8%AE%A1%E5%92%8C%E5%8F%AF%E8%A7%86%E5%8C%96%E5%B7%A5%E5%85%B7%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1120736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%AD%A6%E7%94%9F%E9%A1%B9%E7%9B%AE%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20HIT%20%E9%A1%B9%E7%9B%AE%20%231%EF%BC%9AMonkeyJam%20-%20DIY%20%E5%90%89%E4%BB%96%E6%95%88%E6%9E%9C%E5%99%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Eli%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%AE%9E%E7%8E%B0%E4%BA%86%20CMSIS%20%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%B9%9F%E4%B8%BA%E5%85%B6%E4%BB%96%E4%BA%BA%E5%88%B6%E4%BD%9C%E4%BA%86%E6%96%87%E6%A1%A3%EF%BC%8C%E8%AF%B7%E6%A3%80%E6%9F%A5%E8%BF%87%E7%A8%8B%E4%B8%AD%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E9%94%99%E8%AF%AF%E5%B9%B6%E8%BF%9B%E8%A1%8C%E6%9B%B4%E6%96%B0%E3%80%82%3CA%20_jive_internal%3D%22true%22%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F414670%23414670%22%20title%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F414670%23414670%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F414670%23414670%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3CP%3E%E9%98%BF%E7%B1%B3%E7%89%B9%C2%B7%E5%BA%93%E9%A9%AC%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20HIT%20%E9%A1%B9%E7%9B%AE%20%231%EF%BC%9AMonkeyJam%20-%20DIY%20%E5%90%89%E4%BB%96%E6%95%88%E6%9E%9C%E5%99%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Eli%20Hughes%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%90%91%E6%88%91%E6%8F%90%E4%BE%9B%E6%82%A8%E6%BC%94%E7%A4%BA%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20codwarrior%20%E5%AE%9E%E7%8E%B0%20CMSIS%20%E5%BA%93%E7%9A%84%E8%A7%86%E9%A2%91%E9%93%BE%E6%8E%A5%EF%BC%9F%E5%9F%BA%E6%9C%AC%E4%B8%8A%EF%BC%8C%E6%88%91%E5%85%B3%E5%BF%83%E7%9A%84%E6%98%AF%E6%82%A8%E6%89%80%E5%AE%9E%E7%8E%B0%E7%9A%84%20FFT%20%E5%BA%93%EF%BC%9F%E8%BF%99%E5%B0%86%E4%BC%9A%E6%9C%89%E5%BE%88%E5%A4%A7%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%E8%B0%A2%E8%B0%A2%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3CP%3E%E9%98%BF%E7%B1%B3%E7%89%B9%C2%B7%E5%BA%93%E9%A9%AC%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20HIT%20%E9%A1%B9%E7%9B%AE%20%231%EF%BC%9AMonkeyJam%20-%20DIY%20%E5%90%89%E4%BB%96%E6%95%88%E6%9E%9C%E5%99%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Eli%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%E5%BD%93%E6%88%91%E7%AC%AC%E4%B8%80%E6%AC%A1%E6%89%93%E5%BC%80%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E6%97%B6%EF%BC%8C%E6%88%91%E6%94%B6%E5%88%B0%E4%B8%80%E4%BA%9B%E8%AD%A6%E5%91%8A%E4%BF%A1%E6%81%AF%E3%80%82%E8%BF%99%E6%9D%A1%E6%B6%88%E6%81%AF%E5%80%BC%E5%BE%97%E5%85%B3%E6%B3%A8%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cmp.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cmp.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F44411i3CC3C997C596F267%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22cmp.jpg%22%20alt%3D%22cmp.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ecmp.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3CP%3E%E9%98%BF%E7%B1%B3%E7%89%B9%C2%B7%E5%BA%93%E9%A9%AC%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120740%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20HIT%20%E9%A1%B9%E7%9B%AE%20%231%EF%BC%9AMonkeyJam%20-%20DIY%20%E5%90%89%E4%BB%96%E6%95%88%E6%9E%9C%E5%99%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120740%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EAmit%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%8D%95%E5%87%BB%E5%BA%93%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%B1%9E%E6%80%A7%E5%B9%B6%E6%9F%A5%E7%9C%8B%E5%A4%84%E7%90%86%E5%99%A8%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%88%99%E4%BC%9A%E5%8F%91%E7%8E%B0%202%20%E4%B8%AA%E7%AC%A6%E5%8F%B7%EF%BC%88ARM_CM4%20%E5%92%8C%20ARM_ROUNDING%EF%BC%89%E3%80%82%E8%BF%99%E5%B0%B1%E6%98%AF%E6%88%91%E4%B8%BA%E4%BA%86%E7%BC%96%E8%AF%91%E6%89%80%E8%A6%81%E5%81%9A%E7%9A%84%E5%85%A8%E9%83%A8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E6%88%91%E5%9C%A8%E5%85%B6%E4%B8%AD%E4%B8%80%E4%B8%AA%E8%A7%86%E9%A2%91%E4%B8%AD%E8%AE%B2%E8%BF%87%E8%BF%99%E4%B8%AA%E3%80%82%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%E7%9A%84%E8%AF%9D%EF%BC%8C%E6%88%91%E8%82%AF%E5%AE%9A%E5%BE%97%E4%B8%BA%E5%AE%83%E5%88%B6%E4%BD%9C%E4%B8%80%E4%BA%9B%E5%B0%8F%E8%A7%86%E9%A2%91%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-Eli%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20HIT%20%E9%A1%B9%E7%9B%AE%20%231%EF%BC%9AMonkeyJam%20-%20DIY%20%E5%90%89%E4%BB%96%E6%95%88%E6%9E%9C%E5%99%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20_jive_internal%3D%22true%22%20class%3D%22jiveTT-hover-user%20jive-link-profile-small%22%20data-containerid%3D%22-1%22%20data-containertype%3D%22-1%22%20data-content-finding%3D%22Community%22%20data-objectid%3D%2238030%22%20data-objecttype%3D%223%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Feli_hughes%22%20target%3D%22_blank%22%3EEli%20Hughes%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%AF%BC%E5%85%A5%E4%BA%86%20MonkeyListen%20%E9%A1%B9%E7%9B%AE%E5%B9%B6%E4%B8%94%E5%AE%83%E7%BC%96%E8%AF%91%E6%88%90%E5%8A%9F%E4%BA%86%EF%BC%8C%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E9%94%99%E8%AF%AF%E3%80%82%E7%8E%B0%E5%9C%A8%E6%88%91%E7%9A%84%E6%B5%8B%E8%AF%95%E7%9B%AE%E6%A0%87%E6%98%AFFRDM-K20D50M%EF%BC%88MK20DX128%EF%BC%89%E3%80%82%E6%AD%A4%E5%90%8E%E6%88%91%E5%B0%86%E4%BB%A5%20mk60fn1m0vlq12%20%E4%B8%BA%E7%9B%AE%E6%A0%87%E3%80%82%E5%9C%A8%E4%BB%BB%E4%BD%95%E9%A1%B9%E7%9B%AE%E4%B8%AD%E4%BD%BF%E7%94%A8%E8%AF%A5%E5%BA%93%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E5%93%AA%E4%BA%9B%E8%AE%BE%E7%BD%AE%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%8F%90%E4%BE%9B%E4%BD%BF%E5%85%B6%E5%B7%A5%E4%BD%9C%E6%89%80%E9%9C%80%E7%9A%84%E4%B8%80%E4%BA%9B%E8%AE%BE%E7%BD%AE%E5%BF%AB%E7%85%A7%EF%BC%8C%E8%BF%99%E5%B0%86%E5%AF%B9%E6%89%80%E6%9C%89%E7%A4%BE%E5%8C%BA%E6%88%90%E5%91%98%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%E5%BD%93%E6%88%91%E9%81%87%E5%88%B0%E4%B8%80%E4%BA%9B%E5%85%B3%E4%BA%8E%E6%AD%A4%E9%97%AE%E9%A2%98%E5%B0%9A%E6%9C%AA%E5%BE%97%E5%88%B0%E8%A7%A3%E7%AD%94%E7%9A%84%E9%97%AE%E9%A2%98%E6%97%B6%E3%80%82%E5%9C%A8%20ARM%20%E7%9A%84%E7%BD%91%E7%AB%99%E4%B8%8A%E6%88%91%E4%B9%9F%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E6%9C%89%E5%85%B3%E6%AD%A4%E9%97%AE%E9%A2%98%E7%9A%84%E4%BB%BB%E4%BD%95%E5%B8%AE%E5%8A%A9%E3%80%82%E5%BD%93%E6%88%91%E7%9C%8B%E5%88%B0%E6%82%A8%E7%9A%84%E6%95%99%E7%A8%8B%E6%97%B6%EF%BC%8C%E4%B8%80%E5%88%87%E9%83%BD%E8%A7%A3%E9%87%8A%E5%BE%97%E5%BE%88%E6%B8%85%E6%A5%9A%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%85%B6%E4%B8%AD%E4%B9%9F%E6%B6%B5%E7%9B%96%E4%BA%86%E8%BF%99%E4%B8%80%E9%83%A8%E5%88%86%EF%BC%8C%E9%82%A3%E4%B9%88%E5%AF%B9%E4%BA%8E%E5%83%8F%E6%88%91%E8%BF%99%E6%A0%B7%E7%9A%84%E4%BA%BA%E6%9D%A5%E8%AF%B4%E5%B0%86%E4%BC%9A%E6%9C%89%E5%BE%88%E5%A4%A7%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%E8%80%8C%E4%B8%94%E6%88%91%E7%9B%B8%E4%BF%A1%E5%BE%88%E5%A4%9A%E4%BA%BA%E9%83%BD%E6%83%B3%E4%BD%BF%E7%94%A8%E5%AE%83%EF%BC%8C%E4%BD%86%E7%94%B1%E4%BA%8E%E8%BF%99%E4%B8%AA%E5%AE%9E%E7%8E%B0%E9%83%A8%E5%88%86%E8%80%8C%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%8F%90%E5%89%8D%E8%87%B4%E8%B0%A2%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3CP%3E%E9%98%BF%E7%B1%B3%E7%89%B9%C2%B7%E5%BA%93%E9%A9%AC%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120738%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20HIT%20%E9%A1%B9%E7%9B%AE%20%231%EF%BC%9AMonkeyJam%20-%20DIY%20%E5%90%89%E4%BB%96%E6%95%88%E6%9E%9C%E5%99%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120738%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EAmit%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E5%B0%9D%E8%AF%95%E5%AF%BC%E5%85%A5%20MonkeyListen%20%E9%A1%B9%E7%9B%AE%E5%B9%B6%E6%9F%A5%E7%9C%8B%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E8%AE%BE%E7%BD%AE%EF%BC%9F%E6%82%A8%E9%92%88%E5%AF%B9%E7%9A%84%E6%98%AF%E5%93%AA%E7%A7%8D%E8%8A%AF%E7%89%87%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20HIT%20%E9%A1%B9%E7%9B%AE%20%231%EF%BC%9AMonkeyJam%20-%20DIY%20%E5%90%89%E4%BB%96%E6%95%88%E6%9E%9C%E5%99%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Feli_hughes%22%20target%3D%22_blank%22%3Eeli_hughes%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E7%B2%BE%E5%BD%A9%E6%95%99%E7%A8%8B%E3%80%82%E5%AE%83%E5%87%A0%E4%B9%8E%E5%B1%95%E7%A4%BA%E4%BA%86%20DSP%20%E7%9A%84%E5%AE%9E%E9%99%85%E5%AE%9E%E7%8E%B0%E3%80%82%E6%88%91%E6%83%B3%E9%97%AE%E6%82%A8%E6%9C%89%E5%85%B3%E5%9C%A8%20codewarrior%20%E4%B8%AD%E5%AE%9E%E7%8E%B0%20CMSIS%20%E5%BA%93%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E5%9C%A8%E6%88%91%E7%9A%84%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E6%88%91%E6%83%B3%E5%AE%9E%E7%8E%B0%20DSP%20%E5%BA%93%E6%9D%A5%E5%AE%9E%E7%8E%B0%20FFT%E3%80%82%E4%BD%86%E6%88%91%E5%9C%A8%E5%AE%9E%E7%8E%B0%20CMSIS%20%E5%BA%93%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E5%9B%B0%E9%9A%BE%E3%80%82%E6%88%91%E7%9C%8B%E4%BA%86%E4%BD%A0%E7%9A%84%E8%A7%86%E9%A2%91%E4%BB%A5%E5%8F%8A%E7%AC%AC%E4%BA%8C%E4%B8%AA%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%8D%B3%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-99621%23jive_content_id_Project_2_Monkey_Listen_Audio_Spectrum_Analyzer_Display%22%20target%3D%22_blank%22%3E%E9%A1%B9%E7%9B%AE%EF%BC%832%EF%BC%9A%E7%8C%B4%E5%AD%90%E5%90%AC%EF%BC%81%E9%9F%B3%E9%A2%91%E9%A2%91%E8%B0%B1%E5%88%86%E6%9E%90%E4%BB%AA%E6%98%BE%E7%A4%BA%3C%2FA%3E%EF%BC%8C%E4%B9%9F%E9%9D%9E%E5%B8%B8%E6%A3%92%E3%80%82%E4%BD%86%E6%98%AF%E6%88%91%E6%97%A0%E6%B3%95%E7%BB%A7%E7%BB%AD%E5%89%8D%E8%BF%9B%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E5%9C%A8%E5%AE%9E%E7%8E%B0%E5%BA%93%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E9%98%85%E8%AF%BB%E4%BA%86%E4%B8%80%E4%BA%9B%E5%85%B3%E4%BA%8E%E5%AE%9E%E7%8E%B0%20CMSIS%20%E5%BA%93%E7%9A%84%E5%B8%96%E5%AD%90%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E7%BC%96%E8%AF%91%E5%B9%B6%E4%B8%94%E7%BB%99%E5%87%BA%E4%BA%86%E9%94%99%E8%AF%AF%E3%80%82%E6%9C%89%E6%97%B6%E4%BC%9A%E8%B6%85%E5%87%BA%20m-text%20%E9%99%90%E5%88%B6%E3%80%82%E6%88%91%E6%B5%8F%E8%A7%88%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fmcuoneclipse.com%2F2013%2F02%2F14%2Ftutorial-using-the-arm-cmsis-library%2F%22%20title%3D%22http%3A%2F%2Fmcuoneclipse.com%2F2013%2F02%2F14%2Ftutorial-using-the-arm-cmsis-library%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E6%95%99%E7%A8%8B%EF%BC%9A%E5%9C%A8%20Eclipse%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20ARM%20CMSIS%20%E5%BA%93%20%7C%20MCU%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F320772%22%20target%3D%22_blank%22%3E%E6%B7%BB%E5%8A%A0%20CMSIS-DSP%20%E5%BA%93%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-98638%22%20target%3D%22_blank%22%3E%E7%A7%BB%E6%A4%8DCMSIS-DSP%E5%BA%93%E5%88%B0CodeWarrior%E7%9A%84%E6%AD%A5%E9%AA%A4%E4%BB%A5%E5%8F%8AKinetis%20FPU%E5%8D%95%E5%85%83%E5%BA%94%E7%94%A8%E7%9A%84%E5%AF%B9%E6%AF%94%3C%2FA%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E8%B0%83%E6%9F%A5%E6%AD%A4%E4%BA%8B%E3%80%82%E6%88%91%E5%B8%8C%E6%9C%9B%E8%BF%99%E7%AF%87%E6%96%87%E7%AB%A0%E8%83%BD%E5%A4%9F%E5%AF%B9%E8%AE%B8%E5%A4%9A%E7%A4%BE%E5%8C%BA%E7%94%A8%E6%88%B7%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%E6%8F%90%E5%89%8D%E8%87%B4%E8%B0%A2%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3CP%3E%E9%98%BF%E7%B1%B3%E7%89%B9%C2%B7%E5%BA%93%E9%A9%AC%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-10-2020 02:48 AM
更新人:
