Freescale H.I.T. Project #1: MonkeyJam - A DIY Guitar Stomp Box
Project Summary
SheldonJam.pngMonkeyJam will use the FRDM-K20D50 board (which has a Cortex M4 core with DSP instructions) along with the FRDM-JAM shield so you can  make your very
own guitar /bass  stomp box.  The end result will be a functional DSP system that will allow you to do high quality amplifier simulation and effects.
The FRDM-JAM does not limit you to DSP on musical instruments!  There are 3.5mm stereo jacks to DSP filtering any type of audio signal.    You could even use the USB interface to create a USB-MIDI Synthesizer!  Lastly,  no need to bring the house down.....  a headphone amplifier circuit is provided so you can jam out without bothering the neighbors.
MBED Support coming *very soon*
Skills Developed:
  • Real Time Processing
  • DSP Algorithms
  • Fixed Point Mathematics
  • 24-bit I2S Data Converter Interfacing
  • Soldering SOIC8 and 1206 Surface mount devices
  • Cortex CMSIS DSP Library
Materials:
FRDM-K20D50
FRDM-JAM
Development Tools
Install Codewarrior 10.5 for Microcontrollers (Eclipse) Special Edition to your  machine
Example Code
Get the latest copy from Github
Step 0: Prerequisite Videos
The videos are organized into a nice YouTube playlist:
H.I.T 1: Monkey Jam - YouTube
https://www.youtube.com/playlist?list=PLWM8NW5LEukgM-D5eRMtKZ8R2WfXnqKGp
  • MonkeyJam Watch Me 1st
  • FRDM-JAM Hardware Overview
  • MonkeyJam Software Overview
  • Introduction to Fixed Point Math for Embedded Systems - Part 1 of 3
  • Introduction to Fixed Point Math for Embedded Systems - Part 2 of 3
  • Introduction to Fixed Point Math for Embedded Systems - Part 3 of 3
  • Real Time Signal Processing Part 1 of 3
  • Real Time Signal Processing Part 2 of 3
  • Real Time Signal Processing Part 3 of 3
  • q31_t (Q0.31) Number Format for the CMSIS DSP Libraries and the MonkeyJam Software
  • Guitar physics in a nutshell
  • Ideas for hacking the MonkeyJam
Step 1: Get a FRDM-JAM
MonkeyJam Build Package on the FRDM-JAM site.    Please let us know if you are interested in a pre-assembled version.  If there is enough demand we will get some preassembled for purchase, I will get a Kickstarter going!   Don't be afraid to build it yourself,  Soldering is fun!  There is plenty of good stuff on the web on how to do SMT soldering.  All of the parts on the board are fairly simply once you get the hang of it and everything can be hand soldered  The key is having some decent tools.
Step 2: Put it Together
Attach the FRDM-JAM to the FRDM-K20D50.  The FRDM-K20D50 comes with female headers that you can solder on so the boards can be easily separated.  Note that as of Rev Gamma (current version),   it is possible to connect to a K64F.    The software isn't quite there but it hardware connections are available.   If you are unsure,  stick with the FRDM-K20D50
Step 3: Download
Download the Example Software from Github.  The video "Loading and Configuring the MonkeyJam Example Software" will step you though downloading the program and doing some basic configuration.
Step 4: Hack and Slash!
Plug In and jam!
Sound Samples
Each sound sample was my Carvin Ultra-V guitar plugged direct into the MonkeyJam Board.  The output was fed to a Zoom Handy Recorder H4n (Thanks to Brandin Claar of Remodulate LLC for the recorder).  The H4N recorded the signal at 44.1KHz Sample rate @16-bit.  The sound files were converted to mono format via Goldwave.  No processing (other than a  volume boost on the files) was performed.   I listen to the recording in real-time via a line out on the H4N.
File (See Attachments)PatchNotes
STE-003-Neck-a12b12g12-mlike.wav
PATCH_TUBEY_CLEAN
Neck Pickup
Alpha Pot - 12 O'Cock
Beta Pot - 12 O'Cock
Gamma Pot - 12 O'Cock
Pattern Similar to Metallica Sanitarium
STE-005-Neck-a7b5g5-mlike.wav
PATCH_TUBEY_CLEAN
Neck Pickup
Alpha Pot - 7 O'Cock
Beta Pot - 5 O'Cock
Gamma Pot - 5 O'Cock
STE-006-Neck-a12b7g5-mlike.wav
PATCH_TUBEY_CLEAN
Neck Pickup
Beta Pot - 7 O'Cock
STE-007-Neck-VariousSettings-d-g-em_strum.wav
PATCH_TUBEY_CLEAN
Neck Pickup
The pots were moved around throughout the file
Strummed D-Major, G-Major and E-Minor
STE-008-Neck+Bridge-VariousSettings-d-g-em_strum.wav
PATCH_TUBEY_CLEAN
Neck + Bridge Pickup
STE-009-Bridge-VariousSettings-d-g-em_strum.wav
PATCH_TUBEY_CLEAN
Bridge + Bridge Pickup
STE-010-Neck-VariousSettings-Jammy.wav
PATCH_TUBEY_CLEAN
B-Minor Type Jam
STE-011- Bridge - Various Settings - On-Off Demo-RandomDroppedD.wav
PATCH_OVERDRIVE
Bridge Pickup
Alpha Pot - 5 O'Cock
Random Dropped D twiddling
STE-012- Neck - Various Settings - On-Off Demo-Jammy.wav
PATCH_OVERDRIVE
Neck Pickup
Beta Pot - 7 O'Cock
Gamma Pot - 7 O'Cock
Random B-Minor twiddles (bluesy)
PATCH_OVERDRIVE
  Signal In  |    IIR BiQuad    |      |      Hard Overdrive      |      |      IIR BiQuad     |  Signal Out     
             |   [Peaking EQ]   |      | [atan24pi Look Up Table] |      |  [Low Pass Filter]  |                 
                 0.1 < Q < 1.5    [Pot Alpha]                                     Q = 0                          
                 50 < Fs < 750    [Pot Gamma]                                   Fs = 2000                        
               -20 < dbGain < 20  [Pot Beta]
PATCH_TUBEY_CLEAN
  Signal In  |    IIR BiQuad    |      |      Soft Overdrive      |      |      IIR BiQuad     |  Signal Out     
             |     [LowShelf]   |      | [atan4pi Look Up Table]  |      |  [Low Pass Filter]  |                 
                 0.05 < Q < 2.58   [Pot Alpha]                                     Q = 2.0                          
                1000 < Fs < 4000    [Pot Beta]                                   Fs = 2500                        
               -15 < dbGain < 15  [Pot Gamma]
Utilities, etc:
Biquad Filter View - A IIR Biquad Filter Design &amp; Visualization Tool
Comments
Hi eli_hughes
Thanks For the awesome tutorial. It pretty much shows the real life implementation of DSP. I wanted to ask you about implementation of CMSIS library in codewarrior. In one of my projects I wanted to implement DSP library to implement FFT. But I am stuck in implementing CMSIS library. I saw your Video for this as well as the 2nd project i.e Project #2: Monkey Listen! Audio Spectrum Analyzer Display That was also awesome like this. But again I cannot move further as I am facing problem in implementing the library.I went through some post regarding implementing the CMSIS library but that was not compiling and was giving errors. and sometimes was exceeding the m-text limit. I went through the following links.
Tutorial: Using the ARM CMSIS Library | MCU on Eclipse
Adding the CMSIS-DSP library
移植CMSIS-DSP库到CodeWarrior的步骤以及Kinetis FPU单元应用的对比
Please look into the matter. I hope this post will be beneficial for many community users. Thanks in advance
Kind Regards
Amit Kumar
Amit:
Do you try importing the MonkeyListen project and see the settings I used?   What chip are you targeting?
Hi Eli Hughes
I Imported the MonkeyListen Project and it got compiled without any error. right now for testing I am targeting FRDM-K20D50M (MK20DX128). After this I will be targeting mk60fn1m0vlq12. What are the settings required to be done for using the library in any project ? If you can provide some snapshot of  the settings required to make it work It will be helpful for all the community members. As I went across some queries which was unanswered regarding the same. In ARM's website also I didn't find any help regarding this. When I saw your tutorial everything was well explained. So If this portion is also covered in it than it will a great help for people like me. and I am sure many people want to use it but can't use due to this implementation part.
Thanks in advance
Kind Regards
Amit Kumar
Amit:
If you click on the project properties for the library and look at processor settings, there are 2 symbols (ARM_CM4 and ARM_ROUNDING).   This is all I had to do to get it compile.
I think I covered it in one of the videos.  If not, I will certainly have to get some sort of small video for it!.
-Eli
Hi Eli
Thanks for your reply. when I am opening your project for the 1st time I am getting some warning message. Is this message of any concern?.
Kind Regards
Amit Kumar
Hi Eli Hughes
Can you provide me the link of the video in which you have demonstrated how to implement  CMSIS library with codwarrior basically I am concerned with FFT library which you have implemented? It Will be a great help. Thanks
Kind Regards
Amit Kumar
Hi Eli
I have implemented the CMSIS code and also made the document for others , kindly look if anything is incorrect in the process and please update it. https://community.freescale.com/message/414670#414670
Kind Regards
Amit Kumar
%3CLINGO-SUB%20id%3D%22lingo-sub-1120736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFreescale%20H.I.T.%20Project%20%231%3A%20%20MonkeyJam%20-%20A%20DIY%20Guitar%20Stomp%20Box%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-H-I-T-Project-1-MonkeyJam-A-DIY-Guitar-Stomp-Box%2Fta-p%2F1120736%23toc-hId-382338843%22%20target%3D%22_blank%22%3EProject%20Summary%20%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-H-I-T-Project-1-MonkeyJam-A-DIY-Guitar-Stomp-Box%2Fta-p%2F1120736%23toc-hId--1425115620%22%20target%3D%22_blank%22%3ESkills%20Developed%3A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-H-I-T-Project-1-MonkeyJam-A-DIY-Guitar-Stomp-Box%2Fta-p%2F1120736%23toc-hId-1062397213%22%20target%3D%22_blank%22%3EMaterials%3A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-H-I-T-Project-1-MonkeyJam-A-DIY-Guitar-Stomp-Box%2Fta-p%2F1120736%23toc-hId--745057250%22%20target%3D%22_blank%22%3EStep%200%3A%20Prerequisite%20Videos%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-H-I-T-Project-1-MonkeyJam-A-DIY-Guitar-Stomp-Box%2Fta-p%2F1120736%23toc-hId--64998880%22%20target%3D%22_blank%22%3EStep%201%3A%20Get%20a%20FRDM-JAM%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-H-I-T-Project-1-MonkeyJam-A-DIY-Guitar-Stomp-Box%2Fta-p%2F1120736%23toc-hId--1872453343%22%20target%3D%22_blank%22%3EStep%202%3A%20Put%20it%20Together%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-H-I-T-Project-1-MonkeyJam-A-DIY-Guitar-Stomp-Box%2Fta-p%2F1120736%23toc-hId-615059490%22%20target%3D%22_blank%22%3EStep%203%3A%20Download%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-H-I-T-Project-1-MonkeyJam-A-DIY-Guitar-Stomp-Box%2Fta-p%2F1120736%23toc-hId--1192394973%22%20target%3D%22_blank%22%3EStep%204%3A%20Hack%20and%20Slash!%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-H-I-T-Project-1-MonkeyJam-A-DIY-Guitar-Stomp-Box%2Fta-p%2F1120736%23toc-hId-1295117860%22%20target%3D%22_blank%22%3ESound%20Samples%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FUniversity-Programs-Knowledge%2FFreescale-H-I-T-Project-1-MonkeyJam-A-DIY-Guitar-Stomp-Box%2Fta-p%2F1120736%23toc-hId--764600942%22%20target%3D%22_blank%22%3EUtilities%2C%20etc%3A%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-382338843%22%20id%3D%22toc-hId-382338843%22%20id%3D%22toc-hId-1297699180%22%3E%3CSTRONG%3EProject%20Summary%20%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SheldonJam.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SheldonJam.png%22%20style%3D%22width%3A%20450px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F43727i673ECBBD80DE86A9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SheldonJam.png%22%20alt%3D%22SheldonJam.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESheldonJam.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3EMonkeyJam%20will%20use%20the%20FRDM-K20D50%20board%20(which%20has%20a%20Cortex%20M4%20core%20with%20DSP%20instructions)%20along%20with%20the%20FRDM-JAM%20shield%20so%20you%20can%26nbsp%3B%20make%20your%20very%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3Eown%20guitar%20%2Fbass%26nbsp%3B%20stomp%20box.%26nbsp%3B%20The%20end%20result%20will%20be%20a%20functional%20DSP%20system%20that%20will%20allow%20you%20to%20do%20high%20quality%20amplifier%20simulation%20and%20effects.%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3EThe%20FRDM-JAM%20does%20not%20limit%20you%20to%20DSP%20on%20musical%20instruments!%26nbsp%3B%20There%20are%203.5mm%20stereo%20jacks%20to%20DSP%20filtering%20any%20type%20of%20audio%20signal.%26nbsp%3B%26nbsp%3B%26nbsp%3B%20You%20could%20even%20use%20the%20USB%20interface%20to%20create%20a%20USB-MIDI%20Synthesizer!%26nbsp%3B%20Lastly%2C%26nbsp%3B%20no%20need%20to%20bring%20the%20house%20down.....%26nbsp%3B%20a%20headphone%20amplifier%20circuit%20is%20provided%20so%20you%20can%20jam%20out%20without%20bothering%20the%20neighbors.%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2016px%3B%20text-align%3A%20center%3B%22%3E%3CSTRONG%20style%3D%22%3A%20%3B%20color%3A%20%23339966%3B%20font-size%3A%2012pt%3B%22%3EMBED%20Support%20coming%20*very%20soon*%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1425115620%22%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%20id%3D%22toc-hId--1425115620%22%20id%3D%22toc-hId--509755283%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSTRONG%3ESkills%20Developed%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3EReal%20Time%20Processing%3C%2FLI%3E%3CLI%3EDSP%20Algorithms%3C%2FLI%3E%3CLI%3EFixed%20Point%20Mathematics%3C%2FLI%3E%3CLI%3E24-bit%20I2S%20Data%20Converter%20Interfacing%3C%2FLI%3E%3CLI%3ESoldering%20SOIC8%20and%201206%20Surface%20mount%20devices%3C%2FLI%3E%3CLI%3ECortex%20CMSIS%20DSP%20Library%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1062397213%22%20id%3D%22toc-hId-1062397213%22%20id%3D%22toc-hId-1977757550%22%3E%3CSTRONG%3EMaterials%3A%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20class%3D%22jiveBorder%22%20height%3D%22295%22%20jive-data-cell%3D%22%7B%22%20color%3D%22%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20center%3B%22%3E%3CP%3E%3CSTRONG%3E%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DFRDM-K20D50M%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3EFRDM-K20D50%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22K20D50.PNG.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22K20D50.PNG.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F43682i2FF5CF5A87620E5E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22K20D50.PNG.png%22%20alt%3D%22K20D50.PNG.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EK20D50.PNG.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22text-align%3A%20center%3B%22%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100151%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3EFRDM-JAM%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FRDM-JAM-s.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FRDM-JAM-s.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F43281iD1AB62DA7D30F98A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FRDM-JAM-s.png%22%20alt%3D%22FRDM-JAM-s.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFRDM-JAM-s.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20center%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3EDevelopment%20Tools%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Foverview.jsp%3Fcode%3DCW_SPECIALEDITIONS%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22font-size%3A%2015.555556297302246px%3B%20text-align%3A%20center%3B%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3EInstall%20Codewarrior%2010.5%20for%20Microcontrollers%20(Eclipse)%20Special%20Edition%20to%20your%26nbsp%3B%20machine%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22text-align%3A%20center%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3EExample%20Code%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3EGet%20the%20latest%20copy%20from%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fehughes%2FMonkeyJam%2Freleases%2Ftag%2FR0%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EGithub%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--745057250%22%20id%3D%22toc-hId--745057250%22%20id%3D%22toc-hId-170303087%22%3E%3CSTRONG%3EStep%200%3A%20Prerequisite%20Videos%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EThe%20videos%20are%20organized%20into%20a%20nice%20YouTube%20playlist%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fwww.youtube.com%2Fplaylist%3Flist%3DPLWM8NW5LEukgM-D5eRMtKZ8R2WfXnqKGp%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20title%3D%22https%3A%2F%2Fwww.youtube.com%2Fplaylist%3Flist%3DPLWM8NW5LEukgM-D5eRMtKZ8R2WfXnqKGp%22%20target%3D%22_blank%22%3EH.I.T%201%3A%20Monkey%20Jam%20-%20YouTube%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fwww.youtube.com%2Fplaylist%3Flist%3DPLWM8NW5LEukgM-D5eRMtKZ8R2WfXnqKGp%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20title%3D%22https%3A%2F%2Fwww.youtube.com%2Fplaylist%3Flist%3DPLWM8NW5LEukgM-D5eRMtKZ8R2WfXnqKGp%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.youtube.com%2Fplaylist%3Flist%3DPLWM8NW5LEukgM-D5eRMtKZ8R2WfXnqKGp%3C%2FA%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3EMonkeyJam%20Watch%20Me%201st%3C%2FLI%3E%3CLI%3EFRDM-JAM%20Hardware%20Overview%3C%2FLI%3E%3CLI%3EMonkeyJam%20Software%20Overview%3C%2FLI%3E%3CLI%3EIntroduction%20to%20Fixed%20Point%20Math%20for%20Embedded%20Systems%20-%20Part%201%20of%203%3C%2FLI%3E%3CLI%3EIntroduction%20to%20Fixed%20Point%20Math%20for%20Embedded%20Systems%20-%20Part%202%20of%203%3C%2FLI%3E%3CLI%3EIntroduction%20to%20Fixed%20Point%20Math%20for%20Embedded%20Systems%20-%20Part%203%20of%203%3C%2FLI%3E%3CLI%3EReal%20Time%20Signal%20Processing%20Part%201%20of%203%3C%2FLI%3E%3CLI%3EReal%20Time%20Signal%20Processing%20Part%202%20of%203%3C%2FLI%3E%3CLI%3EReal%20Time%20Signal%20Processing%20Part%203%20of%203%3C%2FLI%3E%3CLI%3Eq31_t%20(Q0.31)%20Number%20Format%20for%20the%20CMSIS%20DSP%20Libraries%20and%20the%20MonkeyJam%20Software%3C%2FLI%3E%3CLI%3EGuitar%20physics%20in%20a%20nutshell%3C%2FLI%3E%3CLI%3EIdeas%20for%20hacking%20the%20MonkeyJam%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1742455583%22%20id%3D%22toc-hId-1742455583%22%20id%3D%22toc-hId--1637151376%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId--64998880%22%20id%3D%22toc-hId--64998880%22%20id%3D%22toc-hId-850361457%22%3E%3CSTRONG%3EStep%201%3A%20Get%20a%20FRDM-JAM%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100151%22%20target%3D%22_blank%22%3EMonkeyJam%3C%2FA%3E%3C%2FSTRONG%3E%20Build%20Package%20on%20the%20FRDM-JAM%20site.%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Please%20let%20us%20know%20if%20you%20are%20interested%20in%20a%20pre-assembled%20version.%26nbsp%3B%20If%20there%20is%20enough%20demand%20we%20will%20get%20some%20preassembled%20for%20purchase%2C%20I%20will%20get%20a%20Kickstarter%20going!%26nbsp%3B%26nbsp%3B%20Don't%20be%20afraid%20to%20build%20it%20yourself%2C%26nbsp%3B%20Soldering%20is%20fun!%26nbsp%3B%20%3CA%20href%3D%22https%3A%2F%2Fwww.sparkfun.com%2Ftutorials%2Fcategory%2F2%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20There%20is%20plenty%20of%20good%20stuff%20on%20the%20web%20on%20how%20to%20do%20SMT%20soldering%3C%2FA%3E.%26nbsp%3B%20All%20of%20the%20parts%20on%20the%20board%20are%20fairly%20simply%20once%20you%20get%20the%20hang%20of%20it%20and%20everything%20can%20be%20hand%20soldered%26nbsp%3B%20The%20key%20is%20having%20some%20decent%20tools.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1872453343%22%20id%3D%22toc-hId--1872453343%22%20id%3D%22toc-hId--957093006%22%3E%3CSTRONG%3EStep%202%3A%20Put%20it%20Together%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EAttach%20the%20FRDM-JAM%20to%20the%20FRDM-K20D50.%26nbsp%3B%20The%20FRDM-K20D50%20comes%20with%20female%20headers%20that%20you%20can%20solder%20on%20so%20the%20boards%20can%20be%20easily%20separated.%26nbsp%3B%20Note%20that%20as%20of%20Rev%20Gamma%20(current%20version)%2C%26nbsp%3B%26nbsp%3B%20it%20is%20possible%20to%20connect%20to%20a%20K64F.%26nbsp%3B%26nbsp%3B%26nbsp%3B%20The%20software%20isn't%20quite%20there%20but%20it%20hardware%20connections%20are%20available.%26nbsp%3B%26nbsp%3B%20If%20you%20are%20unsure%2C%26nbsp%3B%20stick%20with%20the%20FRDM-K20D50%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-615059490%22%20id%3D%22toc-hId-615059490%22%20id%3D%22toc-hId-1530419827%22%3E%3CSTRONG%3EStep%203%3A%20Download%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EDownload%20the%20Example%20Software%20from%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fehughes%2FMonkeyJam%2Freleases%2Ftag%2FR0%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22font-size%3A%2015.555556297302246px%3B%20text-align%3A%20center%3B%22%20target%3D%22_blank%22%3EGithub%3C%2FA%3E.%26nbsp%3B%20The%20video%20%3CSTRONG%3E%22Loading%20and%20Configuring%20the%20MonkeyJam%20Example%20Software%22%3C%2FSTRONG%3E%20will%20step%20you%20though%20downloading%20the%20program%20and%20doing%20some%20basic%20configuration.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1192394973%22%20id%3D%22toc-hId--1192394973%22%20id%3D%22toc-hId--277034636%22%3E%3CSTRONG%3EStep%204%3A%20Hack%20and%20Slash!%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EPlug%20In%20and%20jam!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1295117860%22%20id%3D%22toc-hId-1295117860%22%20id%3D%22toc-hId--2084489099%22%3E%3CSTRONG%3ESound%20Samples%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EEach%20sound%20sample%20was%20my%20Carvin%20Ultra-V%20guitar%20plugged%20direct%20into%20the%20MonkeyJam%20Board.%26nbsp%3B%20The%20output%20was%20fed%20to%20a%20Zoom%20Handy%20Recorder%20H4n%20(Thanks%20to%20Brandin%20Claar%20of%20Remodulate%20LLC%20for%20the%20recorder).%26nbsp%3B%20The%20H4N%20recorded%20the%20signal%20at%2044.1KHz%20Sample%20rate%20%4016-bit.%26nbsp%3B%20The%20sound%20files%20were%20converted%20to%20mono%20format%20via%20Goldwave.%26nbsp%3B%20No%20processing%20(other%20than%20a%26nbsp%3B%20volume%20boost%20on%20the%20files)%20was%20performed.%26nbsp%3B%26nbsp%3B%20I%20listen%20to%20the%20recording%20in%20real-time%20via%20a%20line%20out%20on%20the%20H4N.%26nbsp%3B%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22TestSetup.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22TestSetup.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45923iEE08F05B00376700%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22TestSetup.jpg%22%20alt%3D%22TestSetup.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ETestSetup.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20class%3D%22jiveBorder%22%20height%3D%221273%22%20jive-data-cell%3D%22%7B%22%20color%3D%22%22%3E%3CTBODY%3E%3CTR%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%204px%3B%20vertical-align%3A%20middle%3B%22%20valign%3D%22middle%22%3E%3CSTRONG%3EFile%20(See%20Attachments)%3C%2FSTRONG%3E%3C%2FTH%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%204px%3B%20vertical-align%3A%20middle%3B%22%20valign%3D%22middle%22%3E%3CSTRONG%3EPatch%3C%2FSTRONG%3E%3C%2FTH%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%204px%3B%20vertical-align%3A%20middle%3B%22%20valign%3D%22middle%22%3E%3CSTRONG%3ENotes%3C%2FSTRONG%3E%3C%2FTH%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3ESTE-003-Neck-a12b12g12-mlike.wav%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%2038px%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%3CSTRONG%3EPATCH_TUBEY_CLEAN%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3ENeck%20Pickup%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAlpha%20Pot%20-%2012%20O'Cock%3C%2FP%3E%3CP%3EBeta%20Pot%20-%2012%20O'Cock%3C%2FP%3E%3CP%3EGamma%20Pot%20-%2012%20O'Cock%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPattern%20Similar%20to%20Metallica%20Sanitarium%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3ESTE-005-Neck-a7b5g5-mlike.wav%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%2038px%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%3CSTRONG%3EPATCH_TUBEY_CLEAN%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3E%3CTABLE%20border%3D%221%22%20class%3D%22jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20width%3A%20100%25%3B%22%3E%3CTBODY%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3ENeck%20Pickup%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAlpha%20Pot%20-%207%20O'Cock%3C%2FP%3E%3CP%3EBeta%20Pot%20-%205%20O'Cock%3C%2FP%3E%3CP%3EGamma%20Pot%20-%205%20O'Cock%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPattern%20Similar%20to%20Metallica%20Sanitarium%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3ESTE-006-Neck-a12b7g5-mlike.wav%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%2038px%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%3CSTRONG%3EPATCH_TUBEY_CLEAN%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3E%3CTABLE%20border%3D%221%22%20class%3D%22jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20width%3A%20100%25%3B%22%3E%3CTBODY%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3ENeck%20Pickup%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAlpha%20Pot%20-%2012%20O'Cock%3C%2FP%3E%3CP%3EBeta%20Pot%20-%207%20O'Cock%3C%2FP%3E%3CP%3EGamma%20Pot%20-%205%20O'Cock%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPattern%20Similar%20to%20Metallica%20Sanitarium%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3ESTE-007-Neck-VariousSettings-d-g-em_strum.wav%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%2038px%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%3CSTRONG%3EPATCH_TUBEY_CLEAN%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3ENeck%20Pickup%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20pots%20were%20moved%20around%20throughout%20the%20file%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EStrummed%20D-Major%2C%20G-Major%20and%20E-Minor%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3ESTE-008-Neck%2BBridge-VariousSettings-d-g-em_strum.wav%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%2038px%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%3CSTRONG%3EPATCH_TUBEY_CLEAN%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3ENeck%20%2B%20Bridge%20Pickup%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20pots%20were%20moved%20around%20throughout%20the%20file%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EStrummed%20D-Major%2C%20G-Major%20and%20E-Minor%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3ESTE-009-Bridge-VariousSettings-d-g-em_strum.wav%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%2038px%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%3CSTRONG%3EPATCH_TUBEY_CLEAN%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3EBridge%20%2B%20Bridge%20Pickup%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20pots%20were%20moved%20around%20throughout%20the%20file%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EStrummed%20D-Major%2C%20G-Major%20and%20E-Minor%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3ESTE-010-Neck-VariousSettings-Jammy.wav%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%2038px%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%3CSTRONG%3EPATCH_TUBEY_CLEAN%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3ENeck%20%2B%20Bridge%20Pickup%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20pots%20were%20moved%20around%20throughout%20the%20file%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EB-Minor%20Type%20Jam%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3ESTE-011-%20Bridge%20-%20Various%20Settings%20-%20On-Off%20Demo-RandomDroppedD.wav%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%2038px%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%3CSTRONG%3EPATCH_OVERDRIVE%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3EBridge%20Pickup%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAlpha%20Pot%20-%205%20O'Cock%3C%2FP%3E%3CP%3EBeta%20Pot%20-%2012%20O'Cock%3C%2FP%3E%3CP%3EGamma%20Pot%20-%2012%20O'Cock%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERandom%20Dropped%20D%20twiddling%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3ESTE-012-%20Neck%20-%20Various%20Settings%20-%20On-Off%20Demo-Jammy.wav%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%2038px%3B%20text-align%3A%20center%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3E%3CSTRONG%3EPATCH_OVERDRIVE%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%20text-align%3A%20left%3B%20vertical-align%3A%20middle%3B%22%3E%3CP%3ENeck%20Pickup%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAlpha%20Pot%20-%205%20O'Cock%3C%2FP%3E%3CP%3EBeta%20Pot%20-%207%20O'Cock%3C%2FP%3E%3CP%3EGamma%20Pot%20-%207%20O'Cock%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERandom%20B-Minor%20twiddles%20(bluesy)%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3E%3CSTRONG%3EPATCH_OVERDRIVE%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20jive_macro_code%20_jivemacro_uid_14106251056281574%22%20jivemacro_uid%3D%22_14106251056281574%22%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89Signal%E2%80%89In%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89IIR%E2%80%89BiQuad%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89Hard%E2%80%89Overdrive%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89IIR%E2%80%89BiQuad%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89Signal%E2%80%89Out%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%26gt%3B%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%26gt%3B%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%26gt%3B%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%26gt%3B%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%5BPeaking%E2%80%89EQ%5D%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%5Batan24pi%E2%80%89Look%E2%80%89Up%E2%80%89Table%5D%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%5BLow%E2%80%89Pass%E2%80%89Filter%5D%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%890.1%E2%80%89%26lt%3B%E2%80%89Q%E2%80%89%26lt%3B%E2%80%891.5%E2%80%89%E2%80%89%E2%80%89%E2%80%89%5BPot%E2%80%89Alpha%5D%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89Q%E2%80%89%3D%E2%80%890%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%8950%E2%80%89%26lt%3B%E2%80%89Fs%E2%80%89%26lt%3B%E2%80%89750%E2%80%89%E2%80%89%E2%80%89%E2%80%89%5BPot%E2%80%89Gamma%5D%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89Fs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lt%3B%E2%80%89dbGain%E2%80%89%26lt%3B%E2%80%8920%E2%80%89%E2%80%89%5BPot%E2%80%89Beta%5D%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3EPATCH_TUBEY_CLEAN%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14106251056075068%20jive_text_macro%20jive_macro_code%22%20jivemacro_uid%3D%22_14106251056075068%22%3E%0A%3CP%3E%E2%80%89%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89Signal%E2%80%89In%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89IIR%E2%80%89BiQuad%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89Soft%E2%80%89Overdrive%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89IIR%E2%80%89BiQuad%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89Signal%E2%80%89Out%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%26gt%3B%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%26gt%3B%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%26gt%3B%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%26gt%3B%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%26nbsp%3B%20%E2%80%89%5BLowShelf%5D%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%5Batan4pi%E2%80%89Look%E2%80%89Up%E2%80%89Table%5D%20%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%5BLow%E2%80%89Pass%E2%80%89Filter%5D%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%7C%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%2B%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%E2%80%93%2B%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%890.05%E2%80%89%26lt%3B%E2%80%89Q%E2%80%89%26lt%3B%E2%80%892.58%E2%80%89%E2%80%89%E2%80%89%5BPot%E2%80%89Alpha%5D%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89Q%E2%80%89%3D%E2%80%892.0%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%20%E2%80%891000%E2%80%89%26lt%3B%E2%80%89Fs%E2%80%89%26lt%3B%204000%E2%80%89%E2%80%89%E2%80%89%E2%80%89%5BPot%20Beta%5D%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89Fs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lt%3B%E2%80%89dbGain%E2%80%89%26lt%3B%E2%80%8915%E2%80%89%E2%80%89%5BPot%E2%80%89Gamma%5D%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%20%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%E2%80%89%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--764600942%22%20id%3D%22toc-hId--764600942%22%20id%3D%22toc-hId-150759395%22%3E%3CSTRONG%3EUtilities%2C%20etc%3A%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100240%22%20target%3D%22_blank%22%3EBiquad%20Filter%20View%20-%20A%20IIR%20Biquad%20Filter%20Design%20%26amp%3B%20Visualization%20Tool%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1120736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EStudent%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20H.I.T.%20Project%20%231%3A%20%20MonkeyJam%20-%20A%20DIY%20Guitar%20Stomp%20Box%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Eli%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20have%20implemented%20the%20CMSIS%20code%20and%20also%20made%20the%20document%20for%20others%20%2C%20kindly%20look%20if%20anything%20is%20incorrect%20in%20the%20process%20and%20please%20update%20it.%20%3CA%20_jive_internal%3D%22true%22%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F414670%23414670%22%20title%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F414670%23414670%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F414670%23414670%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EKind%20Regards%3C%2FP%3E%3CP%3EAmit%20Kumar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20H.I.T.%20Project%20%231%3A%20%20MonkeyJam%20-%20A%20DIY%20Guitar%20Stomp%20Box%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Eli%20Hughes%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECan%20you%20provide%20me%20the%20link%20of%20the%20video%20in%20which%20you%20have%20demonstrated%20how%20to%20implement%26nbsp%3B%20CMSIS%20library%20with%20codwarrior%20basically%20I%20am%20concerned%20with%20FFT%20library%20which%20you%20have%20implemented%3F%20It%20Will%20be%20a%20great%20help.%20Thanks%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EKind%20Regards%3C%2FP%3E%3CP%3EAmit%20Kumar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20H.I.T.%20Project%20%231%3A%20%20MonkeyJam%20-%20A%20DIY%20Guitar%20Stomp%20Box%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Eli%3C%2FP%3E%3CP%3EThanks%20for%20your%20reply.%20when%20I%20am%20opening%20your%20project%20for%20the%201st%20time%20I%20am%20getting%20some%20warning%20message.%20Is%20this%20message%20of%20any%20concern%3F.%20%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cmp.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cmp.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F44411i3CC3C997C596F267%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22cmp.jpg%22%20alt%3D%22cmp.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ecmp.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EKind%20Regards%3C%2FP%3E%3CP%3EAmit%20Kumar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120740%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20H.I.T.%20Project%20%231%3A%20%20MonkeyJam%20-%20A%20DIY%20Guitar%20Stomp%20Box%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120740%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAmit%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIf%20you%20click%20on%20the%20project%20properties%20for%20the%20library%20and%20look%20at%20processor%20settings%2C%20there%20are%202%20symbols%20(ARM_CM4%20and%20ARM_ROUNDING).%26nbsp%3B%26nbsp%3B%20This%20is%20all%20I%20had%20to%20do%20to%20get%20it%20compile.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20think%20I%20covered%20it%20in%20one%20of%20the%20videos.%26nbsp%3B%20If%20not%2C%20I%20will%20certainly%20have%20to%20get%20some%20sort%20of%20small%20video%20for%20it!.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-Eli%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20H.I.T.%20Project%20%231%3A%20%20MonkeyJam%20-%20A%20DIY%20Guitar%20Stomp%20Box%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20_jive_internal%3D%22true%22%20class%3D%22jiveTT-hover-user%20jive-link-profile-small%22%20data-containerid%3D%22-1%22%20data-containertype%3D%22-1%22%20data-content-finding%3D%22Community%22%20data-objectid%3D%2238030%22%20data-objecttype%3D%223%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Feli_hughes%22%20target%3D%22_blank%22%3EEli%20Hughes%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20Imported%20the%20MonkeyListen%20Project%20and%20it%20got%20compiled%20without%20any%20error.%20right%20now%20for%20testing%20I%20am%20targeting%20FRDM-K20D50M%20(MK20DX128).%20After%20this%20I%20will%20be%20targeting%20mk60fn1m0vlq12.%20What%20are%20the%20settings%20required%20to%20be%20done%20for%20using%20the%20library%20in%20any%20project%20%3F%20If%20you%20can%20provide%20some%20snapshot%20of%26nbsp%3B%20the%20settings%20required%20to%20make%20it%20work%20It%20will%20be%20helpful%20for%20all%20the%20community%20members.%20As%20I%20went%20across%20some%20queries%20which%20was%20unanswered%20regarding%20the%20same.%20In%20ARM's%20website%20also%20I%20didn't%20find%20any%20help%20regarding%20this.%20When%20I%20saw%20your%20tutorial%20everything%20was%20well%20explained.%20So%20If%20this%20portion%20is%20also%20covered%20in%20it%20than%20it%20will%20a%20great%20help%20for%20people%20like%20me.%20and%20I%20am%20sure%20many%20people%20want%20to%20use%20it%20but%20can't%20use%20due%20to%20this%20implementation%20part.%20%3C%2FP%3E%3CP%3EThanks%20in%20advance%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EKind%20Regards%3C%2FP%3E%3CP%3EAmit%20Kumar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120738%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20H.I.T.%20Project%20%231%3A%20%20MonkeyJam%20-%20A%20DIY%20Guitar%20Stomp%20Box%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120738%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAmit%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDo%20you%20try%20importing%20the%20MonkeyListen%20project%20and%20see%20the%20settings%20I%20used%3F%26nbsp%3B%26nbsp%3B%20What%20chip%20are%20you%20targeting%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Freescale%20H.I.T.%20Project%20%231%3A%20%20MonkeyJam%20-%20A%20DIY%20Guitar%20Stomp%20Box%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Feli_hughes%22%20target%3D%22_blank%22%3Eeli_hughes%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20For%20the%20awesome%20tutorial.%20It%20pretty%20much%20shows%20the%20real%20life%20implementation%20of%20DSP.%20I%20wanted%20to%20ask%20you%20about%20implementation%20of%20CMSIS%20library%20in%20codewarrior.%20In%20one%20of%20my%20projects%20I%20wanted%20to%20implement%20DSP%20library%20to%20implement%20FFT.%20But%20I%20am%20stuck%20in%20implementing%20CMSIS%20library.%20I%20saw%20your%20Video%20for%20this%20as%20well%20as%20the%202nd%20project%20i.e%20%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-99621%23jive_content_id_Project_2_Monkey_Listen_Audio_Spectrum_Analyzer_Display%22%20target%3D%22_blank%22%3EProject%20%232%3A%20Monkey%20Listen!%20Audio%20Spectrum%20Analyzer%20Display%3C%2FA%3E%20That%20was%20also%20awesome%20like%20this.%20But%20again%20I%20cannot%20move%20further%20as%20I%20am%20facing%20problem%20in%20implementing%20the%20library.I%20went%20through%20some%20post%20regarding%20implementing%20the%20CMSIS%20library%20but%20that%20was%20not%20compiling%20and%20was%20giving%20errors.%20and%20sometimes%20was%20exceeding%20the%20m-text%20limit.%20I%20went%20through%20the%20following%20links.%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fmcuoneclipse.com%2F2013%2F02%2F14%2Ftutorial-using-the-arm-cmsis-library%2F%22%20title%3D%22http%3A%2F%2Fmcuoneclipse.com%2F2013%2F02%2F14%2Ftutorial-using-the-arm-cmsis-library%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ETutorial%3A%20Using%20the%20ARM%20CMSIS%20Library%20%7C%20MCU%20on%20Eclipse%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F320772%22%20target%3D%22_blank%22%3EAdding%20the%20CMSIS-DSP%20library%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-98638%22%20target%3D%22_blank%22%3E%E7%A7%BB%E6%A4%8DCMSIS-DSP%E5%BA%93%E5%88%B0CodeWarrior%E7%9A%84%E6%AD%A5%E9%AA%A4%E4%BB%A5%E5%8F%8AKinetis%20FPU%E5%8D%95%E5%85%83%E5%BA%94%E7%94%A8%E7%9A%84%E5%AF%B9%E6%AF%94%3C%2FA%3E%3C%2FP%3E%3CP%3EPlease%20look%20into%20the%20matter.%20I%20hope%20this%20post%20will%20be%20beneficial%20for%20many%20community%20users.%20Thanks%20in%20advance%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EKind%20Regards%3C%2FP%3E%3CP%3EAmit%20Kumar%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎09-10-2020 02:48 AM
Updated by:
