reset in u-boot
reset in u-boot
1,567 次查看
monalihaware
I have a custom board with T2080. And i have successfully dumped uboot code in it. Issue is ," reset" command from uboot code does not work, the board does not reset with "reset' command. whereas the "cpld reset" command resets the board and uboot resets and repeats printing on serial board but why "reset" command does not work? Can anyone help?
1,541 次查看
LFGP
please check if the reset command is enabled, you can use the next info:
I will keep attend you in your privet case
