Debugger License Error
anirudhm
Hello, i have this issue coming up repeatedly whenever i try debugging a Bareboard project. During debugging, this line of information always shows up, Debugger License Error, though im using a valid license for running validation tool. Could you help me suggesting a solution for this?
anirudhm
hello, pls find attached the required attachment wrt license(s) expiration. This issue is arising only for debugger, but the validation tool is running fine with the generated license.
LFGP
It's necessary an active license in order to debug, if you recently adquiere one of it please reinstall the IDE and set the license once again.
LFGP
please check the "Product Licenses" into the CodeWarrior IDE, you must have days to left
