T1024 DDR
T1024 DDR
3,378 次查看
BharathiG
During the DDR initialization software is setting D_INIT bit and after initialization is done software waits for this bit to be cleared. Hardware will clear this bit after the initialization is complete.  Clearing of D_INIT bit is consistent for all T1024 hardware’s or it will changing with variation of environmental factor (temperature or electromagnetic effect) or any other factors?
3,344 次查看
yipingwang
The clearing of D_INIT bit is done 100% of time by HW if DDR initialization completes.
3,314 次查看
BharathiG
I accept what you said and we are seeing the clearing of D_INIT bit by hardware. Powerup to powerup will their be any variations (timing variations) in clearing this bit ? Will it be consistently clearing the bit?
3,293 次查看
yipingwang
For the same board type (same HW and SW/settings), the time it takes to clear the D_INIT would be constantly the same.
3,345 次查看
yipingwang
