How to test nvram rtc with powepc kernel
vinothkumars
Senior Contributor IV
Dear NXP,
I am working on T4240RDB-64B machine and using QORIQ-SDK-2.0 source. I needs to test NVRAM RTC in kernel.
Needs to read and write the value.
Will you please tell me how to test NVRAM RTC (CY14B116M ) ?
Do I needs to do any configuration ?
Thanks & Regards,
VinothS,
Vinothkumar Sekar
yipingwang
1. Enable I2C-RTC driver in kernel, Eg.<DS3232>.
Device Drivers->
        Real Time Clock-->
                  [*] Set system time from RTC on startup and resume (new)
                  (rtc0) RTC used to set the system time (new)
                 <[*] /sys/class/rtc/rtcN (sysfs)
                 <[*] /proc/driver/rtc (procfs for rtc0)
                 <[*] /dev/rtcN (character devices)
                  I2C RTC drivers
                 <[*] Dallas/Maxim DS3232
After booting up Linux.
# dmesg |grep rtc
# ls -l /dev/rtc*
# cat /proc/devices |grep rtc
# mknod /dev/rtc0 c 254 0
# ln -s /dev/rtc0 /dev/rtc
# hwclock -r
# date
# date 081815202008
# hwclock -w
# date 010101012011
# date
# hwclock
# hwclock -s
# date
If your RTC chip supports NVRAM, it will be exposed as a sysfs file named nvram. To find the file, run
find /sys -name nvram
and you will get output like
/sys/devices/platform/i2c_davinci.1/i2c-1/1-0068/nvram
If your busybox configuration includes
CONFIG_OD=y
then you can dump the contents of NVRAM using
od -x /sys/devices/platform/i2c_davinci.1/i2c-1/1-0068/nvram
and you will get output similar to
0000000     d67a    8472    5de8    b5d6    7e1d    10da    4aef    8016 0000020     26df    1027    56a5    b814    61ca    5214    1259    5aca 0000040     ba49    5930    e452    a730    f653    ec0a    f0bb    2ad0 0000060     88dc    657e    3468    9be8
You can test that you can write to NVRAM using
echo "123456789a123456789b123456789c123456789d123456789e1234" > /sys/devices/platform/i2c_davinci.1/i2c-1/1-0068/nvram
yipingwang
Device Drivers->
        Real Time Clock-->
                  I2C RTC drivers
# dmesg |grep rtc
# ls -l /dev/rtc*
# hwclock -r
# date
# date 081815202008
# hwclock -w
# date 010101012011
# date
# hwclock
# hwclock -s
# date
CONFIG_OD=y
vinothkumars
Thank you Yiping Wang for your reply.
Thanks & Regards,
VinothS,
Vinothkumar Sekar
