DDR3 Power Connection on T1024RDB
已解决
跳至解决方案
1,938 次查看
bltuna
Below is the power connection of the DDR3 that is presented on the T1024RDB schematic. I couldn't understand why such a connection (highlighted portion) is made.
标签 (1)
标记 (3)
1 解答
1,801 次查看
r8070z
This figure is from T1040QDS schematics where they explains that connection. For the T1024RDB schematics it should sounds like “Decoupling between 1V35_SLP and 1V35 power split located under DIMM. Place these caps around DDR Power Pin areas to stitch return current flow for Address and command signals.”
在原帖中查看解决方案
1 回复
1,802 次查看
r8070z
