Building USDPAA applications with yocto 2.7
sedat_altun
My question is about how to build USDPAA applications with yocto 2.7 for t4240rdb-64b board.
I am able to build images by using latest yocto 2.7 by using the instructions from
qoriq-components/yocto-sdk - Repo manifest for QorIQ Yocto SDK .
I am getting the yocto layers from community repository and then by the below commands I succeeded to build kernel4.14, rootfs, dtb ..
$: . ./setup-env -m t4240rdb-64b
$: bitbake fsl-image-networking-full
After build when I looked at rootfs there is no usdpaa applications .
What I have to do in order to build usdpaa applications by yocto 2.7?
Tags (2)
sedat_altun
I found how to build usdpaa by using sdk 2.0.
After installing sdk 2.0  I successfully built usdpaa applications with the below commands :
bitbake -c compile usdpaa
bitbake -c compile usdpaa-apps
