Problem with registering Codewarior  for HCS12(X) Microcontrollers
1,714件の閲覧回数
ronensharabani
My license to CodeWarrior Development Studio for HCS12(X) Microcontrollers (Classic IDE) v5.1   has expiered on Mar 30, 2016 .
Even though We have ordered Annual Subscription, Node-locked License on Mar 03 2016  until Mar 30, 2017 I could not successfully register and continue using  the product with the generated license file.
1,458件の閲覧回数
TICS_Fiona
Hello Ronen
Did you have purchased CodeWarrior suite? If yes, please refer to the document below to register your suite:
New Web license system - Registering your physical shipment Software and Support contracts.
If you still cannot register it, I would suggest using another web browser like Firefox to try again.
Hope this helps! If there’s further question for your registered CodeWarrior Suite, I would suggest summiting a case. It's better under Case process for private license details.
https://community.freescale.com/docs/DOC-330215
Best Regards
Fiona Kuang
Technical Information & Commercial Support
Note: If this post answers your question, please click the Mark Correct button. Thank you!
