I need to set up an instance of CodeWarrior for Coldfire version 6.4, however it appears that is no longer available for purchase.  Can I use a version 7.2 license to activate a version 6.4 install assuming I still have copies of the old binaries?
2,225 次查看
kenmcinerney
Trying to replicate our customer's development environment and they are not in a position to upgrade their tools.  I need to get a licensed copy of 6.4 set up at our development facility.  Is there a way to accomplish this?
1,950 次查看
TICS_Fiona
Please send email to [email protected] to request the license for CodeWarrior 6.4, please also supply the part number of your CodeWarriior.
Part number is defined as Examples:
    CWP-PRO-NL_1-387604471
    FSL-13d9-3f41-13b7-03b3-102c-c8
    AB693-1DC57-2AB67-E014C
Else you can provide your license.dat file used in CodeWarrior 7.2?
1,951 次查看
TICS_Fiona
1,950 次查看
weiranhe
My license problem has been solved and I have clicked Correct Answer in the community thread,thank you again~
TICS_Fiona <[email protected]>编写:
>reply from TICS_Fiona in CodeWarrior Licensing - View the full discussion
> Did your question get answered?
> If so, say thanks by clicking Correct Answer in the community thread! Reply to this message by replying to this email, or go to the message on Freescale Community Start a new discussion in CodeWarrior Licensing by email or at Freescale Community Following TICS_Fiona in these streams: Inbox
