How can I add two products to one license file?
franklombardo
I am in the process of porting an application from Classic CodeWarrior to CodeWarrior for MCU Eclipse.  I would like to run both IDEs while I do this.
franklombardo
I have resolved my issue.  I don't know if there is an easier way to do it, but here is what I ended up doing.
I generated the license file for the two products, then copied the INCREMENT section(s) from the second file into the first. The combined file now works for both products from my single license server.
TomasPaez
Here is a document for combining license.
franklombardo
