Codewarrior license
Codewarrior license
3,039 次查看
fredfu
   My customer--Xiamen Shinlin bought CW license, they can't install sucessful the license according to "Floating License Installatio Guide for Windows", the Client can't work(see below picture), the attachments are FlexLM running picture and license file generated from Internet, the customer placed the license file in C:\FSL_FlexLM in Server, and placed it in \CW S12 V5.1 in Client. How can I install the license? Thanks.
标记 (1)
2,307 次查看
TomasPaez
The error code shows the vendor daemon is down
Error -97, The desired vendor daemon is down.
1) Check the lmadmin or lmgrd log file, or 2) Try lmreread.
I will contact you directly to check with you the log file.
Thank you.
2,308 次查看
TomasPaez
Thank you.
2,307 次查看
fredfu
CodeWarrior Licensing
   Could you help on that? The problem still is not solved, below is license file data. Thanks.
#CodeWarrior Development Suite - Standard Edition, Perpetual Model, Floating
#License - CodeWarrior for HC12 Standard Edition WIN for ? ? Software Account
SERVER xseec-4dfa9dda6 d067e52afd7f 27000
VENDOR metrowks
USE_SERVER
INCREMENT HI100350 metrowks 5.002 permanent 1 8E17690DF676 \
VENDOR_STRING="CodeWarrior for HC12 Standard Edition WIN" \
DUP_GROUP=UH ISSUER="Freescale Semiconductor" \
ISSUED=20-apr-2016 ck=81 SN="FSL - 16113057" TS_OK
INCREMENT HI150000 metrowks 5 permanent 1 68D0FCAF408D \
ISSUED=20-apr-2016 ck=168 SN="FSL - 16113057" TS_OK
INCREMENT HI150050 metrowks 5.001 permanent 1 249EEB15CAC5 \
ISSUED=20-apr-2016 ck=175 SN="FSL - 16113057" TS_OK
INCREMENT HI404050 metrowks 5 permanent 1 E9E97C6AA346 \
INCREMENT HI404220 metrowks 5 permanent 1 B5D417F2BD9A \
ISSUED=20-apr-2016 ck=120 SN="FSL - 16113057" TS_OK
INCREMENT HI407284 metrowks 5 permanent 1 6F006072793E \
ISSUED=20-apr-2016 ck=117 SN="FSL - 16113057" TS_OK
INCREMENT PE_Basic_BeansHCS12 metrowks 1 permanent 1 12667A694BA0 \
ISSUED=20-apr-2016 ck=104 SN="FSL - 16113057" TS_OK
INCREMENT ProcessorExpertHCS12 metrowks 1.001 permanent 1 \
D4E1B17D1F5B VENDOR_STRING="CodeWarrior for HC12 Standard \
Edition WIN" DUP_GROUP=UH ISSUER="Freescale Semiconductor" \
ISSUED=20-apr-2016 ck=129 SN="FSL - 16113057" TS_OK
INCREMENT Win32_CWIDE_Unlimited metrowks 5.9 permanent 1 C83CD4771CA8 \
ISSUED=20-apr-2016 ck=160 SN="FSL - 16113057" TS_OK
INCREMENT HI100300 metrowks 5 permanent 1 1D2250F10E6E \
ISSUED=20-apr-2016 ck=113 SN="FSL - 16113057" TS_OK
INCREMENT HI100360 metrowks 5 permanent 1 F3378A3D2A2A \
ISSUED=20-apr-2016 ck=97 SN="FSL - 16113057" TS_OK
