CW for PA evaluation period?
3,256 次查看
peterscheiwille
I downloaded and installed CW for PA for Network Applications on 6 Jan for evaluation. After installation it ran OK, and on 21 Jan I got an email telling me the evaluation license would expire on 20-2-2017. However when I try and run CW today (1-2-17) it says that the license has already expired. How long should the evaluation period actually be, and can I possible extend the evaluation period? ( I read somewhere on the website that I could...)
Peter
标记 (1)
6 回复数
3,025 次查看
stanish
Peter,
AFAIK you can extend/request an evaluation version 3 times in total.
So you might have already downloaded/requested eval. license 2 times (could be even different product) so you probably cannot extend it automatically now. Anyway you can explicitly request to extend the evaluation period.
To do it please create a support ticket and specify your request:https://community.nxp.com/docs/DOC-329745
Hope it helps.
Stan
3,025 次查看
stanish
Hello Peter,
The standard evaluation period is 30 days. Could you please check your license.dat file?
You should see:
#EVALUATION CodeWarrior Development Suite for Networked Applications -
#CodeWarrior for Power Architecture - Professional Edition (Eclipse-Windows
#hosted) Evaluation / Updates for XYX Software Account
# License for ANY
INCREMENT Win32_CFP_PPC metrowks 10.5 xx-xxx-2017 uncounted \
      0123456789AB VENDOR_STRING="CodeWarrior for Power Architecture \
      - Professional Edition (Eclipse-Windows hosted) Evaluation / \
      Updates" HOSTID=ANY ISSUER="Freescale Semiconductor" \
      ISSUED=xx-xxx-2017 NOTICE=NONE ck=152 SN="FSL - 12345678" \
      TS_OK
 what are the highlighted dates in your license.dat file?
Stan
3,024 次查看
peterscheiwille
Hi Stan
Please see attached for the only license.dat file I can find. It doesn't seem to have the lines you quote in it.
Peter
3,024 次查看
TomasPaez
Hi Peter, you might have used the embedded license that comes with the first installation, you can get the license file with the 45 days after the first download following the next video, I have generated the license on your behalf.
How to access software products and licenses|NXP
Find it here
3,024 次查看
peterscheiwille
Hi Tomas,
It says on the NXP website that the evaluation license can be extended a limited number of days, but the instructions on the website don't really make sense. Looks like the website has changed since they were written.
Is it still possible to extend the License, and how can I do it?
Peter
3,024 次查看
peterscheiwille
Oh well, I guess it's no longer possible to extend the evaluation period........ Please update info on the website
