How do you change keys on a P71 card?
899 次查看
larry1
I'm personalizing a contactless Mchip P71 card from scratch, but having trouble setting a new Personalization key.  During Mchip applet perso, DGI8001 is accepted, the perso session closes, and the card passes all its tests. Hand decrypting the DGI with the session key verifies that the new keys are sent to the card.
But the original key still works, and the new Perso key fails.  I could not get the Card Manager to accept a DGI 8001.  It kept giving me 6D00, "Instruction code not supported or invalid."  I cannot get the Mchip applet to authenticate after first perso, so I can't see if the new key is active at that level.
What is the procedure for changing keys on this chip?
标签 (3)
标记 (1)
883 次查看
Kan_Li
Hi @larry1 ,
I am sorry, but P71 products are not the mass market products supported here, would you please create a private ticket according to the following link? We have a dedicated team to support this.
https://www.nxp.com/video/tutorial-for-nxp-support-case-portal:NCP-VIDEO
Thanks for your patience and understanding!
Kan
884 次查看
Kan_Li
Hi @larry1 ,
Kan
