pressure sensor MPXV7002 temperature range
andreacelani
The pressure sensor MPXV7002 has following temperature ranges:
operating: TA +10...+60°C
Do may cause permanent damage if operating at -10°C...+9°C? [yes or no]
I can accept in my project that the error will increase outside of the compensated temperature range (+10...+60°C), but I cannot accept that the sensor will be permanent damaged, as stated in the datasheet (Table 4. Maximum Ratings, note [1]).
Thank you for your help.
JozefKozon
Dear Andrea,
yes, you can use the MPXV7002DP outside of the compensated temperature range (TA +10...+60°C), from -30°C to 100°C without damage. But as you mentioned the error is increased outside of the compensated area and we cannot guarantee how much.
With Best Regards,
Jozef
JozefKozon
Dear Andrea,
With Best Regards,
Jozef
%3CLINGO-SUB%20id%3D%22lingo-sub-1687252%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Epressure%20sensor%20MPXV7002%20temperature%20range%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1687252%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20pressure%20sensor%20MPXV7002%20has%20following%20temperature%20ranges%3A%3C%2FP%3E%3CP%3Eoperating%3A%20TA%20%2B10...%2B60%C2%B0C%3C%2FP%3E%3CP%3EDo%20may%20cause%20permanent%20damage%20if%20operating%20at%20-10%C2%B0C...%2B9%C2%B0C%3F%20%5Byes%20or%20no%5D%3C%2FP%3E%3CP%3EI%20can%20accept%20in%20my%20project%20that%20the%20error%20will%20increase%20outside%20of%20the%20compensated%20temperature%20range%20(%2B10...%2B60%C2%B0C)%2C%20but%20I%20cannot%20accept%20that%20the%20sensor%20will%20be%20permanent%20damaged%2C%20as%20stated%20in%20the%20datasheet%20(Table%204.%20Maximum%20Ratings%2C%20note%20%5B1%5D).%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20help.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1687357%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20pressure%20sensor%20MPXV7002%20temperature%20range%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1687357%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EDear%20Andrea%2C%3C%2FSPAN%3E%3CBR%20clear%3D%22none%22%20%2F%3E%3CBR%20clear%3D%22none%22%20%2F%3E%3CSPAN%3Eyes%2C%20you%20can%20use%20the%20MPXV7002DP%20outside%20of%20the%20compensated%20temperature%20range%20(TA%20%2B10...%2B60%C2%B0C)%2C%20from%20-30%C2%B0C%20to%20100%C2%B0C%20without%20damage.%20But%20as%20you%20mentioned%20the%20error%20is%20increased%20outside%20of%20the%20compensated%20area%20and%20we%20cannot%20guarantee%20how%20much.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EWith%20Best%20Regards%2C%3C%2FP%3E%0A%3CP%3EJozef%3C%2FP%3E%3C%2FLINGO-BODY%3E
