RFID passive tag UHF temp sens
921件の閲覧回数
estriby
Hi, I'm Sebastiano Viti and I'm doing a degree thesis on a project that
should use a passive RFID tag that works in the UHF band and has an
integrated temperature sensor.
Do you have any products that can satisfy these requests?
You can contact me at this address: sebastiano.viti@studenti.unipg.it
904件の閲覧回数
diazmarin09
Hello Sebastiano,
I hope all is great with you. Thank you for using the NXP communities.
Have you considered the device below?
NHS3100 - NTAG SmartSensor with Temperature Sensor and Digital IOs
I hope this information helps.
David
