how to code MM912J637
1,214 次查看
afandi
Hi, I want to explore MM912J637 using LQ-Multilink. I have search how to code and the basic sourcode for MM912J637 using LQ-Multilink but I get nothing. I have explore this forum https://community.nxp.com/thread/430483 but I'm still confuse. What kind of chip I must to select for the setting ? MC9S12 chip for LQ-Multilink ? or MM912J637 ? Can someone help me what I must to do first for explore MM912J637 or the basic source code so I can explore how to code or something that I must to know about MM912J637 ?
Note: I'm using code warrior 5.2
1,073 次查看
david_diaz
Hello Aly,
In this case, do you mean the P&E USB Multilink Debug Interface?
David
