There is a file called DWF13_AMF_AUT_T1043.pdf that describes detailed informations about battery sensor functions.
I was wondering if there be any detail code for this that can be referenced. For example, how the battery state-of-charge be calculated using mm912j637 etc.
Solved! Go to Solution.
The first evaluation of the SOC is the Coulomb Counting formula, you can find this formula in page 7 of the DWF13_AMF_AUT_T1043.pdf document: http://cache.freescale.com/files/training/doc/dwf/DWF13_AMF_AUT_T1043.pdf
The MM912_637 and MM9Z1_638 are embedding an internal Coulomb Counter that might be use while into low power mode to minimize the overall current consumption of the product.
Another way to compute the SOC is to measure the Voltage of the Battery while into open condition (Open Circuit Voltage - OCV) as it is linked to the SOC.
OCV = f(SOC)
This equation is related to the battery to monitor. This data should be available at Battery Manufacturer.
The attached software “QuIBS V5 Nobember 2011.zip”, could be a good code example project for MM912J637, it includes most the basic features.
Jose Reyes
I get it! Thanks for your patience Jose.
OCV = f(SOC)
Jose Reyes
Hi Jose, I'm starting kit912j637 with your example project. When i debug, it have error. Please show me how to solve it. Thanks for your help.
Best Regards!
Tahi.
