Sensor Fusion on i.MX RT1170
VassiliN
I have i.MX RT1170 evaluation at the moment and trying to figure out how to integrate Sensor Fusion to the board. My understanding that  Sensor Fusion has a built-in support for some other boards, mostly Freedom for Kinetis.
So my question is: can Sensor Fusion be mapped/ported to #i.MX RT1170
I could not find any info if the FXOS8700CQ sensor on i.MX RT1170 is compatible/complies with the requirements of the Sensor Fusion.
Is there any documents/guidelines for the Sensor Fusion porting?
Labels (2)
jennie258fitz
Thank you for helping people get the information they need. Great stuff as usual. Keep up the great work!!!
VassiliN
I see. If I use the RT1170+AGM01 SDK then Sensor Fusion is supported for the second board (AGM01), so I won't need to port it for the RT1170, right?
JozefKozon
Dear Vassili,
in the MCUXpresso is an SDK available for the RT1170+AGM01, which includes FXOS8700CQ.
For the porting of the SDK please follow the Getting Started guidance in this link: https://www.nxp.com/document/guide/getting-started-with-the-i-mx-rt1170-evaluation-kit:GS-MIMXRT1170...
With Best Regards,
Jozef
