Sensor Fusion on i.MX RT1170
1,777 次查看
VassiliN
I have i.MX RT1170 evaluation at the moment and trying to figure out how to integrate Sensor Fusion to the board. My understanding that  Sensor Fusion has a built-in support for some other boards, mostly Freedom for Kinetis.
So my question is: can Sensor Fusion be mapped/ported to #i.MX RT1170
I could not find any info if the FXOS8700CQ sensor on i.MX RT1170 is compatible/complies with the requirements of the Sensor Fusion.
Is there any documents/guidelines for the Sensor Fusion porting?
标签 (2)
1,490 次查看
jennie258fitz
Thank you for helping people get the information they need. Great stuff as usual. Keep up the great work!!!
1,700 次查看
VassiliN
I see. If I use the RT1170+AGM01 SDK then Sensor Fusion is supported for the second board (AGM01), so I won't need to port it for the RT1170, right?
1,722 次查看
JozefKozon
Dear Vassili,
in the MCUXpresso is an SDK available for the RT1170+AGM01, which includes FXOS8700CQ.
For the porting of the SDK please follow the Getting Started guidance in this link: https://www.nxp.com/document/guide/getting-started-with-the-i-mx-rt1170-evaluation-kit:GS-MIMXRT1170...
With Best Regards,
Jozef
