S32r45 sdk oal memory allocator
2,629件の閲覧回数
sinetech
hi everyone,
may I get detailed documentation on the oal_memory_allocator.c section of s32r45 sdk?The following issues were found during debugging.I need to know the Max memory limit,thanks!
log:
[WRN] [OAL_OS_AllocPhysicalMemory:68] Failed to allocate 0x180040 bytes from chunk 1 [WRN] [allocPhysMem:97] Failed to allocate physical memory [WRN] [allocMemoryArea:491] Failed to allocate physical memory OAL memory allocation failed, unit 3
2,566件の閲覧回数
petervlna
The error seems clear: "Failed to allocate 0x180040 bytes from chunk 1"
Maybe the CHUNK IDs are not obvious? That I agree. Those can be found in the app
app_mem_mgr.h
Peter
6 返答(返信)
2,590件の閲覧回数
petervlna
CHUNK 1 is SRAM.
S32R45 has 8MB of SRAM.
Peter
2,594件の閲覧回数
petervlna
Let me ask RSDK team and I will come back to you ASAP.
Peter
2,586件の閲覧回数
sinetech
hello petervlna,
I need the OAL detailed documentation because I use OAL frequently, and I spend a lot of time when errors occur.thanks!
Ray
2,567件の閲覧回数
petervlna
app_mem_mgr.h
Peter
2,552件の閲覧回数
sinetech
hello Peter,
I already know the define of CHUNK ID in app_mem_mgr.h. But I face this error often, even though the request size is 512K that less than 8M SRAM size.
Running Range FFT Kernel...[WRN] [OAL_OS_AllocPhysicalMemory:68] Failed to allocate 0x80000 bytes from chunk 1
AppMemAllocBuffer: failed to alloc 524288 bytes.
Ray
2,521件の閲覧回数
petervlna
Without knowing what app are you running ( if it is RSDK or custom) and what RSDK is used, the only assumption I can make is that memory is allocated in SRAM but not properly deallocated so after a few iterations, the error occurs because there is no more available space in that chunk
 As for documentation, apart from what is in the user manual, the source code is available for OAL. Other than that I'm not aware of other, more detailed documentation.
Peter
%3CLINGO-SUB%20id%3D%22lingo-sub-1986538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32r45%20sdk%20oal%20%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%82%A2%E3%83%AD%E3%82%B1%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1986538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%AD%E3%81%88%E7%9A%86%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3ES32R45%20SDK%E3%81%AEoal_memory_allocator.c%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%A9%B3%E7%B4%B0%E3%81%AA%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E4%B8%AD%E3%81%AB%E6%AC%A1%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%9C%80%E5%A4%A7%E3%83%A1%E3%83%A2%E3%83%AA%E5%88%B6%E9%99%90%E3%82%92%E7%9F%A5%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86!%3C%2FP%3E%3CP%3E%E4%B8%B8%E5%A4%AA%EF%BC%9A%3C%2FP%3E%3CDIV%3E%3CDIV%20class%3D%22%22%3E%5BWRN%E3%81%AE%5D(OAL_OS_AllocPhysicalMemory%3A68)%E3%83%81%E3%83%A3%E3%83%B3%E3%82%AF%201%20%E3%81%8B%E3%82%89%200x180040%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%5BWRN%5D%20%5BallocPhysMem%3A97%5D%20%E7%89%A9%E7%90%86%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%5BWRN%5D%20%5BallocMemoryArea%3A491%5D%20%E7%89%A9%E7%90%86%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20OAL%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%203%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1991628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AS32r45%20sdk%20oal%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%A2%E3%83%AD%E3%82%B1%E3%83%BC%E3%82%BF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1991628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%E3%80%81%3CBR%20%2F%3E%E7%A7%81%E3%81%AF%E3%81%99%E3%81%A7%E3%81%ABapp_mem_mgr.h%E3%81%AECHUNK%20ID%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%82%92%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C512K%E3%81%A7%E3%80%81SRAM%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C8M%E6%9C%AA%E6%BA%80%E3%81%A7%E3%81%82%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E3%82%88%E3%81%8F%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%AE%9F%E8%A1%8C%E7%AF%84%E5%9B%B2%20FFT%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB...%5BWRN%E3%81%AE%5D(OAL_OS_AllocPhysicalMemory%3A68)%E3%83%81%E3%83%A3%E3%83%B3%E3%82%AF%201%20%E3%81%8B%E3%82%89%200x80000%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5BWRN%E3%81%AE%5D%5BallocPhysMem%3A97%5D%E7%89%A9%E7%90%86%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5BWRN%E3%81%AE%5D%5BallocMemoryArea%3A491%5D%E7%89%A9%E7%90%86%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EAppMemAllocBuffer%3A%20524288%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E9%B1%8F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1988662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AS32r45%20sdk%20oal%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%A2%E3%83%AD%E3%82%B1%E3%83%BC%E3%82%BF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1988662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFPetervlna%E3%80%81%3CBR%20%2F%3E%E7%A7%81%E3%81%AFOAL%E3%82%92%E9%A0%BB%E7%B9%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%A8%E5%A4%9A%E3%81%8F%E3%81%AE%E6%99%82%E9%96%93%E3%82%92%E8%B2%BB%E3%82%84%E3%81%99%E3%81%9F%E3%82%81%E3%80%81OAL%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AA%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E9%B1%8F%3C%2FLINGO-BODY%3E
