NTM88
NTM88
dongyong1
Hi NXP Engineer I would like to know if I can burn the APS library when I burn the bootloader. Thank you for your help.
guoweisun
能否再说下您的问题,没看太明白?
dongyong1
就是客户这边做售后市场,希望把BOOT和一些库一起烧进去。然后在他们客户安装的时候烧个APP就行。这样有什么方案吗?
guoweisun
讨论下您的这个需求目前我们还没有对应的方案。
dongyong1
或者有没有可行的方法,可以先预埋进去。然后售后市场那边只烧应用。
%3CLINGO-SUB%20id%3D%22lingo-sub-1755993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENTM88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1755993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20NXP%20Engineer%20I%20would%20like%20to%20know%20if%20I%20can%20burn%20the%20APS%20library%20when%20I%20burn%20the%20bootloader.%20Thank%20you%20for%20your%20help.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1757994%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NTM88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1757994%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EOr%20is%20there%20a%20viable%20way%20to%20pre-build%20it%20in%20first.%20Then%20the%20aftermarket%20side%20only%20burns%20the%20application.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1756557%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NTM88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1756557%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EDiscuss%20this%20need%20of%20yours%20currently%20we%20have%20no%20corresponding%20program.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1756104%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NTM88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1756104%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EIt's%20the%20aftermarket%20on%20the%20customer's%20side%20that%20wants%20to%20burn%20in%20the%20BOOT%20along%20with%20some%20libraries.%20Then%20just%20burn%20an%20app%20when%20their%20customer%20installs%20it.%20Is%20there%20any%20program%20like%20this%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1756091%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NTM88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1756091%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3ECan%20you%20repeat%20your%20question%2C%20didn't%20quite%20read%20it%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
