FXLS8964AF
FXLS8964AF
DivyaN
Please let us know what are the IIH (Input Current High) and IIL (Input Current Low) [ i.e the leakage current value when the pin is set to an input and is driven high or low] for the GPIOs and I2C interfaces as we do not find it in datasheet.
Thank you,
Divya.N
guoweisun
There is no any current value spec under VIH/VIL test result, only VOH/VOL spec will identify such test current value.
DivyaN
Hi    Guoweisun,
Thank you for your immediate reply.
We need this value for load analysis. Could you please let us know " What is the leakage current of a GPIO pins when the pins are set as an input pin and is driven high or low.
Divya.N
%3CLINGO-SUB%20id%3D%22lingo-sub-1758106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFXLS8964AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1758106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EPlease%20let%20us%20know%20what%20are%20the%20IIH%20(Input%20Current%20High)%20and%20IIL%20(Input%20Current%20Low)%20%5B%20i.e%20the%20leakage%20current%20value%20when%20the%20pin%20is%20set%20to%20an%20input%20and%20is%20driven%20high%20or%20low%5D%20for%20the%20GPIOs%20and%20I2C%20interfaces%20as%20we%20do%20not%20find%20it%20in%20datasheet.%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you%2C%3C%2FP%3E%3CP%3EDivya.N%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1758232%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FXLS8964AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1758232%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%20%26nbsp%3B%20Guoweisun%2C%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20immediate%20reply.%3C%2FP%3E%3CP%3EWe%20need%20this%20value%20for%20load%20analysis.%20Could%20you%20please%20let%20us%20know%20%22%20What%20is%20the%20leakage%20current%20of%20a%20GPIO%20pins%20when%20the%20pins%20are%20set%20as%20an%20input%20pin%20and%20is%20driven%20high%20or%20low.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3EDivya.N%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1758124%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FXLS8964AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1758124%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThere%20is%20no%20any%20current%20value%20spec%20under%20VIH%2FVIL%20test%20result%2C%20only%20VOH%2FVOL%20spec%20will%20identify%20such%20test%20current%20value.%3C%2FP%3E%3C%2FLINGO-BODY%3E
