MPX2202A / MPX599D wiring problem
2,208 次查看
lucas_s
I bought MPX2202A Si Pressure Sensor in case 344-15. I have a big problem with connecting it properly as on p.8 of datasheet there are three styles of connection, which are very different from each other. Which style I should use? Same question about MPX5999D in case 867? Thank you in advance.
2,019 次查看
TomasVaverka
Hi Lucas,
The MPX2202A is a compensated pressure sensor with a differential output (+Vout and -Vout), so the pin description is as follows:
1 – GND
2 – +Vout
3 – Vs
4 – -Vout
The MPX599A is a fully integrated pressure sensor with a single ended output:
1 – Vout
2 – GND
3 – Vs
4 – V1
5 – V2
6 – VEX
V1, V2 and VEX pins are used for factory trimming and then they are laser cut. We recommend to leave these pins floating.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
2,019 次查看
lucas_s
Hi Tomas,
thank you very much, that was quick and accurate answer!
Kind regards, Lucas.
2,020 次查看
TomasVaverka
Hi Lucas,
1 – GND
2 – +Vout
3 – Vs
4 – -Vout
1 – Vout
2 – GND
3 – Vs
4 – V1
5 – V2
6 – VEX
Tomas
%3CLINGO-SUB%20id%3D%22lingo-sub-427348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPX2202A%20%2F%20MPX599D%20%E6%8E%A5%E7%BA%BF%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-427348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E4%B9%B0%E4%BA%86%20MPX2202A%20Si%20%E5%8E%8B%E5%8A%9B%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%8C%E8%A3%85%E5%9C%A8%20344-15%20%E5%8F%B7%E7%AE%B1%E5%AD%90%E9%87%8C%E3%80%82%E6%88%91%E5%9C%A8%E6%AD%A3%E7%A1%AE%E8%BF%9E%E6%8E%A5%E6%96%B9%E9%9D%A2%E9%81%87%E5%88%B0%E4%BA%86%E5%BE%88%E5%A4%A7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%9C%A8%E6%95%B0%E6%8D%AE%E8%A1%A8%E7%AC%AC%208%20%E9%A1%B5%E4%B8%8A%E6%9C%89%E4%B8%89%E7%A7%8D%E8%BF%9E%E6%8E%A5%E6%96%B9%E5%BC%8F%EF%BC%8C%E5%AE%83%E4%BB%AC%E4%B9%8B%E9%97%B4%E6%9C%89%E5%BE%88%E5%A4%A7%E7%9A%84%E4%B8%8D%E5%90%8C%E3%80%82%E6%88%91%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%E5%93%AA%E7%A7%8D%E9%A3%8E%E6%A0%BC%EF%BC%9F%E5%85%B3%E4%BA%8E%20867%20%E6%A1%88%E4%BE%8B%E4%B8%AD%E7%9A%84%20MPX5999D%EF%BC%8C%E4%B9%9F%E6%9C%89%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E5%9C%A8%E6%AD%A4%E5%85%88%E8%A1%A8%E7%A4%BA%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-427348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8E%8B%E5%8A%9B%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-427350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPX2202A%20%2F%20MPX599D%20wiring%20problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-427350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E6%89%98%E9%A9%AC%E6%96%AF%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%8C%E5%9B%9E%E7%AD%94%E5%BE%97%E5%8F%88%E5%BF%AB%E5%8F%88%E5%87%86%E7%A1%AE%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-427349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPX2202A%20%2F%20MPX599D%20wiring%20problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-427349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMPX2202A%20%E6%98%AF%E5%B8%A6%E5%B7%AE%E5%88%86%E8%BE%93%E5%87%BA%EF%BC%88%2BVout%20%E5%92%8C%20-Vout%EF%BC%89%E7%9A%84%E8%A1%A5%E5%81%BF%E5%8E%8B%E5%8A%9B%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%BC%95%E8%84%9A%E8%AF%B4%E6%98%8E%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22FR%22%3E1%20-%20%E6%8E%A5%E5%9C%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22FR%22%3E2%20-%20%2BVout%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22FR%22%3E3%20-%20Vs%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22FR%22%3E4%20-%20-Vout%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMPX599A%20%E6%98%AF%E4%B8%80%E6%AC%BE%E5%AE%8C%E5%85%A8%E9%9B%86%E6%88%90%E7%9A%84%E5%8E%8B%E5%8A%9B%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%8C%E5%85%B7%E6%9C%89%E5%8D%95%E7%AB%AF%E8%BE%93%E5%87%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22FR%22%3E1%20-%20Vout%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22FR%22%3E2%20-%20%E6%8E%A5%E5%9C%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22FR%22%3E3%20-%20Vs%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22FR%22%3E4%20-%20V1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22FR%22%3E5%20-%20V2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22FR%22%3E6%20-%20VEX%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EV1%E3%80%81V2%20%E5%92%8C%20VEX%20%E5%BC%95%E8%84%9A%E7%94%A8%E4%BA%8E%E5%B7%A5%E5%8E%82%E4%BF%AE%E6%95%B4%EF%BC%8C%E7%84%B6%E5%90%8E%E8%BF%9B%E8%A1%8C%E6%BF%80%E5%85%89%E5%88%87%E5%89%B2%E3%80%82%E6%88%91%E4%BB%AC%E5%BB%BA%E8%AE%AE%E5%B0%86%E8%BF%99%E4%BA%9B%E5%BC%95%E8%84%9A%E4%BF%9D%E6%8C%81%E6%B5%AE%E7%A9%BA%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%89%98%E9%A9%AC%E6%96%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20color%3A%20%23333333%3B%22%3E%3CEM%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011px%3B%20font-family%3A%20inherit%3B%20font-style%3A%20inherit%3B%22%3E%3CEM%3EPS%EF%BC%9A%3CSPAN%20class%3D%22Apple-converted-space%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22Apple-converted-space%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22Apple-converted-space%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3EI%3C%2FEM%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-size%3A%2011px%3B%20font-family%3A%20inherit%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%A6%82%E6%9E%9C%E6%88%91%E7%9A%84%E5%9B%9E%E7%AD%94%E6%9C%89%E5%8A%A9%E4%BA%8E%E8%A7%A3%E5%86%B3%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%A0%87%E8%AE%B0%E4%B8%BA%22%E6%AD%A3%E7%A1%AE%22%20%E3%80%82%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
