Which pin configuration applies for MPXv4006DP?
1,236 次查看
yishi
In MPXv4006DP's datasheet, on Page 8, which pin configuration applies for product MPXv4006DP? "STYLE 1" or "STYLE 2"?
Thanks!
标记 (2)
1 回复
1,024 次查看
TomasVaverka
Hi Yi,
The MPXV4006DP is an integrated pressure sensor with a single ended output, so Style 2 applies to this part.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
