MPX2010GP issue with voltage output
house_burn
Hi there,
I am using the MPX2010GP pressure sensor to measure drop in pressure from airflow across sports fabrics. We expect a pressure drop of around 100Pa. There is currently an issue with the analog voltage output from the Pin 2 of the sensor.
The datasheet says that at max rated gauge pressure of 10kPa the voltage output should be 25mV, but when measured using an RS PRO digital multi-meter I get a value of ~2.8V. The bench power supply used to provide the 10V to Pin 3 of the sensor is from TTI EL302 PSU 0-30V,2A. I have repeated this with another MPX2010GP to check the original is not faulty. Everything is connected using a breadboard and jumper wires for prototyping.
Please could someone let me know what the potential issue with sensor or set up is here.
Pin connections are:
Pin 1: (Power supply) GND
Pin 2: Multi-meter
Pin 3: +10V
Pin 4: GND
Thank you,
Sean
TomasVaverka
Hi Sean,
It seems you are measuring the voltage on +Vout (pin 2) with respect to GND.
However, this is not correct, you should measure the differential voltage between +Vout (pin 2) and -Vout (pin 4).
BR, Tomas
house_burn
Hi Tomas,
For the MPX2010GP it is a single gauge pressure sensor that I am looking to measure the pressure at a specific point, in this case where would the Pin 4 connect to as it is not a differential output.
Sean
TomasVaverka
Hi Sean,
Please see the answer on this topic from my colleague here.
BR, Tomas
%3CLINGO-SUB%20id%3D%22lingo-sub-1824604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPX2010GP%20issue%20with%20voltage%20output%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1824604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20there%2C%3C%2FP%3E%3CP%3EI%20am%20using%20the%20MPX2010GP%20pressure%20sensor%20to%20measure%20drop%20in%20pressure%20from%20airflow%20across%20sports%20fabrics.%20We%20expect%20a%20pressure%20drop%20of%20around%20100Pa.%20There%20is%20currently%20an%20issue%20with%20the%20analog%20voltage%20output%20from%20the%20Pin%202%20of%20the%20sensor.%26nbsp%3B%3C%2FP%3E%3CP%3EThe%20datasheet%20says%20that%20at%20max%20rated%20gauge%20pressure%20of%2010kPa%20the%20voltage%20output%20should%20be%2025mV%2C%20but%20when%20measured%20using%20an%20RS%20PRO%20digital%20multi-meter%20I%20get%20a%20value%20of%20~2.8V.%20The%20bench%20power%20supply%20used%20to%20provide%20the%2010V%20to%20Pin%203%20of%20the%20sensor%20is%20from%26nbsp%3BTTI%20EL302%20PSU%200-30V%2C2A.%20I%20have%20repeated%20this%20with%20another%20MPX2010GP%20to%20check%20the%20original%20is%20not%20faulty.%20Everything%20is%20connected%20using%20a%20breadboard%20and%20jumper%20wires%20for%20prototyping.%3C%2FP%3E%3CP%3EPlease%20could%20someone%20let%20me%20know%20what%20the%20potential%20issue%20with%20sensor%20or%20set%20up%20is%20here.%3C%2FP%3E%3CP%3EPin%20connections%20are%3A%3C%2FP%3E%3CP%3EPin%201%3A%20(Power%20supply)%20GND%3C%2FP%3E%3CP%3EPin%202%3A%20Multi-meter%3C%2FP%3E%3CP%3EPin%203%3A%20%2B10V%3C%2FP%3E%3CP%3EPin%204%3A%20GND%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you%2C%3C%2FP%3E%3CP%3ESean%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1824604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EPressure%20Sensors%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1825188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPX2010GP%20issue%20with%20voltage%20output%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1825188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHi%20Sean%2C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EPlease%20see%20the%20answer%20on%20this%20topic%20from%20my%20colleague%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FSensors%2FSetting-up-the-MPX2010DP-differential-pressure-transducer%2Fm-p%2F802535%22%20target%3D%22_self%22%3Ehere%3C%2FA%3E.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%2C%20Tomas%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1825177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPX2010GP%20issue%20with%20voltage%20output%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1825177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20Tomas%2C%3CBR%20%2F%3E%3CBR%20%2F%3EFor%20the%20MPX2010GP%20it%20is%20a%20single%20gauge%20pressure%20sensor%20that%20I%20am%20looking%20to%20measure%20the%20pressure%20at%20a%20specific%20point%2C%20in%20this%20case%20where%20would%20the%20Pin%204%20connect%20to%20as%20it%20is%20not%20a%20differential%20output.%3CBR%20%2F%3E%3CBR%20%2F%3EThanks%2C%3CBR%20%2F%3ESean%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1824940%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPX2010GP%20issue%20with%20voltage%20output%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1824940%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Sean%2C%3C%2FP%3E%0A%3CP%3EIt%20seems%20you%20are%20measuring%20the%20voltage%20on%20%2BVout%20(pin%202)%20with%20respect%20to%20GND.%3C%2FP%3E%0A%3CP%3EHowever%2C%20this%20is%20not%20correct%2C%20you%20should%20measure%20the%20differential%20voltage%20between%20%2BVout%20(pin%202)%20and%20-Vout%20(pin%204).%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Capture.JPG%22%20style%3D%22width%3A%20539px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Capture.JPG%22%20style%3D%22width%3A%20539px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F267500i4CF02D78841F9717%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Capture.JPG%22%20alt%3D%22Capture.JPG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECapture.JPG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%2C%20Tomas%3C%2FP%3E%3C%2FLINGO-BODY%3E
