MM9Z1_638 Microcontroller GPIOB Input Set Problem
5,260 次查看
mfatihkoseoglu
Hello All,
I'am programming MM9Z1_638 microcontroller. I set output and input PORTA, but i don't set input GPIOB.
I wrote this function:
void GPIOB_Init(void)
B_GPIO_CTL = (B_GPIO_CTL_PE1M_MASK |0);
B_GPIO_CTL = (B_GPIO_CTL_PE2M_MASK |0);
B_GPIO_CTL = (B_GPIO_CTL_PE3M_MASK |0);
B_GPIO_CTL = (B_GPIO_CTL_PE4M_MASK |0);
B_GPIO_CTL = (B_GPIO_CTL_DIR2M_MASK|0);
B_GPIO_CTL = (B_GPIO_CTL_PE2M_MASK |B_GPIO_CTL_PE2_MASK);
B_GPIO_CTL = (B_GPIO_CTL_DIR3M_MASK|0);
B_GPIO_CTL = (B_GPIO_CTL_PE3M_MASK |B_GPIO_CTL_PE3_MASK);
and i wath B_GPIO register and B_GPIO_CTL register is 0x0000.
Why cant i set port and how can i use this port?
5 回复数
5,245 次查看
StanoA
Hello Muhammed,
No problem, just note the B_GPIO_CTL register has different bit’s meaning from the commonly used standards.
The *_MASK bits block (“0”) or allow (“1”) to write value into data bit. So if you want to have all port’s bits accessible you need use:
B_GPIO_CTLH = (B_GPIO_CTLH_PE1M_MASK |   // enable write to PE1;
B_GPIO_CTLH_PE2M_MASK |   // enable write to PE2;
B_GPIO_CTLH_PE3M_MASK |   // enable write to PE3;
B_GPIO_CTLH_PE4M_MASK |   // enable write to PE4;
B_GPIO_CTLH_DIR1M_MASK |   // enable write to DIR1;
B_GPIO_CTLH_DIR2M_MASK |   // enable write to DIR2;
B_GPIO_CTLH_DIR3M_MASK);   // enable write to DIR3;
// and then write values to low byte of B_GPIO_CTLL register;
B_GPIO_CTLL = (B_GPIO_CTLL_PE1_MASK |   // PE1 enabled;
B_GPIO_CTLL_PE2_MASK |   // PE2 enabled;
B_GPIO_CTLL_PE3_MASK |   // PE3 enabled;
B_GPIO_CTLH_DIR1_MASK |   // PE1 as output;
B_GPIO_CTLH_DIR2_MASK |   // PE2 as output;
B_GPIO_CTLH_DIR3_MASK );    // PE3 as output;
Sorry I don’t have the board with MCU for test, but I hope my suggestion could help you.
Stano.
5,241 次查看
mfatihkoseoglu
Hello StanoA,
I tried the way you said but it is not work.
My init function:
Not: I want to use input GPIOB pins.
B_GPIO_CTLH = (B_GPIO_CTLH_PE1M_MASK | B_GPIO_CTLH_PE2M_MASK | B_GPIO_CTLH_PE3M_MASK | B_GPIO_CTLH_PE4M_MASK
| B_GPIO_CTLH_DIR1M_MASK | B_GPIO_CTLH_DIR2M_MASK | B_GPIO_CTLH_DIR2M_MASK);
B_GPIO_CTLL = (B_GPIO_CTLL_PE1_MASK | B_GPIO_CTLL_PE2_MASK | B_GPIO_CTLL_PE3_MASK | B_GPIO_CTLL_PE4_MASK);
After the work, B_GPIO_C register value is 0x0000.
My init function:
5,213 次查看
StanoA
Hello Muhammed,
Please reset the MCU in debug mode, set the breakpoint to line “for(;;) { …” and run the code. When it will stop on breakpoint read the variables:
value and value2.
This means select them in window:
And check the values.
Stano.
5,206 次查看
mfatihkoseoglu
Hello StanoA,
I reset mcu in debug mode and set break point in for loop, i see the all values is 0.
5,188 次查看
StanoA
Hello Muhammed,
I asked our specialist for help. The result is:
The port bit must be written together with their mask bit = 1.
If the associated mask bit = 0, the write is not allowed.
The masked bits (e.g. GPIO...PE1M and GPIO...PE1) have to be written in a single access. In this case as 16bit write. Please see the attached gpio.h file also for this example:
// enable PTB1 as output
B_GPIO_CTL = GPIO_CTL_PTB1_ENABLE | GPIO_CTL_PTB1_OUTPUT;
B_GPIO_OUT1 = OUT_PTBx;
// set PTB1
// clear PTB1
B_GPIO_OUT1 = 0;
Please see also this AN for this product:
https://www.nxp.com/docs/en/application-note/AN12301.pdf
I hope it could help you with your task.
Stano.
%3CLINGO-SUB%20id%3D%22lingo-sub-1342703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMM9Z1_638%20%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%20GPIOB%20%E8%BE%93%E5%85%A5%E8%AE%BE%E7%BD%AE%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1342703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E7%BB%99%20MM9Z1_638%20%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E7%BC%96%E7%A8%8B%E3%80%82%E6%88%91%E8%AE%BE%E7%BD%AE%E4%BA%86%E8%BE%93%E5%87%BA%E5%92%8C%E8%BE%93%E5%85%A5%20PORTA%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E8%AE%BE%E7%BD%AE%E8%BE%93%E5%85%A5%20GPIOB%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E4%B8%AA%E5%87%BD%E6%95%B0%E6%98%AF%E6%88%91%E5%86%99%E7%9A%84%EF%BC%9A%20%3C%2FP%3E%3CP%3Evoid%20GPIOB_Init(void)%3CBR%20%2F%3E%7B%3CBR%20%2F%3EB_GPIO_CTL%20%3D%20(B_GPIO_CTL_PE1M_MASK%20%7C0)%EF%BC%9B%3CBR%20%2F%3EB_GPIO_CTL%20%3D%20(B_GPIO_CTL_PE2M_MASK%20%7C0)%EF%BC%9B%3CBR%20%2F%3EB_GPIO_CTL%20%3D%20(B_GPIO_CTL_PE3M_MASK%20%7C0)%3B%3CBR%20%2F%3EB_GPIO_CTL%20%3D%20(B_GPIO_CTL_PE4M_MASK%20%7C0)%3B%3CBR%20%2F%3E%3CBR%20%2F%3EB_GPIO_CTL%20%3D%20(B_GPIO_CTL_PE1M_MASK%20%7C0)%EF%BC%9B%3CBR%20%2F%3E%3CBR%20%2F%3Eb_gpio_ctl%20%3D%20(b_gpio_ctl_dir2m_mask%7C0)%3B%3CBR%20%2F%3Eb_gpio_ctl%20%3D%20(b_gpio_ctl_pe2m_mask%20%7Cb_gpio_ctl_pe2_mask)%3B%3CBR%20%2F%3Eb_gpio_ctl%20%3D%20(b_gpio_ctl_dir3m_mask%7C0)%3B%3CBR%20%2F%3Eb_gpio_ctl%20%3D%20(b_gpio_ctl_pe3m_mask%20%7Cb_gpio_ctl_pe3_mask)%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mfatihkoseoglu_1-1632134275182.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mfatihkoseoglu_1-1632134275182.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F156504i9CD7439680AD8A44%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mfatihkoseoglu_1-1632134275182.png%22%20alt%3D%22mfatihkoseoglu_1-1632134275182.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mfatihkoseoglu_2-1632134289064.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mfatihkoseoglu_2-1632134289064.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F156505i1C4DBFCCE30E28CB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mfatihkoseoglu_2-1632134289064.png%22%20alt%3D%22mfatihkoseoglu_2-1632134289064.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E6%9F%A5%E7%9C%8B%E4%BA%86%20B_GPIO%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E5%8F%91%E7%8E%B0%20B_GPIO_CTL%20%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%BA%200x0000%E3%80%82%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E4%B8%8D%E8%83%BD%E8%AE%BE%E7%BD%AE%E7%AB%AF%E5%8F%A3%EF%BC%8C%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E8%AF%A5%E7%AB%AF%E5%8F%A3%EF%BC%9F%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mfatihkoseoglu_0-1632134256163.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mfatihkoseoglu_0-1632134256163.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F156503i180093A00507C206%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mfatihkoseoglu_0-1632134256163.png%22%20alt%3D%22mfatihkoseoglu_0-1632134256163.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1344005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MM9Z1_638%20Microcontroller%20GPIOB%20Input%20Set%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1344005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E7%A9%86%E7%BD%95%E9%BB%98%E5%BE%B7%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%90%91%E6%88%91%E4%BB%AC%E7%9A%84%E4%B8%93%E5%AE%B6%E6%B1%82%E5%8A%A9%E3%80%82%E7%BB%93%E6%9E%9C%E6%98%AF%3C%2FP%3E%0A%3CP%3E%E7%AB%AF%E5%8F%A3%E4%BD%8D%E5%BF%85%E9%A1%BB%E8%BF%9E%E5%90%8C%E5%85%B6%E5%B1%8F%E8%94%BD%E4%BD%8D%20%3D%201%20%E4%B8%80%E8%B5%B7%E5%86%99%E5%85%A5%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E7%9B%B8%E5%85%B3%E6%8E%A9%E7%A0%81%E4%BD%8D%20%3D%200%EF%BC%8C%E5%88%99%E4%B8%8D%E5%85%81%E8%AE%B8%E5%86%99%E5%85%A5%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B1%8F%E8%94%BD%E4%BD%8D%EF%BC%88%E4%BE%8B%E5%A6%82GPIO...PE1M%E5%92%8CGPIO...PE1%EF%BC%89%E5%BF%85%E9%A1%BB%E4%B8%80%E6%AC%A1%E6%80%A7%E5%86%99%E5%85%A5%E3%80%82%E5%9C%A8%E6%9C%AC%E4%BE%8B%E4%B8%AD%E4%B8%BA%2016%20%E4%BD%8D%E5%86%99%E5%85%A5%E3%80%82%E8%AF%B7%E5%8F%82%E8%A7%81%E6%89%80%E9%99%84%E7%9A%84%20gpio.h%E6%96%87%E4%BB%B6%E4%B9%9F%E9%80%82%E7%94%A8%E4%BA%8E%E6%9C%AC%E7%A4%BA%E4%BE%8B%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%2F%2F-------------------------------------------------%3C%2FP%3E%0A%3CP%3E%2F%2F%20%E5%90%AF%E7%94%A8%20PTB1%20%E4%BD%9C%E4%B8%BA%E8%BE%93%E5%87%BA%3C%2FP%3E%0A%3CP%3EB_GPIO_CTL%20%3D%20GPIO_CTL_PTB1_ENABLE%20%7C%20GPIO_CTL_PTB1_OUTPUT%3B%3CBR%20%2F%3EB_GPIO_OUT1%20%3D%20OUT_PTBx%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%2F%2F%20%E8%AE%BE%E7%BD%AE%20PTB1%3CBR%20%2F%3EB_GPIO_OUT1%20%3D%20OUT_PTBx%3B%3CBR%20%2F%3E%2F%2F%20%E6%B8%85%E9%99%A4%20PTB1%3CBR%20%2F%3EB_GPIO_OUT1%20%3D%200%EF%BC%9B%3C%2FP%3E%0A%3CP%3E%2F%2F----------------------------------------------------%3C%2FP%3E%0A%3CP%3E%E5%8F%A6%E8%AF%B7%E5%8F%82%E9%98%85%E8%AF%A5%E4%BA%A7%E5%93%81%E7%9A%84%20AN%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12301.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12301.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AE%83%E8%83%BD%E5%B8%AE%E5%8A%A9%E4%BD%A0%E5%AE%8C%E6%88%90%E4%BB%BB%E5%8A%A1%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E6%96%AF%E5%A1%94%E8%AF%BA%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1343788%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MM9Z1_638%20Microcontroller%20GPIOB%20Input%20Set%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1343788%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CStanoA%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E4%B8%8BRESET%E4%BA%86mcu%E5%B9%B6%E5%9C%A8for%E5%BE%AA%E7%8E%AF%E4%B8%AD%E8%AE%BE%E7%BD%AE%E4%BA%86%E6%96%AD%E7%82%B9%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%E6%89%80%E6%9C%89%E5%80%BC%E9%83%BD%E4%B8%BA0%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mfatihkoseoglu_0-1632295513346.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mfatihkoseoglu_0-1632295513346.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F156706i805F722042A807B0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mfatihkoseoglu_0-1632295513346.png%22%20alt%3D%22mfatihkoseoglu_0-1632295513346.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mfatihkoseoglu_1-1632295558725.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mfatihkoseoglu_1-1632295558725.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F156707i00EFDCE4B9A45FD2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mfatihkoseoglu_1-1632295558725.png%22%20alt%3D%22mfatihkoseoglu_1-1632295558725.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1343382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MM9Z1_638%20Microcontroller%20GPIOB%20Input%20Set%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1343382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E7%A9%86%E7%BD%95%E9%BB%98%E5%BE%B7%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%9C%A8%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E4%B8%8B%E9%87%8D%E7%BD%AE%20MCU%EF%BC%8C%E5%B0%86%E6%96%AD%E7%82%B9%E8%AE%BE%E7%BD%AE%E4%B8%BA%20%E2%80%9Cfor%20(%3B%3B)%20%7B...%E2%80%9D%20%E8%A1%8C%EF%BC%8C%E7%84%B6%E5%90%8E%E8%BF%90%E8%A1%8C%E4%BB%A3%E7%A0%81%E3%80%82%E5%BD%93%E6%96%AD%E7%82%B9%E5%81%9C%E6%AD%A2%E6%97%B6%EF%BC%8C%E8%AF%BB%E5%8F%96%E5%8F%98%E9%87%8F%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CEM%3E%E5%80%BC%3C%2FEM%3E%E5%92%8C%3CEM%3Evalue2%E3%80%82%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E5%9C%A8%E7%AA%97%E5%8F%A3%E4%B8%AD%E9%80%89%E6%8B%A9%E5%AE%83%E4%BB%AC%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22StanoA_0-1632239299914.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22StanoA_0-1632239299914.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F156618iE9FBFB24D109D6B1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22StanoA_0-1632239299914.png%22%20alt%3D%22StanoA_0-1632239299914.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B9%B6%E6%A3%80%E6%9F%A5%E6%95%B0%E5%80%BC%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E6%96%AF%E5%A1%94%E8%AF%BA%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1342804%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MM9Z1_638%20Microcontroller%20GPIOB%20Input%20Set%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1342804%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CStanoA%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E8%AF%95%E8%BF%87%E4%BD%A0%E8%AF%B4%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%8C%E4%BD%86%E4%B8%8D%E7%AE%A1%E7%94%A8%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E5%90%AF%E5%8A%A8%E5%87%BD%E6%95%B0%20%3C%2FP%3E%3CP%3E%E4%B8%8D%E6%98%AF%EF%BC%9A%E6%88%91%E6%83%B3%E4%BD%BF%E7%94%A8%E8%BE%93%E5%85%A5%20GPIOB%20%E5%BC%95%E8%84%9A%E3%80%82%20%3C%2FP%3E%3CP%3Evoid%20GPIOB_Init(void)%3CBR%20%2F%3E%7B%3CBR%20%2F%3EB_GPIO_CTLH%20%3D%20(B_GPIO_CTLH_PE1M_MASK%20%7C%20B_GPIO_CTLH_PE2M_MASK%20%7C%20B_GPIO_CTLH_PE3M_MASK%7C%20b_gpio_ctlh_pe4m_mask%3CBR%20%2F%3E%7C%20b_gpio_ctlh_dir1m_mask%20%7C%20b_gpio_ctlh_dir2m_mask%20%7C%20b_gpio_ctlh_dir2m_mask)%EF%BC%9B%3CBR%20%2F%3Eb_gpio_ctll%20%3D%20(b_gpio_ctll_pe1_mask%20%7C%20b_gpio_ctll_pe2_mask%20%7C%20b_gpio_ctll_pe3_mask%20%7C%20b_gpio_ctll_pe4_mask)%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%E5%B7%A5%E4%BD%9C%E5%AE%8C%E6%88%90%E5%90%8E%EF%BC%8CB_GPIO_C%20%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E5%80%BC%E4%B8%BA%200x0000%E3%80%82%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mfatihkoseoglu_0-1632148309820.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mfatihkoseoglu_0-1632148309820.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F156516i2F5960577C24B4A7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mfatihkoseoglu_0-1632148309820.png%22%20alt%3D%22mfatihkoseoglu_0-1632148309820.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E7%9A%84%E5%90%AF%E5%8A%A8%E5%87%BD%E6%95%B0%20%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mfatihkoseoglu_1-1632148344518.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mfatihkoseoglu_1-1632148344518.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F156517iAEE595480915A974%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mfatihkoseoglu_1-1632148344518.png%22%20alt%3D%22mfatihkoseoglu_1-1632148344518.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1342796%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MM9Z1_638%20Microcontroller%20GPIOB%20Input%20Set%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1342796%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E7%A9%86%E7%BD%95%E9%BB%98%E5%BE%B7%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%B2%A1%E9%97%AE%E9%A2%98%EF%BC%8C%E5%8F%AA%E9%9C%80%E6%B3%A8%E6%84%8F%20B_GPIO_CTL%20%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E4%BD%8D%E5%90%AB%E4%B9%89%E4%B8%8E%E5%B8%B8%E7%94%A8%E6%A0%87%E5%87%86%E4%B8%8D%E5%90%8C%E3%80%82%3C%2FP%3E%0A%3CP%3E*_MASK%20%E4%BD%8D%E9%98%BB%E6%AD%A2%EF%BC%88%220%22%EF%BC%89%E6%88%96%E5%85%81%E8%AE%B8%EF%BC%88%221%22%EF%BC%89%E5%B0%86%E5%80%BC%E5%86%99%E5%85%A5%E6%95%B0%E6%8D%AE%E4%BD%8D%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%A6%82%E6%9E%9C%E8%A6%81%E8%AE%BF%E9%97%AE%E6%89%80%E6%9C%89%E7%AB%AF%E5%8F%A3%E7%9A%84%E4%BD%8D%EF%BC%8C%E5%B0%B1%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%22......%22%EF%BC%9A%3C%2FP%3E%0A%3CP%3Evoid%20GPIOB_Init(void)%3CBR%20%2F%3E%7B%3CBR%20%2F%3EB_GPIO_CTLH%20%3D%20(B_GPIO_CTLH_PE1M_MASK%20%7C%20%2F%2F%20enable%20write%20to%20PE1%EF%BC%9B%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLH_PE2M_MASK%20%7C%20%2F%2F%20%E5%90%AF%E7%94%A8%E5%AF%B9%20PE2%20%E7%9A%84%E5%86%99%E5%85%A5%EF%BC%9B%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLH_PE3M_MASK%20%7C%20%2F%2F%20%E5%90%AF%E7%94%A8%E5%AF%B9%20PE3%20%E7%9A%84%E5%86%99%E5%85%A5%EF%BC%9B%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLH_PE4M_MASK%20%7C%20%2F%2F%20%E5%90%AF%E7%94%A8%E5%AF%B9%20PE4%20%E7%9A%84%E5%86%99%E5%85%A5%EF%BC%9B%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLH_DIR1M_MASK%20%7C%20%2F%2F%20%E5%90%AF%E7%94%A8%E5%AF%B9%20DIR1%20%E7%9A%84%E5%86%99%E5%85%A5%EF%BC%9B%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLH_DIR2M_MASK%20%7C%20%2F%2F%20%E5%90%AF%E7%94%A8%E5%AF%B9%20DIR2%20%E7%9A%84%E5%86%99%E5%85%A5%EF%BC%9B%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLH_DIR3M_MASK)%3B%20%2F%2F%20%E5%90%AF%E7%94%A8%E5%AF%B9%20DIR3%20%E7%9A%84%E5%86%99%E5%85%A5%EF%BC%9B%3C%2FP%3E%0A%3CP%3E%2F%2F%E7%84%B6%E5%90%8E%E5%B0%86%E5%80%BC%E5%86%99%E5%85%A5%20B_GPIO_CTLL%20%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E4%BD%8E%E5%AD%97%E8%8A%82%EF%BC%9B%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLL%20%3D%20(B_GPIO_CTLL_PE1_MASK%20%7C%20%2F%2F%20PE1%20%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%9B%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLL_PE2_MASK%20%7C%20%2F%2F%20PE2%20%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%9B%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLL_PE3_MASK%20%7C%20%2F%2F%20PE3%20%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%9B%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLH_DIR1_MASK%20%7C%20%2F%2F%20PE1%20%E4%BD%9C%E4%B8%BA%E8%BE%93%E5%87%BA%EF%BC%9B%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLH_DIR2_MASK%20%7C%20%2F%2F%20PE2%20%E4%BD%9C%E4%B8%BA%E8%BE%93%E5%87%BA%EF%BC%9B%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLH_DIR3_MASK%20)%3B%20%2F%2F%20PE3%20%E4%BD%9C%E4%B8%BA%E8%BE%93%E5%87%BA%EF%BC%9B%3C%2FP%3E%0A%3CP%3E%7D%3C%2FP%3E%0A%3CP%3E%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E5%B8%A6%E6%9C%89%20MCU%20%E7%9A%84%E4%B8%BB%E6%9D%BF%E5%8F%AF%E4%BE%9B%E6%B5%8B%E8%AF%95%EF%BC%8C%E4%BD%86%E6%88%91%E5%B8%8C%E6%9C%9B%E6%88%91%E7%9A%84%E5%BB%BA%E8%AE%AE%E8%83%BD%E5%B8%AE%E5%8A%A9%E4%BD%A0%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E6%96%AF%E5%A1%94%E8%AF%BA%3C%2FP%3E%3C%2FLINGO-BODY%3E
