MM9Z1_638 Microcontroller GPIOB Input Set Problem
5,339件の閲覧回数
mfatihkoseoglu
Hello All,
I'am programming MM9Z1_638 microcontroller. I set output and input PORTA, but i don't set input GPIOB.
I wrote this function:
void GPIOB_Init(void)
B_GPIO_CTL = (B_GPIO_CTL_PE1M_MASK |0);
B_GPIO_CTL = (B_GPIO_CTL_PE2M_MASK |0);
B_GPIO_CTL = (B_GPIO_CTL_PE3M_MASK |0);
B_GPIO_CTL = (B_GPIO_CTL_PE4M_MASK |0);
B_GPIO_CTL = (B_GPIO_CTL_DIR2M_MASK|0);
B_GPIO_CTL = (B_GPIO_CTL_PE2M_MASK |B_GPIO_CTL_PE2_MASK);
B_GPIO_CTL = (B_GPIO_CTL_DIR3M_MASK|0);
B_GPIO_CTL = (B_GPIO_CTL_PE3M_MASK |B_GPIO_CTL_PE3_MASK);
and i wath B_GPIO register and B_GPIO_CTL register is 0x0000.
Why cant i set port and how can i use this port?
5 返答(返信)
5,324件の閲覧回数
StanoA
Hello Muhammed,
No problem, just note the B_GPIO_CTL register has different bit’s meaning from the commonly used standards.
The *_MASK bits block (“0”) or allow (“1”) to write value into data bit. So if you want to have all port’s bits accessible you need use:
B_GPIO_CTLH = (B_GPIO_CTLH_PE1M_MASK |   // enable write to PE1;
B_GPIO_CTLH_PE2M_MASK |   // enable write to PE2;
B_GPIO_CTLH_PE3M_MASK |   // enable write to PE3;
B_GPIO_CTLH_PE4M_MASK |   // enable write to PE4;
B_GPIO_CTLH_DIR1M_MASK |   // enable write to DIR1;
B_GPIO_CTLH_DIR2M_MASK |   // enable write to DIR2;
B_GPIO_CTLH_DIR3M_MASK);   // enable write to DIR3;
// and then write values to low byte of B_GPIO_CTLL register;
B_GPIO_CTLL = (B_GPIO_CTLL_PE1_MASK |   // PE1 enabled;
B_GPIO_CTLL_PE2_MASK |   // PE2 enabled;
B_GPIO_CTLL_PE3_MASK |   // PE3 enabled;
B_GPIO_CTLH_DIR1_MASK |   // PE1 as output;
B_GPIO_CTLH_DIR2_MASK |   // PE2 as output;
B_GPIO_CTLH_DIR3_MASK );    // PE3 as output;
Sorry I don’t have the board with MCU for test, but I hope my suggestion could help you.
Stano.
5,320件の閲覧回数
mfatihkoseoglu
Hello StanoA,
I tried the way you said but it is not work.
My init function:
Not: I want to use input GPIOB pins.
B_GPIO_CTLH = (B_GPIO_CTLH_PE1M_MASK | B_GPIO_CTLH_PE2M_MASK | B_GPIO_CTLH_PE3M_MASK | B_GPIO_CTLH_PE4M_MASK
| B_GPIO_CTLH_DIR1M_MASK | B_GPIO_CTLH_DIR2M_MASK | B_GPIO_CTLH_DIR2M_MASK);
B_GPIO_CTLL = (B_GPIO_CTLL_PE1_MASK | B_GPIO_CTLL_PE2_MASK | B_GPIO_CTLL_PE3_MASK | B_GPIO_CTLL_PE4_MASK);
After the work, B_GPIO_C register value is 0x0000.
My init function:
5,292件の閲覧回数
StanoA
Hello Muhammed,
Please reset the MCU in debug mode, set the breakpoint to line “for(;;) { …” and run the code. When it will stop on breakpoint read the variables:
value and value2.
This means select them in window:
And check the values.
Stano.
5,285件の閲覧回数
mfatihkoseoglu
Hello StanoA,
I reset mcu in debug mode and set break point in for loop, i see the all values is 0.
5,267件の閲覧回数
StanoA
Hello Muhammed,
I asked our specialist for help. The result is:
The port bit must be written together with their mask bit = 1.
If the associated mask bit = 0, the write is not allowed.
The masked bits (e.g. GPIO...PE1M and GPIO...PE1) have to be written in a single access. In this case as 16bit write. Please see the attached gpio.h file also for this example:
// enable PTB1 as output
B_GPIO_CTL = GPIO_CTL_PTB1_ENABLE | GPIO_CTL_PTB1_OUTPUT;
B_GPIO_OUT1 = OUT_PTBx;
// set PTB1
// clear PTB1
B_GPIO_OUT1 = 0;
Please see also this AN for this product:
https://www.nxp.com/docs/en/application-note/AN12301.pdf
I hope it could help you with your task.
Stano.
%3CLINGO-SUB%20id%3D%22lingo-sub-1342703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMM9Z1_638%20%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%20GPIOB%20%E5%85%A5%E5%8A%9B%E8%A8%AD%E5%AE%9A%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1342703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%9A%86%E3%81%95%E3%82%93%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%3CP%3EMM9Z1_638%20%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%87%BA%E5%8A%9B%E3%81%A8%E5%85%A5%E5%8A%9B%20PORTA%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%85%A5%E5%8A%9B%20GPIOB%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E9%96%A2%E6%95%B0%E3%82%92%E6%9B%B8%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FP%3E%3CP%3Evoid%20GPIOB_Init(void)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20B_GPIO_CTL%20%3D%20(B_GPIO_CTL_PE1M_MASK%20%7C0)%3B%3CBR%20%2F%3E%20B_GPIO_CTL%20%3D%20(B_GPIO_CTL_PE2M_MASK%20%7C0)%3B%3CBR%20%2F%3E%20B_GPIO_CTL%20%3D%20(B_GPIO_CTL_PE3M_MASK%20%7C0)%3B%3CBR%20%2F%3E%20B_GPIO_CTL%20%3D%20(B_GPIO_CTL_PE4M_MASK%20%7C0)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20B_GPIO_CTL%20%3D%20(B_GPIO_CTL_PE1M_MASK%20%7C0)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20B_GPIO_CTL%20%3D%20(B_GPIO_CTL_DIR2M_MASK%7C0)%3B%3CBR%20%2F%3E%20B_GPIO_CTL%20%3D%20(B_GPIO_CTL_PE2M_MASK%20%7C%20B_GPIO_CTL_PE2_MASK)%3B%3CBR%20%2F%3E%20B_GPIO_CTL%20%3D%20(B_GPIO_CTL_DIR3M_MASK%7C0)%3B%3CBR%20%2F%3E%20B_GPIO_CTL%20%3D%20(B_GPIO_CTL_PE3M_MASK%20%7C%20B_GPIO_CTL_PE3_MASK)%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mfatihkoseoglu_1-1632134275182.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mfatihkoseoglu_1-1632134275182.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F156504i9CD7439680AD8A44%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mfatihkoseoglu_1-1632134275182.png%22%20alt%3D%22mfatihkoseoglu_1-1632134275182.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mfatihkoseoglu_2-1632134289064.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mfatihkoseoglu_2-1632134289064.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F156505i1C4DBFCCE30E28CB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mfatihkoseoglu_2-1632134289064.png%22%20alt%3D%22mfatihkoseoglu_2-1632134289064.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81B_GPIO%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%A8%20B_GPIO_CTL%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%200x0000%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%AA%E3%81%9C%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%20%E3%81%BE%E3%81%9F%E3%80%81%E3%81%93%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mfatihkoseoglu_0-1632134256163.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mfatihkoseoglu_0-1632134256163.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F156503i180093A00507C206%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mfatihkoseoglu_0-1632134256163.png%22%20alt%3D%22mfatihkoseoglu_0-1632134256163.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1344005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MM9Z1_638%20Microcontroller%20GPIOB%20Input%20Set%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1344005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%A0%E3%83%8F%E3%83%B3%E3%83%9E%E3%83%89%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B0%82%E9%96%80%E5%AE%B6%E3%81%AB%E5%8A%A9%E3%81%91%E3%82%92%E6%B1%82%E3%82%81%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%B5%90%E6%9E%9C%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AF%E3%80%81%E3%83%9E%E3%82%B9%E3%82%AF%20%E3%83%93%E3%83%83%E3%83%88%20%3D%201%20%E3%81%A8%E3%81%A8%E3%82%82%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%83%9E%E3%82%B9%E3%82%AF%20%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%200%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AF%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%9E%E3%82%B9%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9F%E3%83%93%E3%83%83%E3%83%88%EF%BC%88%E4%BE%8B%EF%BC%9AGPIO...PE1M%20%E3%81%8A%E3%82%88%E3%81%B3%20GPIO...PE1)%20%E3%81%AF%E3%80%811%20%E5%9B%9E%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AECASE%E3%81%AF16%E3%83%93%E3%83%83%E3%83%88%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%A8%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%B7%BB%E4%BB%98%E3%81%AEgpio.h%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%82%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%2F%2F-------------------------------------------------%3C%2FP%3E%0A%3CP%3E%2F%2F%20PTB1%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3C%2FP%3E%0A%3CP%3EB_GPIO_CTL%20%3D%20GPIO_CTL_PTB1_ENABLE%20%7C%20GPIO_CTL_PTB1_OUTPUT%3B%3CBR%20%2F%3E%20B_GPIO_OUT1%20%3D%20OUT_PTBx%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20PTB1%20%E3%82%92%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3EB_GPIO_OUT1%20%3D%20OUT_PTBx%3B%3CBR%20%2F%3E%20%2F%2F%20PTB1%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%3CBR%20%2F%3EB_GPIO_OUT1%20%3D%200%3B%3C%2FP%3E%0A%3CP%3E%2F%2F----------------------------------------------------%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E8%A3%BD%E5%93%81%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%81%A1%E3%82%89%E3%81%AEAN%E3%82%82%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12301.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12301.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%82%8C%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E4%BB%95%E4%BA%8B%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B9%E3%82%BF%E3%83%8E%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1343788%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MM9Z1_638%20Microcontroller%20GPIOB%20Input%20Set%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1343788%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81StanoA%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%20MCU%20%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%80%81for%20%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%20%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%80%A4%E3%81%8C%200%20%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mfatihkoseoglu_0-1632295513346.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mfatihkoseoglu_0-1632295513346.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F156706i805F722042A807B0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mfatihkoseoglu_0-1632295513346.png%22%20alt%3D%22mfatihkoseoglu_0-1632295513346.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mfatihkoseoglu_1-1632295558725.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mfatihkoseoglu_1-1632295558725.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F156707i00EFDCE4B9A45FD2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mfatihkoseoglu_1-1632295558725.png%22%20alt%3D%22mfatihkoseoglu_1-1632295558725.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1343382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MM9Z1_638%20Microcontroller%20GPIOB%20Input%20Set%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1343382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%A0%E3%83%8F%E3%83%B3%E3%83%9E%E3%83%89%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3EMCU%20%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%80%81%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E3%80%8Cfor(%3B%3B)%20%7B%20%E2%80%A6%E3%80%8D%E8%A1%8C%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E5%A4%89%E6%95%B0%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CEM%3E%E5%80%A4%3C%2FEM%3E%E3%81%A8%3CEM%3E%E5%80%A42%E3%80%82%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%A7%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22StanoA_0-1632239299914.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22StanoA_0-1632239299914.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F156618iE9FBFB24D109D6B1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22StanoA_0-1632239299914.png%22%20alt%3D%22StanoA_0-1632239299914.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E5%80%A4%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B9%E3%82%BF%E3%83%8E%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1342804%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MM9Z1_638%20Microcontroller%20GPIOB%20Input%20Set%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1342804%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81StanoA%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%A8%80%E3%82%8F%E3%82%8C%E3%81%9F%E9%80%9A%E3%82%8A%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AEinit%E9%96%A2%E6%95%B0%3A%3C%2FP%3E%3CP%3E%E6%B3%A8%E6%84%8F%3A%20%E5%85%A5%E5%8A%9B%20GPIOB%20%E3%83%94%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Evoid%20GPIOB_Init(void)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20B_GPIO_CTLH%20%3D%20(B_GPIO_CTLH_PE1M_MASK%20%7C%20B_GPIO_CTLH_PE2M_MASK%20%7C%20B_GPIO_CTLH_PE3M_MASK%20%7C%20B_GPIO_CTLH_PE4M_MASK%3CBR%20%2F%3E%20%7C%20B_GPIO_CTLH_DIR1M_MASK%20%7C%20B_GPIO_CTLH_DIR2M_MASK%20%7C%20B_GPIO_CTLH_DIR2M_MASK)%3B%3CBR%20%2F%3E%20B_GPIO_CTLL%20%3D%20(B_GPIO_CTLL_PE1_MASK%20%7C%20B_GPIO_CTLL_PE2_MASK%20%7C%20B_GPIO_CTLL_PE3_MASK%20%7C%20B_GPIO_CTLL_PE4_MASK)%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%E4%BD%9C%E6%A5%AD%E5%BE%8C%E3%80%81B_GPIO_C%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E5%80%A4%E3%81%AF0x0000%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mfatihkoseoglu_0-1632148309820.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mfatihkoseoglu_0-1632148309820.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F156516i2F5960577C24B4A7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mfatihkoseoglu_0-1632148309820.png%22%20alt%3D%22mfatihkoseoglu_0-1632148309820.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AEinit%E9%96%A2%E6%95%B0%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mfatihkoseoglu_1-1632148344518.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mfatihkoseoglu_1-1632148344518.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F156517iAEE595480915A974%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mfatihkoseoglu_1-1632148344518.png%22%20alt%3D%22mfatihkoseoglu_1-1632148344518.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1342796%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MM9Z1_638%20Microcontroller%20GPIOB%20Input%20Set%20Problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1342796%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%A0%E3%83%8F%E3%83%B3%E3%83%9E%E3%83%89%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82B_GPIO_CTL%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E6%84%8F%E5%91%B3%E3%81%AF%E3%80%81%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E6%A8%99%E6%BA%96%E3%81%A8%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E*_MASK%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AF%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%93%E3%83%83%E3%83%88%E3%81%B8%E3%81%AE%E5%80%A4%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%20(%E3%80%8C0%E3%80%8D)%20%E3%81%BE%E3%81%9F%E3%81%AF%E8%A8%B1%E5%8F%AF%20(%E3%80%8C1%E3%80%8D)%20%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3Evoid%20GPIOB_Init(void)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20B_GPIO_CTLH%20%3D%20(B_GPIO_CTLH_PE1M_MASK%20%7C%20%2F%2F%20PE1%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3B%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLH_PE2M_MASK%20%7C%20%2F%2F%20PE2%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLH_PE3M_MASK%20%7C%20%2F%2F%20PE3%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLH_PE4M_MASK%20%7C%20%2F%2F%20PE4%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLH_DIR1M_MASK%20%7C%20%2F%2F%20DIR1%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLH_DIR2M_MASK%20%7C%20%2F%2F%20DIR2%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLH_DIR3M_MASK)%3B%20%2F%2F%20DIR3%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%2F%2F%20%E6%AC%A1%E3%81%AB%E3%80%81B_GPIO_CTLL%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E4%B8%8B%E4%BD%8D%E3%83%90%E3%82%A4%E3%83%88%E3%81%AB%E5%80%A4%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLL%20%3D%20(B_GPIO_CTLL_PE1_MASK%20%7C%20%2F%2F%20PE1%20%E3%81%8C%E6%9C%89%E5%8A%B9%3B%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLL_PE2_MASK%20%7C%20%2F%2F%20PE2%20%E3%81%8C%E6%9C%89%E5%8A%B9%3B%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLL_PE3_MASK%20%7C%20%2F%2F%20PE3%20%E3%81%8C%E6%9C%89%E5%8A%B9%3B%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLH_DIR1_MASK%20%7C%20%2F%2F%20PE1%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6%3B%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLH_DIR2_MASK%20%7C%20%2F%2F%20PE2%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6%3B%3C%2FP%3E%0A%3CP%3EB_GPIO_CTLH_DIR3_MASK%20)%3B%20%2F%2F%20PE3%20%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%7D%3C%2FP%3E%0A%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E7%94%A8%E3%81%AE%20MCU%20%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AE%E6%8F%90%E6%A1%88%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B9%E3%82%BF%E3%83%8E%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
