MAG 3110 ctrl_reg2 reading issue.
nicolasdecroze
I try to use MAG3110 sensor with an arduino due board.
I have a problem when i want to write in the "Ctrl_reg2" register.
I want to write 0x80 in the register but when i read it (just to verify), the register value is 0x00...
I haven't this issue with ctrl_reg1.
Here ou can see the writing code :
       Wire.beginTransmission(MAG_ADDR);   // transmit to device 0x0E
       Wire.write(0x10);                   // ctrl register1
       Wire.write(0x00);                   // Standby
       Wire.endTransmission();             // stop transmitting
       delay(15);
       Wire.write(0x11);                   // ctrl register2
       Wire.write(0x80);                  // send 0x80, enable auto resets
Is there any special things to do with this register ?
Many thanks for the help.
nicolasdecroze
hi Tomas,
I'm really sorry for late reply but i had a big issue on another project so i hadn't a lot of time...
you  can see below my Arduino source code :
I can see if there is a mistake...
Many thanks for your help.
regards,
Nicolas.
#include <Wire.h>
#define MAG_ADDR  0x0E        // 7-bit address for the MAG3110, doesn't change
void setup()
  pinMode(38, INPUT);
  Serial.begin(115200);       // start serial for output
  Wire.begin();               // join i2c bus (address optional for master)
  config();                   // turn the MAG3110 on
void loop()
  if (digitalRead(38) == HIGH){
      print_values();
void config(void)
  delay(15);
  delay(15);
  Wire.write(0x30);                  // send 0x80, enable auto resets
  delay(15);
  Wire.write(0xC9);                   // send 0x01, active mode
void print_values(void)
  int LSB_MASK = 0x00FF;
    Serial.write(0x01);
    int16_t X_T = readx();
    Serial.write(X_T>>8);             // MSB
    Serial.write(X_T & LSB_MASK);     // LSB
    int16_t Y_T = ready();
    Serial.write(Y_T>>8);             // MSB
    Serial.write(Y_T & LSB_MASK);     // LSB
    int16_t Z_T = readz();
    Serial.write(Z_T>>8);             // MSB
    Serial.write(Z_T & LSB_MASK);     // LSB
    Serial.write(0x02);
//////////////////////////////// Read X /////////////////////////////////////
int16_t readx(void)
  byte xl = 0;
  byte xh = 0;                      // define the MSB and LSB
  int16_t xout = 0;
  Wire.write(0x01);                 // x MSB reg
  delayMicroseconds(2);             // needs at least 1.3us free time between start and stop
  Wire.requestFrom(MAG_ADDR, 1);    // request 1 byte
  while(Wire.available())           // slave may send less than requested
    xh = Wire.read();               // receive the byte
  Wire.write(0x02);                 // x LSB reg
    xl = Wire.read();               // receive the byte
  //xl = 0;                           // Ici on met le lsb à 0 pour éviter les fluctuations
  xout = (xl|(xh << 8));            // concatenate the MSB and LSB
  return xout;
//////////////////////////////// Read Y /////////////////////////////////////
int16_t ready(void)
  byte yl = 0;
  byte yh = 0;                   // define the MSB and LSB
  int16_t yout = 0;
  Wire.write(0x03);                     // y MSB reg
    yh = Wire.read();                   // receive the byte
  Wire.write(0x04);                     // y LSB reg
    yl = Wire.read();                   // receive the byte
  //yl = 0;                               // Ici on met le lsb à 0 pour éviter les fluctuations
  yout = (yl|(yh << 8));                // concatenate the MSB and LSB
  return yout;
//////////////////////////////// Read Z /////////////////////////////////////
int16_t readz(void)
  byte zl = 0;
  byte zh = 0;                   // define the MSB and LSB
  int16_t zout = 0;
  Wire.write(0x05);                     // z MSB reg
    zh = Wire.read();                   // receive the byte
  Wire.write(0x06);                     // z LSB reg
    zl = Wire.read();                   // receive the byte
  //zl = 0;                               // Ici on met le lsb à 0 pour éviter les fluctuations
  zout = (zl|(zh << 8));                // concatenate the MSB and LSB
  return zout;
//////////////////////////////// Read CTRL_REG_2 /////////////////////////////////////
byte readctrl2(void)
  byte CTRL2;                   // define the MSB and LSB
  Wire.write(0x11);                     // z MSB reg
    CTRL2 = Wire.read();                   // receive the byte
  return CTRL2;
//////////////////////////////// Read CTRL_REG_1 /////////////////////////////////////
byte readctrl1(void)
  byte CTRL1;                   // define the MSB and LSB
  Wire.write(0x10);                     // z MSB reg
    CTRL1 = Wire.read();                   // receive the byte
  return CTRL1;
TomasVaverka
Hi Nicolas,
This is correct behaviour, the AUTO_MRST_EN is a write-only bit and always reads back as 0.
Let me know if you have any other questions.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
nicolasdecroze
hi Tomas,
Sorry for late reply, i was in vacation :smileyhappy:
Many thanks for your help !
However i have one more question :
If RAW bit is 1, output data should be beetween -20000 and +20000 is that right?
Because when i put this bit to 1, output values are still beetween -32768 and +32768... is that normal ? or i have an issue in my software?
Nicolas
TomasVaverka
Hi Nicolas,
Having such big values is not normal, unless the device is exposed to strong magnetic fields. Could you please share here your source code and raw values you read from registers 0x01 – 0x06? There may be a problem with converting raw values to signed 16-bit numbers or with incorrect interpreting on output device (if used).
Tomas
%3CLINGO-SUB%20id%3D%22lingo-sub-500823%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMAG%203110%20ctrl_reg2%20reading%20issue.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-500823%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20try%20to%20use%20MAG3110%20sensor%20with%20an%20arduino%20due%20board.%3C%2FP%3E%3CP%3EI%20have%20a%20problem%20when%20i%20want%20to%20write%20in%20the%20%22Ctrl_reg2%22%20register.%3C%2FP%3E%3CP%3EI%20want%20to%20write%200x80%20in%20the%20register%20but%20when%20i%20read%20it%20(%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3Ejust%20to%20verify%3C%2FSPAN%3E)%2C%20the%20register%20value%20is%200x00...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20haven't%20this%20issue%20with%20ctrl_reg1.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHere%20ou%20can%20see%20the%20writing%20code%20%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Wire.beginTransmission(MAG_ADDR)%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20transmit%20to%20device%200x0E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Wire.write(0x10)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20ctrl%20register1%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Wire.write(0x00)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20Standby%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Wire.endTransmission()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20stop%20transmitting%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20delay(15)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Wire.beginTransmission(MAG_ADDR)%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20transmit%20to%20device%200x0E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Wire.write(0x11)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20ctrl%20register2%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Wire.write(0x80)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20send%200x80%2C%20enable%20auto%20resets%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Wire.endTransmission()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20stop%20transmitting%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIs%20there%20any%20special%20things%20to%20do%20with%20this%20register%20%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMany%20thanks%20for%20the%20help.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-500823%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EMagnetic%20Sensors%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-500827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MAG%203110%20ctrl_reg2%20reading%20issue.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-500827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%20Tomas%2C%3C%2FP%3E%3CP%3EI'm%20really%20sorry%20for%20late%20reply%20but%20i%20had%20a%20big%20issue%20on%20another%20project%20so%20i%20hadn't%20a%20lot%20of%20time...%3C%2FP%3E%3CP%3Eyou%26nbsp%3B%20can%20see%20below%20my%20Arduino%20source%20code%20%3A%3C%2FP%3E%3CP%3EI%20can%20see%20if%20there%20is%20a%20mistake...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMany%20thanks%20for%20your%20help.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eregards%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENicolas.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23include%20%3CWIRE.H%3E%3C%2FWIRE.H%3E%3C%2FP%3E%3CP%3E%23define%20MAG_ADDR%26nbsp%3B%200x0E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%207-bit%20address%20for%20the%20MAG3110%2C%20doesn't%20change%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Evoid%20setup()%3C%2FP%3E%3CP%3E%7B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20pinMode(38%2C%20INPUT)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20Serial.begin(115200)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20start%20serial%20for%20output%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.begin()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20join%20i2c%20bus%20(address%20optional%20for%20master)%3C%2FP%3E%3CP%3E%26nbsp%3B%20config()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20turn%20the%20MAG3110%20on%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Evoid%20loop()%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20if%20(digitalRead(38)%20%3D%3D%20HIGH)%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20print_values()%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7D%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Evoid%20config(void)%3C%2FP%3E%3CP%3E%7B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.beginTransmission(MAG_ADDR)%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20transmit%20to%20device%200x0E%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.write(0x10)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20ctrl%20register1%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.write(0x00)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20Standby%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.endTransmission()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20stop%20transmitting%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20delay(15)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.beginTransmission(MAG_ADDR)%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20transmit%20to%20device%200x0E%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.write(0x11)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20ctrl%20register2%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.write(0x80)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20send%200x80%2C%20enable%20auto%20resets%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.endTransmission()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20stop%20transmitting%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20delay(15)%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20Wire.beginTransmission(MAG_ADDR)%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20transmit%20to%20device%200x0E%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.write(0x11)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20ctrl%20register2%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.write(0x30)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20send%200x80%2C%20enable%20auto%20resets%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.endTransmission()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20stop%20transmitting%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20delay(15)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.beginTransmission(MAG_ADDR)%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20transmit%20to%20device%200x0E%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.write(0x10)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20ctrl%20register1%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.write(0xC9)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20send%200x01%2C%20active%20mode%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.endTransmission()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20stop%20transmitting%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Evoid%20print_values(void)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%20int%20LSB_MASK%20%3D%200x00FF%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Serial.write(0x01)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20int16_t%20X_T%20%3D%20readx()%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Serial.write(X_T%26gt%3B%26gt%3B8)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20MSB%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Serial.write(X_T%20%26amp%3B%20LSB_MASK)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20LSB%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20int16_t%20Y_T%20%3D%20ready()%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Serial.write(Y_T%26gt%3B%26gt%3B8)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20MSB%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Serial.write(Y_T%20%26amp%3B%20LSB_MASK)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20LSB%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20int16_t%20Z_T%20%3D%20readz()%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Serial.write(Z_T%26gt%3B%26gt%3B8)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20MSB%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Serial.write(Z_T%20%26amp%3B%20LSB_MASK)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20LSB%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Serial.write(0x02)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%20Read%20X%20%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eint16_t%20readx(void)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%20byte%20xl%20%3D%200%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20byte%20xh%20%3D%200%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20define%20the%20MSB%20and%20LSB%3C%2FP%3E%3CP%3E%26nbsp%3B%20int16_t%20xout%20%3D%200%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20Wire.beginTransmission(MAG_ADDR)%3B%20%2F%2F%20transmit%20to%20device%200x0E%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.write(0x01)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20x%20MSB%20reg%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.endTransmission()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20stop%20transmitting%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20delayMicroseconds(2)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20needs%20at%20least%201.3us%20free%20time%20between%20start%20and%20stop%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20Wire.requestFrom(MAG_ADDR%2C%201)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20request%201%20byte%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20while(Wire.available())%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20slave%20may%20send%20less%20than%20requested%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20xh%20%3D%20Wire.read()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20receive%20the%20byte%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20delayMicroseconds(2)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20needs%20at%20least%201.3us%20free%20time%20between%20start%20and%20stop%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20Wire.beginTransmission(MAG_ADDR)%3B%20%2F%2F%20transmit%20to%20device%200x0E%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.write(0x02)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20x%20LSB%20reg%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.endTransmission()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20stop%20transmitting%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20delayMicroseconds(2)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20needs%20at%20least%201.3us%20free%20time%20between%20start%20and%20stop%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20Wire.requestFrom(MAG_ADDR%2C%201)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20request%201%20byte%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20while(Wire.available())%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20slave%20may%20send%20less%20than%20requested%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20xl%20%3D%20Wire.read()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20receive%20the%20byte%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%2F%2Fxl%20%3D%200%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20Ici%20on%20met%20le%20lsb%20%C3%A0%200%20pour%20%C3%A9viter%20les%20fluctuations%3C%2FP%3E%3CP%3E%26nbsp%3B%20xout%20%3D%20(xl%7C(xh%20%26lt%3B%26lt%3B%208))%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20concatenate%20the%20MSB%20and%20LSB%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20return%20xout%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%20Read%20Y%20%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eint16_t%20ready(void)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%20byte%20yl%20%3D%200%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20byte%20yh%20%3D%200%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20define%20the%20MSB%20and%20LSB%3C%2FP%3E%3CP%3E%26nbsp%3B%20int16_t%20yout%20%3D%200%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20Wire.beginTransmission(MAG_ADDR)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20transmit%20to%20device%200x0E%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.write(0x03)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20y%20MSB%20reg%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.endTransmission()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20stop%20transmitting%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20delayMicroseconds(2)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20needs%20at%20least%201.3us%20free%20time%20between%20start%20and%20stop%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20Wire.requestFrom(MAG_ADDR%2C%201)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20request%201%20byte%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20while(Wire.available())%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20slave%20may%20send%20less%20than%20requested%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20yh%20%3D%20Wire.read()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20receive%20the%20byte%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20delayMicroseconds(2)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20needs%20at%20least%201.3us%20free%20time%20between%20start%20and%20stop%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20Wire.beginTransmission(MAG_ADDR)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20transmit%20to%20device%200x0E%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.write(0x04)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20y%20LSB%20reg%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.endTransmission()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20stop%20transmitting%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20delayMicroseconds(2)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20needs%20at%20least%201.3us%20free%20time%20between%20start%20and%20stop%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20Wire.requestFrom(MAG_ADDR%2C%201)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20request%201%20byte%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20while(Wire.available())%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20slave%20may%20send%20less%20than%20requested%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20yl%20%3D%20Wire.read()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20receive%20the%20byte%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%2F%2Fyl%20%3D%200%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20Ici%20on%20met%20le%20lsb%20%C3%A0%200%20pour%20%C3%A9viter%20les%20fluctuations%3C%2FP%3E%3CP%3E%26nbsp%3B%20yout%20%3D%20(yl%7C(yh%20%26lt%3B%26lt%3B%208))%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20concatenate%20the%20MSB%20and%20LSB%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20return%20yout%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%20Read%20Z%20%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eint16_t%20readz(void)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%20byte%20zl%20%3D%200%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20byte%20zh%20%3D%200%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20define%20the%20MSB%20and%20LSB%3C%2FP%3E%3CP%3E%26nbsp%3B%20int16_t%20zout%20%3D%200%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20Wire.beginTransmission(MAG_ADDR)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20transmit%20to%20device%200x0E%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.write(0x05)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20z%20MSB%20reg%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.endTransmission()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20stop%20transmitting%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20delayMicroseconds(2)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20needs%20at%20least%201.3us%20free%20time%20between%20start%20and%20stop%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20Wire.requestFrom(MAG_ADDR%2C%201)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20request%201%20byte%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20while(Wire.available())%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20slave%20may%20send%20less%20than%20requested%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20zh%20%3D%20Wire.read()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20receive%20the%20byte%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20delayMicroseconds(2)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20needs%20at%20least%201.3us%20free%20time%20between%20start%20and%20stop%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20Wire.beginTransmission(MAG_ADDR)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20transmit%20to%20device%200x0E%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.write(0x06)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20z%20LSB%20reg%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.endTransmission()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20stop%20transmitting%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20delayMicroseconds(2)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20needs%20at%20least%201.3us%20free%20time%20between%20start%20and%20stop%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20Wire.requestFrom(MAG_ADDR%2C%201)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20request%201%20byte%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20while(Wire.available())%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20slave%20may%20send%20less%20than%20requested%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20zl%20%3D%20Wire.read()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20receive%20the%20byte%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%2F%2Fzl%20%3D%200%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20Ici%20on%20met%20le%20lsb%20%C3%A0%200%20pour%20%C3%A9viter%20les%20fluctuations%3C%2FP%3E%3CP%3E%26nbsp%3B%20zout%20%3D%20(zl%7C(zh%20%26lt%3B%26lt%3B%208))%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20concatenate%20the%20MSB%20and%20LSB%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20return%20zout%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%20Read%20CTRL_REG_2%20%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ebyte%20readctrl2(void)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%20byte%20CTRL2%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20define%20the%20MSB%20and%20LSB%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.beginTransmission(MAG_ADDR)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20transmit%20to%20device%200x0E%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.write(0x11)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20z%20MSB%20reg%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.endTransmission()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20stop%20transmitting%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20delayMicroseconds(2)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20needs%20at%20least%201.3us%20free%20time%20between%20start%20and%20stop%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.requestFrom(MAG_ADDR%2C%201)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20request%201%20byte%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20while(Wire.available())%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20slave%20may%20send%20less%20than%20requested%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20CTRL2%20%3D%20Wire.read()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20receive%20the%20byte%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20return%20CTRL2%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%20Read%20CTRL_REG_1%20%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ebyte%20readctrl1(void)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%20byte%20CTRL1%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20define%20the%20MSB%20and%20LSB%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.beginTransmission(MAG_ADDR)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20transmit%20to%20device%200x0E%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.write(0x10)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20z%20MSB%20reg%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.endTransmission()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20stop%20transmitting%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20delayMicroseconds(2)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20needs%20at%20least%201.3us%20free%20time%20between%20start%20and%20stop%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20Wire.requestFrom(MAG_ADDR%2C%201)%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20request%201%20byte%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20while(Wire.available())%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20slave%20may%20send%20less%20than%20requested%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20CTRL1%20%3D%20Wire.read()%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20receive%20the%20byte%3C%2FP%3E%3CP%3E%26nbsp%3B%20%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%20return%20CTRL1%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-500826%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MAG%203110%20ctrl_reg2%20reading%20issue.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-500826%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Nicolas%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHaving%20such%20big%20values%20is%20not%20normal%2C%20unless%20the%20device%20is%20exposed%20to%20strong%20magnetic%20fields.%20Could%20you%20please%20share%20here%20your%20source%20code%20and%20raw%20values%20you%20read%20from%20registers%200x01%20%E2%80%93%200x06%3F%20There%20may%20be%20a%20problem%20with%20converting%20raw%20values%20to%20signed%2016-bit%20numbers%20or%20with%20incorrect%20interpreting%20on%20output%20device%20(if%20used).%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-500825%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MAG%203110%20ctrl_reg2%20reading%20issue.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-500825%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%20Tomas%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESorry%20for%20late%20reply%2C%20i%20was%20in%20vacation%20%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FP%3E%3CP%3EMany%20thanks%20for%20your%20help%20!%3C%2FP%3E%3CP%3EHowever%20i%20have%20one%20more%20question%20%3A%3C%2FP%3E%3CP%3EIf%20RAW%20bit%20is%201%2C%20output%20data%20should%20be%20beetween%20-20000%20and%20%2B20000%20is%20that%20right%3F%3C%2FP%3E%3CP%3EBecause%20when%20i%20put%20this%20bit%20to%201%2C%20output%20values%20are%20still%20beetween%20-32768%20and%20%2B32768...%20is%20that%20normal%20%3F%20or%20i%20have%20an%20issue%20in%20my%20software%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENicolas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-500824%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MAG%203110%20ctrl_reg2%20reading%20issue.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-500824%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Nicolas%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThis%20is%20correct%20behaviour%2C%20the%20AUTO_MRST_EN%20is%20a%20write-only%20bit%20and%20always%20reads%20back%20as%200.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20679px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F52176i6B7BC88774CFA5D7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3ELet%20me%20know%20if%20you%20have%20any%20other%20questions.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3ERegards%2C%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3ETomas%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3CEM%20style%3D%22font-size%3A%2011px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3EPS%3A%20If%20my%20answer%20helps%20to%20solve%20your%20question%2C%20please%20mark%20it%20as%20%22Correct%22.%20Thank%20you.%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
