Is the source code used for the MPR121EVM available?
larryo
I have an MPR121EVM KIT and I was wondering if the source code for the demo that is supplied with it is available. It would seem to be a nice starting point to further evaluate the MPR121 touch sensor.
If not the source code, is the binary available so that I can restore the demo application after I load my own program?
Larry
TomasVaverka
Hi Larry,
Unfortunately I do not have the source code that is embedded in the MC9S08QG8 that controls the MPR121 on the KITMPR121EVM.
I can only share the source code that is available for the TWRPI-MPR121 (TWR-SENSOR-PAK MPR121 plug-in module) or for the MPR121 breakout board.
I hope you will find it useful.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct" or “Helpful”. Thank you.
larryo
Hi Tomas,
Thanks for the reply.
Is there some way to restore the included application if I erase the one that ships in the device?
Larry
TomasVaverka
Hi Larry,
Yes, you can restore the original application using the KITMPR121EVM_Bootloader.s19 file that is located in the Bootloaders folder (C:\Program Files\Freescale\Sensor Toolbox\Bootloaders).
Tomas
larryo
Hi Tomas,
Actually I guess my real problem is that I cannot find any documentation on the Sensor Tool Box Application for the MPR121. The tutorial button is grayed out, the button for the documentation does not work,( a command prompt window opens then closes) and the help button just displays the generic quick start info.
I see that there are ERASE and UPDATE Firmware buttons on the application but is there some information on how this works? Is there a link that contains all of this information?
Larry
%3CLINGO-SUB%20id%3D%22lingo-sub-329108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIs%20the%20source%20code%20used%20for%20the%20MPR121EVM%20available%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-329108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20an%20MPR121EVM%20KIT%20and%20I%20was%20wondering%20if%20the%20source%20code%20for%20the%20demo%20that%20is%20supplied%20with%20it%20is%20available.%20It%20would%20seem%20to%20be%20a%20nice%20starting%20point%20to%20further%20evaluate%20the%20MPR121%20touch%20sensor.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIf%20not%20the%20source%20code%2C%20is%20the%20binary%20available%20so%20that%20I%20can%20restore%20the%20demo%20application%20after%20I%20load%20my%20own%20program%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELarry%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-329108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ETouch%20Sensors%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-329112%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Is%20the%20source%20code%20used%20for%20the%20MPR121EVM%20available%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-329112%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Tomas%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EActually%20I%20guess%20my%20real%20problem%20is%20that%20I%20cannot%20find%20any%20documentation%20on%20the%20Sensor%20Tool%20Box%20Application%20for%20the%20MPR121.%20The%20tutorial%20button%20is%20grayed%20out%2C%20the%20button%20for%20the%20documentation%20does%20not%20work%2C(%20a%20command%20prompt%20window%20opens%20then%20closes)%20and%20the%20help%20button%20just%20displays%20the%20generic%20quick%20start%20info.%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20see%20that%20there%20are%20ERASE%20and%20UPDATE%20Firmware%20buttons%20on%20the%20application%20but%20is%20there%20some%20information%20on%20how%20this%20works%3F%20Is%20there%20a%20link%20that%20contains%20all%20of%20this%20information%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELarry%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-329111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Is%20the%20source%20code%20used%20for%20the%20MPR121EVM%20available%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-329111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Larry%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYes%2C%20you%20can%20restore%20the%20original%20application%20using%20the%20KITMPR121EVM_Bootloader.s19%20file%20that%20is%20located%20in%20the%20Bootloaders%20folder%20(C%3A%5CProgram%20Files%5CFreescale%5CSensor%20Toolbox%5CBootloaders).%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-329110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Is%20the%20source%20code%20used%20for%20the%20MPR121EVM%20available%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-329110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Tomas%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20for%20the%20reply.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIs%20there%20some%20way%20to%20restore%20the%20included%20application%20if%20I%20erase%20the%20one%20that%20ships%20in%20the%20device%3F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELarry%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-329109%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Is%20the%20source%20code%20used%20for%20the%20MPR121EVM%20available%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-329109%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Larry%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-position%3A%20initial%3B%22%3EUnfortunately%20I%20do%20not%20have%20the%20source%20code%20that%20is%20embedded%20in%20the%20MC9S08QG8%20that%20controls%20the%20MPR121%20on%20the%20%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DKITMPR121EVM%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EKITMPR121EVM%3C%2FA%3E.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-position%3A%20initial%3B%22%3EI%20can%20only%20share%20the%20source%20code%20that%20is%20available%20for%20the%20TWRPI-MPR121%20(%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-position%3A%20initial%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DTWR-SENSOR-PAK%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ETWR-SENSOR-PAK%3C%2FA%3E%20MPR121%20plug-in%20module)%20or%20for%20the%20%3CA%20href%3D%22https%3A%2F%2Fwww.sparkfun.com%2Fproducts%2F9695%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMPR121%20breakout%20board%3C%2FA%3E.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-position%3A%20initial%3B%22%3EI%20hope%20you%20will%20find%20it%20useful.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-position%3A%20initial%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-position%3A%20initial%3B%22%3ERegards%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-position%3A%20initial%3B%22%3ETomas%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-position%3A%20initial%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-position%3A%20initial%3B%22%3E%3CEM%20style%3D%22font-family%3A%20Arial%2C%20sans-serif%3B%20color%3A%20%23333333%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-size%3A%2011px%3B%20font-family%3A%20inherit%3B%20color%3A%20%233d3d3d%3B%22%3E%3CEM%20style%3D%22font-weight%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3EPS%3A%3CSPAN%20class%3D%22Apple-converted-space%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22Apple-converted-space%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-size%3A%2011px%3B%20font-family%3A%20inherit%3B%20color%3A%20%233d3d3d%3B%22%3EIf%20my%20answer%20helps%20to%20solve%20your%20question%2C%20please%20mark%20it%20as%20%22Correct%22%20or%20%E2%80%9CHelpful%E2%80%9D.%20Thank%20you.%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
