How to detect the Direction and Angle using XZ-accelerometer Sensor
sakthivelkuland
Dear All,
I am using FXTH8719xxxx Family XZ axis Accelerometer Sensor. I need to find the direction as well how much angle turned by using X-axis ans Z Axis data. If any one can help me the possibility?
Each sensor Z-Axis have the different offset values, help me how to calibrate the Z-axis with the new sensor.
sakthivelkuland
hi Anthony,
I have one points to clarify,
what is the values for Z0 - Z base values, How to find the Z base values?
Sakthivel K
sakthivelkuland
Dear Anthony,
Thanks for your response. Your points are very helpful i'm collecting z-x axis data so i will apply your method if any points to clarify i get back to you.
Sakthivel K
anthonyduhamel
Hi Hulandaivel,
There are several methods to calibrate sensor offsets. The big limitation with an accelerometer is you need to do the calibration phase with quasi-static data. I mean: if you move the FXTH8719xxxx , you will add an acceleration vector on both axis (Z & X) and this will degrade/pervert the calibration... So you have to take care of the sensor rotation by doing very smooth motion (external acceleration should be very small compared to the 1g-force).
About calibration algorithms:
1. You can collect data/measurements around the circle in a buffer. When the full revolution is done, you compute the Z offset with an optimization method to minimize the standard deviation of the 1g vector on all measurements.
2. You can calculate the circle center with 3 points only. (Basic equations & resolution)
The final angle can be calulated with the following equation:
-Z0 the Z bias
- Z current / X current  are the actual measurements.
Note that these equations are only valid in a static model and are using the 1g gravitational force as reference.
I hope it helps.
Anthony
%3CLINGO-SUB%20id%3D%22lingo-sub-431447%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHow%20to%20detect%20the%20Direction%20and%20Angle%20using%20XZ-accelerometer%20Sensor%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-431447%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20All%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20am%20using%20FXTH8719xxxx%20Family%20XZ%20axis%20Accelerometer%20Sensor.%20I%20need%20to%20find%20the%20direction%20as%20well%20how%20much%20angle%20turned%20by%20using%20X-axis%20ans%20Z%20Axis%20data.%20If%20any%20one%20can%20help%20me%20the%20possibility%3F%3C%2FP%3E%3CP%3EEach%20sensor%20Z-Axis%20have%20the%20different%20offset%20values%2C%20help%20me%20how%20to%20calibrate%20the%20Z-axis%20with%20the%20new%20sensor.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-431447%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAccelerometers%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-431450%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20detect%20the%20Direction%20and%20Angle%20using%20XZ-accelerometer%20Sensor%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-431450%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%20Anthony%2C%3C%2FP%3E%3CP%3EI%20have%20one%20points%20to%20clarify%2C%3C%2FP%3E%3CP%3Ewhat%20is%20the%20values%20for%20Z0%20-%20Z%20base%20values%2C%20How%20to%20find%20the%20Z%20base%20values%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3ESakthivel%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-431449%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20detect%20the%20Direction%20and%20Angle%20using%20XZ-accelerometer%20Sensor%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-431449%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Anthony%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20for%20your%20response.%20Your%20points%20are%20very%20helpful%20i'm%20collecting%20z-x%20axis%20data%20so%20i%20will%20apply%20your%20method%20if%20any%20points%20to%20clarify%20i%20get%20back%20to%20you.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3ESakthivel%20K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-431448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20detect%20the%20Direction%20and%20Angle%20using%20XZ-accelerometer%20Sensor%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-431448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Hulandaivel%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThere%20are%20several%20methods%20to%20calibrate%20sensor%20offsets.%20The%20big%20limitation%20with%20an%20accelerometer%20is%20you%20need%20to%20do%20the%20calibration%20phase%20with%20quasi-static%20data.%20I%20mean%3A%20if%20you%20move%20the%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EFXTH8719xxxx%20%2C%20you%20will%20add%20an%20acceleration%20vector%20on%20both%20axis%20(Z%20%26amp%3B%20X)%20and%20this%20will%20degrade%2Fpervert%20the%20calibration...%20So%20you%20have%20to%20take%20care%20of%20the%20sensor%20rotation%20by%20doing%20very%20smooth%20motion%20(external%20acceleration%20should%20be%20very%20small%20compared%20to%20the%201g-force)%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3EAbout%20calibration%20algorithms%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E1.%20You%20can%20collect%20data%2Fmeasurements%20around%20the%20circle%20in%20a%20buffer.%20When%20the%20full%20revolution%20is%20done%2C%20you%20compute%20the%20Z%20offset%20with%20an%20optimization%20method%20to%20minimize%20the%20standard%20deviation%20of%20the%201g%20vector%20on%20all%20measurements.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22data.PNG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22data.PNG%22%20style%3D%22width%3A%20685px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F31831i04247435C2FAD4D5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22data.PNG%22%20alt%3D%22data.PNG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E2.%20You%20can%20calculate%20the%20circle%20center%20with%203%20points%20only.%20(Basic%20equations%20%26amp%3B%20resolution)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Capture.PNG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Capture.PNG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F31896iBBE3C55BCA3A5487%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Capture.PNG%22%20alt%3D%22Capture.PNG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E------%3C%2FP%3E%3CP%3EThe%20final%20angle%20can%20be%20calulated%20with%20the%20following%20equation%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Capture.PNG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Capture.PNG%22%20style%3D%22width%3A%20785px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F31946iD1972B2A3FBEF06E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Capture.PNG%22%20alt%3D%22Capture.PNG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E-Z0%20the%20Z%20bias%3C%2FP%3E%3CP%3E-%20Z%20current%20%2F%20X%20current%26nbsp%3B%20are%20the%20actual%20measurements.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENote%20that%20these%20equations%20are%20only%20valid%20in%20a%20static%20model%20and%20are%20using%20the%201g%20gravitational%20force%20as%20reference.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20hope%20it%20helps.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EAnthony%3C%2FP%3E%3C%2FLINGO-BODY%3E
