How to Find the transfer function of MPX5700AP
1,496 次查看
dengyong
     I can find the transfer function of differential pressure (kPa) in the datasheet,that is  Vout = VS*(0.0012858*P+0.04) ± Error . I think it is the transfer function of MPX5700DP . However I has applied MPX5700AP in my project, So Can you tell me how to find the transfer function of MPX5700AP.
     Thinks.
标记 (1)
1,241 次查看
TomasVaverka
Hi Deng,
The transfer function for MPX5700 is correct and the same for both absolute and Diff/Gauge for their respective pressure ranges.  The absolute version is reference to a vacuum whereas the Diff/Gauge are reference to either another pressure reference or vented (atmosphere).
Tomas
PS: If this answer helps to solve your question, please mark it as "Correct". Thank you.
1,241 次查看
dengyong
I‘v get it.Thanks to Tomas!
1,242 次查看
TomasVaverka
Hi Deng,
Tomas
