Hi. For to mount 06 sensor MPX599D i need the case 867-08 suffix A/D , please Do you have in sotck? in other wise can be ussue the other case 867C-05 suffix DP in case dont have one or other. You can send in Miami for more facilities. I live in LIMA - PER
1,400 次查看
angelgustavoval
En mi caso estoy usando sensores con 06 pines... una sola salida de presion positiva. P1
1,127 次查看
reyes
Hi Angel,
The only case/package presentation available for the MPX5999 is the 6-pin case 867-08 as appears on Page 6 of the MPX5999 datasheet, but, if you need a custom housing for this case, you can find recommendations and some suppliers in in the Application Note AN936.
About the availability of the MPX5999, you can find if there is availability directly in our web page, please click here to direct you to the buy page of the MPX5999.
Jose
