FXPS71407 change physaddr
6,346 次查看
gangli_hhh
Hi !
 I use the method in datasheet to change physaddr in otp, but it does not work. How could I change the physaddr in otp.
When the board power on, the physaddr is 0x0. Then I send a crm command 0x08180112 to change the physaddr to 0x1. I want physaddr keep 0x1 when the board reset. So I use the method in the datasheet below. The Lock_UF2 is 0, then I send crm command 0x18118a5b to write to the WRITE_OP_EN register. I can get the correct crm response. But then I send a crm command to read back the register value, I can not communicate with the board. And when I power off and on, the physaddr is still 0x0. How could I change the physaddr to 0x2 permanently?
Thanks!
6,247 次查看
RafaR
Hi gangli_weride
Can you please confirm the voltage applied to BUS_I during programming ?
It needs to be within 9-11V for at least 10ms after the register $11 write command.
10 回复数
6,292 次查看
gangli_hhh
Hi!
  Now I can change the physaddr by sending write $11 register data 0x8a. And the physaddr changed successfully!
  But after I reset, there is a u_otp_err error. And I can not clear this error by reading DEVSTAT2 register. Is there something wrong?
Thanks! Hope for you response!
6,248 次查看
RafaR
Hi gangli_weride
6,279 次查看
RafaR
Hi gangli_weride
Let me confirm with an expert on this device to have a definitive answer.
I will contact you soon
Have a great day and best of luck.
6,291 次查看
gangli_hhh
And why the u_otp_err happen? How could I clear this error?
6,224 次查看
gangli_hhh
Hi RafaR:
By the way, Could you show me how to clear u_otp_err in DEVSTAT2?
6,210 次查看
RafaR
Hi gangli_weride
I am still in contact with the expert, let me share the information with you.
“The U_OTP_ERR cannot be cleared as the memory is only One Time Programmable (i.e OTP).”
I hope this information has helped you
6,195 次查看
gangli_hhh
Hi RafaR
Thanks for your help!
If there is U_OTP_ERR in DEVSTAT2, is it meaning the chip is broken? Because U_OTP_ERR influences the pdcm data
And how could I avoid U_OTP_ERR when I write $11 register?
Thanks!
6,178 次查看
RafaR
Hi gangli
“if there is U_OTP_ERR in DEVSTAT2, is it meaning the chip is broken?”
I contacted the expert to see if there was any way to fix it but no.
“The device will remain definitively in that state.”
I hope this information has helped you.
6,328 次查看
RafaR
Hi gangli_weride
Could you check if the UF2 regions are not locked before and after the reset?, It seems to be exactly what is happening to you.
6,311 次查看
gangli_hhh
Before send crm 0x1811820c to write OTP:0x5f register data: 0x00, LOCK_UF2 was not set.
Sending crm 0x181182f8, response: 0x18820087. The crm was sending correctly.
After send crm 0x181182f8, I read 0x5f register, there is no response of crm 0x105f00f8, I can check the LOCK_UF2.
Thanks!
%3CLINGO-SUB%20id%3D%22lingo-sub-2020437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFXPS71407%20%E6%9B%B4%E6%94%B9%E7%89%A9%E7%90%86%E5%9C%B0%E5%9D%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2020437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20!%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8datasheet%E4%B8%AD%E7%9A%84%E6%96%B9%E6%B3%95%E5%8E%BB%E6%94%B9%E5%8F%98otp%E4%B8%AD%E7%9A%84physaddr%EF%BC%8C%E4%BD%86%E6%98%AF%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E6%88%91%E6%80%8E%E6%A0%B7%E6%89%8D%E8%83%BD%E6%9B%B4%E6%94%B9%20otp%20%E4%B8%AD%E7%9A%84%20physaddr%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E4%B8%BB%E6%9D%BF%E4%B8%8A%E7%94%B5%E6%97%B6%EF%BC%8Cphysaddr%20%E4%B8%BA%200x0%E3%80%82%E7%84%B6%E5%90%8E%E6%88%91%E5%8F%91%E9%80%81%E4%B8%80%E4%B8%AA%20crm%20%E5%91%BD%E4%BB%A4%200x08180112%20%E5%B0%86%20physaddr%20%E6%9B%B4%E6%94%B9%E4%B8%BA%200x1%E3%80%82%E6%88%91%E5%B8%8C%E6%9C%9B%E5%BD%93%E4%B8%BB%E6%9D%BF%E9%87%8D%E7%BD%AE%E6%97%B6%20physaddr%20%E4%BF%9D%E6%8C%81%200x1%E3%80%82%E6%89%80%E4%BB%A5%E6%88%91%E4%BD%BF%E7%94%A8%E4%B8%8B%E9%9D%A2%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%AD%E7%9A%84%E6%96%B9%E6%B3%95%E3%80%82Lock_UF2%E4%B8%BA0%EF%BC%8C%E7%84%B6%E5%90%8E%E6%88%91%E5%8F%91%E9%80%81crm%E5%91%BD%E4%BB%A40x18118a5b%E6%9D%A5%E5%86%99%E5%85%A5WRITE_OP_EN%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%E6%88%91%E5%8F%AF%E4%BB%A5%E5%BE%97%E5%88%B0%E6%AD%A3%E7%A1%AE%E7%9A%84%20crm%20%E5%93%8D%E5%BA%94%E3%80%82%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E5%8F%91%E9%80%81%20crm%20%E5%91%BD%E4%BB%A4%E6%9D%A5%E8%AF%BB%E5%9B%9E%E5%AF%84%E5%AD%98%E5%99%A8%E5%80%BC%E6%97%B6%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E4%B8%8E%E7%94%B5%E8%B7%AF%E6%9D%BF%E9%80%9A%E4%BF%A1%E3%80%82%E5%BD%93%E6%88%91%E5%85%B3%E9%97%AD%E5%B9%B6%E6%89%93%E5%BC%80%E7%94%B5%E6%BA%90%E6%97%B6%EF%BC%8Cphysaddr%20%E4%BB%8D%E7%84%B6%E6%98%AF%200x0%E3%80%82%E6%88%91%E6%80%8E%E6%A0%B7%E6%89%8D%E8%83%BD%E5%B0%86%20physaddr%20%E6%B0%B8%E4%B9%85%E6%9B%B4%E6%94%B9%E4%B8%BA%200x2%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22gangli_weride_0-1735547757778.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gangli_weride_0-1735547757778.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F317632i11CDDC996204EEE0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22gangli_weride_0-1735547757778.png%22%20alt%3D%22gangli_weride_0-1735547757778.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2026073%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXPS71407%20%E6%9B%B4%E6%94%B9%E7%89%A9%E7%90%86%E5%9C%B0%E5%9D%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2026073%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20gangli%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CEM%3E%E2%80%9C%E5%A6%82%E6%9E%9CDEVSTAT2%E4%B8%AD%E6%9C%89U_OTP_ERR%EF%BC%8C%E6%98%AF%E5%90%A6%E6%84%8F%E5%91%B3%E7%9D%80%E8%8A%AF%E7%89%87%E5%9D%8F%E4%BA%86%EF%BC%9F%E2%80%9D%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E8%81%94%E7%B3%BB%E4%BA%86%E4%B8%93%E5%AE%B6%EF%BC%8C%E7%9C%8B%E7%9C%8B%E6%98%AF%E5%90%A6%E6%9C%89%E5%8A%9E%E6%B3%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CEM%3E%E2%80%9C%E8%AF%A5%E8%AE%BE%E5%A4%87%E5%B0%86%E5%A7%8B%E7%BB%88%E4%BF%9D%E6%8C%81%E8%AF%A5%E7%8A%B6%E6%80%81%E3%80%82%E2%80%9D%3C%2FEM%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E5%B8%8C%E6%9C%9B%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E5%BA%A6%E8%BF%87%E6%84%89%E5%BF%AB%E7%9A%84%E4%B8%80%E5%A4%A9%E5%B9%B6%E5%A5%BD%E8%BF%90%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2025357%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXPS71407%20%E6%9B%B4%E6%94%B9%E7%89%A9%E7%90%86%E5%9C%B0%E5%9D%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2025357%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CRafaR%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%81%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9CDEVSTAT2%E5%87%BA%E7%8E%B0U_OTP_ERR%EF%BC%8C%E6%98%AF%E4%B8%8D%E6%98%AF%E4%BB%A3%E8%A1%A8%E8%8A%AF%E7%89%87%E5%9D%8F%E4%BA%86%EF%BC%9F%E5%9B%A0%E4%B8%BA%20U_OTP_ERR%20%E5%BD%B1%E5%93%8D%20pdcm%20%E6%95%B0%E6%8D%AE%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22gangli_weride_0-1736474173756.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gangli_weride_0-1736474173756.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gangli_weride_0-1736474173756.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F318869iBB3D0F10745668A6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22gangli_weride_0-1736474173756.png%22%20alt%3D%22gangli_weride_0-1736474173756.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%86%99%E5%85%A5%20%2411%20%E5%AF%84%E5%AD%98%E5%99%A8%E6%97%B6%EF%BC%8C%E5%A6%82%E4%BD%95%E9%81%BF%E5%85%8D%20U_OTP_ERR%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E5%BE%97%E5%88%B0%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%81%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2025150%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXPS71407%20%E6%9B%B4%E6%94%B9%E7%89%A9%E7%90%86%E5%9C%B0%E5%9D%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2025150%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20gangli_weride%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E4%BB%8D%E4%B8%8E%E4%B8%93%E5%AE%B6%E4%BF%9D%E6%8C%81%E8%81%94%E7%B3%BB%EF%BC%8C%E8%AE%A9%E6%88%91%E4%B8%8E%E6%82%A8%E5%88%86%E4%BA%AB%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CEM%3E%E2%80%9C%E7%94%B1%E4%BA%8E%E5%86%85%E5%AD%98%E5%8F%AA%E8%83%BD%E4%B8%80%E6%AC%A1%E6%80%A7%E7%BC%96%E7%A8%8B%EF%BC%88%E5%8D%B3%20OTP%EF%BC%89%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%97%A0%E6%B3%95%E6%B8%85%E9%99%A4%20U_OTP_ERR%E3%80%82%E2%80%9D%3C%2FEM%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E5%B8%8C%E6%9C%9B%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%E5%AF%B9%E4%BD%A0%E6%9C%89%E5%B8%AE%E5%8A%A9%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E5%BA%A6%E8%BF%87%E6%84%89%E5%BF%AB%E7%9A%84%E4%B8%80%E5%A4%A9%E5%B9%B6%E5%A5%BD%E8%BF%90%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2024403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXPS71407%20%E6%9B%B4%E6%94%B9%E7%89%A9%E7%90%86%E5%9C%B0%E5%9D%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2024403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CRafaR%EF%BC%9A%3C%2FP%3E%3CP%3E%E9%A1%BA%E4%BE%BF%E9%97%AE%E4%B8%80%E4%B8%8B%EF%BC%8C%E6%82%A8%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E5%A6%82%E4%BD%95%E6%B8%85%E9%99%A4%20DEVSTAT2%20%E4%B8%AD%E7%9A%84%20u_otp_err%20%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2023464%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXPS71407%20%E6%9B%B4%E6%94%B9%E7%89%A9%E7%90%86%E5%9C%B0%E5%9D%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2023464%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20gangli_weride%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E7%A1%AE%E8%AE%A4%E7%BC%96%E7%A8%8B%E6%9C%9F%E9%97%B4%E6%96%BD%E5%8A%A0%E5%88%B0%20BUS_I%20%E7%9A%84%E7%94%B5%E5%8E%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%AF%84%E5%AD%98%E5%99%A8%2411%E5%86%99%E5%85%A5%E5%91%BD%E4%BB%A4%E5%90%8E%EF%BC%8C%E5%AE%83%E9%9C%80%E8%A6%81%E5%9C%A89-11V%E8%8C%83%E5%9B%B4%E5%86%85%E8%87%B3%E5%B0%9110ms%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2022023%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXPS71407%20%E6%9B%B4%E6%94%B9%E7%89%A9%E7%90%86%E5%9C%B0%E5%9D%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2022023%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20gangli_weride%3C%2FP%3E%0A%3CP%3E%E8%AE%A9%E6%88%91%E4%B8%8E%E8%AF%A5%E8%AE%BE%E5%A4%87%E7%9A%84%E4%B8%93%E5%AE%B6%E7%A1%AE%E8%AE%A4%E4%B8%80%E4%B8%8B%EF%BC%8C%E4%BB%A5%E8%8E%B7%E5%BE%97%E6%98%8E%E7%A1%AE%E7%9A%84%E7%AD%94%E6%A1%88%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BC%9A%E5%B0%BD%E5%BF%AB%E8%81%94%E7%B3%BB%E4%BD%A0%3C%2FP%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E5%BA%A6%E8%BF%87%E6%84%89%E5%BF%AB%E7%9A%84%E4%B8%80%E5%A4%A9%E5%B9%B6%E5%A5%BD%E8%BF%90%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2021647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXPS71407%20%E6%9B%B4%E6%94%B9%E7%89%A9%E7%90%86%E5%9C%B0%E5%9D%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2021647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BC%9A%E5%8F%91%E7%94%9F%20u_otp_err%EF%BC%9F%E6%88%91%E6%80%8E%E6%A0%B7%E6%89%8D%E8%83%BD%E6%B8%85%E9%99%A4%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2021637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXPS71407%20%E6%9B%B4%E6%94%B9%E7%89%A9%E7%90%86%E5%9C%B0%E5%9D%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2021637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi!%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%88%91%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E5%8F%91%E9%80%81%E5%86%99%E5%85%A5%20%2411%20%E5%AF%84%E5%AD%98%E5%99%A8%E6%95%B0%E6%8D%AE%200x8a%20%E6%9D%A5%E6%9B%B4%E6%94%B9%E7%89%A9%E7%90%86%E5%9C%B0%E5%9D%80%E3%80%82physaddr%E4%BF%AE%E6%94%B9%E6%88%90%E5%8A%9F%EF%BC%81%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E6%88%91%E9%87%8D%E7%BD%AE%E5%90%8E%EF%BC%8C%E5%87%BA%E7%8E%B0%20u_otp_err%20%E9%94%99%E8%AF%AF%E3%80%82%E6%88%91%E6%97%A0%E6%B3%95%E9%80%9A%E8%BF%87%E8%AF%BB%E5%8F%96%20DEVSTAT2%20%E5%AF%84%E5%AD%98%E5%99%A8%E6%9D%A5%E6%B8%85%E9%99%A4%E6%AD%A4%E9%94%99%E8%AF%AF%E3%80%82%E6%9C%89%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%E5%B8%8C%E6%9C%9B%E6%82%A8%E5%9B%9E%E5%A4%8D%EF%BC%81%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22gangli_weride_0-1735884337190.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gangli_weride_0-1735884337190.png%22%20style%3D%22width%3A%20375px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gangli_weride_0-1735884337190.png%22%20style%3D%22width%3A%20375px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F317978i720015EE3295BCDD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22gangli_weride_0-1735884337190.png%22%20alt%3D%22gangli_weride_0-1735884337190.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2020616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXPS71407%20%E6%9B%B4%E6%94%B9%E7%89%A9%E7%90%86%E5%9C%B0%E5%9D%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2020616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%E5%8F%91%E9%80%81crm%200x1811820c%E5%86%99%E5%85%A5OTP%EF%BC%9A0x5f%E5%AF%84%E5%AD%98%E5%99%A8%E6%95%B0%E6%8D%AE0x00%E4%B9%8B%E5%89%8D%EF%BC%8CLOCK_UF2%E5%B0%9A%E6%9C%AA%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%91%E9%80%81%20crm%200x181182f8%EF%BC%8C%E5%93%8D%E5%BA%94%EF%BC%9A0x18820087%E3%80%82crm%20%E5%8F%91%E9%80%81%E6%AD%A3%E7%A1%AE%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%91%E9%80%81crm%200x181182f8%E5%90%8E%EF%BC%8C%E6%88%91%E8%AF%BB%E5%8F%960x5f%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E6%B2%A1%E6%9C%89crm%200x105f00f8%E7%9A%84%E5%93%8D%E5%BA%94%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E6%A3%80%E6%9F%A5LOCK_UF2%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2020552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXPS71407%20%E6%9B%B4%E6%94%B9%E7%89%A9%E7%90%86%E5%9C%B0%E5%9D%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2020552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20gangli_weride%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22RafaR_0-1735584940211.png%22%20style%3D%22width%3A%20482px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RafaR_0-1735584940211.png%22%20style%3D%22width%3A%20482px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RafaR_0-1735584940211.png%22%20style%3D%22width%3A%20482px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F317662i9E51B26EDA3D8681%2Fimage-dimensions%2F482x158%3Fv%3Dv2%22%20width%3D%22482%22%20height%3D%22158%22%20role%3D%22button%22%20title%3D%22RafaR_0-1735584940211.png%22%20alt%3D%22RafaR_0-1735584940211.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E6%A3%80%E6%9F%A5%E9%87%8D%E7%BD%AE%E5%89%8D%E5%90%8E%20UF2%20%E5%8C%BA%E5%9F%9F%E6%98%AF%E5%90%A6%E6%9C%AA%E8%A2%AB%E9%94%81%E5%AE%9A%EF%BC%9F%E8%BF%99%E4%BC%BC%E4%B9%8E%E6%AD%A3%E6%98%AF%E6%82%A8%E6%89%80%E9%81%87%E5%88%B0%E7%9A%84%E6%83%85%E5%86%B5%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E5%BA%A6%E8%BF%87%E6%84%89%E5%BF%AB%E7%9A%84%E4%B8%80%E5%A4%A9%E5%B9%B6%E5%A5%BD%E8%BF%90%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
