Consecutive Reads
Consecutive Reads
admin
Specialist II
I'm using the MPL115A2 over the I2C bus. I need to know if the device supports consecutive read. I.e. If I write the address pointer to 0x00 and send a read command with 4 bytes worth of clock cycles( 4 x 9 clock pulses on the SCL line), will it send me pressure MSB, LSB, temperature MSB, and LSB?
Thanks.
Onkar Raut,
Embedded Systems Engineer,
BNS Solutions, Walpole, MA.
TomasVaverka
Hi Onkar,
Yes, it will. The MPL115A2 does support a multiple-byte (burst) read.
Tomas
TomasVaverka
Hi Onkar,
Tomas
%3CLINGO-SUB%20id%3D%22lingo-sub-293410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EConsecutive%20Reads%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-293410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI'm%20using%20the%20MPL115A2%20over%20the%20I2C%20bus.%20I%20need%20to%20know%20if%20the%20device%20supports%20consecutive%20read.%20I.e.%20If%20I%20write%20the%20address%20pointer%20to%200x00%20and%20send%20a%20read%20command%20with%204%20bytes%20worth%20of%20clock%20cycles(%204%20x%209%20clock%20pulses%20on%20the%20SCL%20line)%2C%20will%20it%20send%20me%20pressure%20MSB%2C%20LSB%2C%20temperature%20MSB%2C%20and%20LSB%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EOnkar%20Raut%2C%3C%2FP%3E%3CP%3EEmbedded%20Systems%20Engineer%2C%3C%2FP%3E%3CP%3EBNS%20Solutions%2C%20Walpole%2C%20MA.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-293410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EPressure%20Sensors%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-293411%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Consecutive%20Reads%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-293411%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Onkar%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYes%2C%20it%20will.%20The%20MPL115A2%20does%20support%20a%20multiple-byte%20(burst)%20read.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E
