Clarification on MPX2200GP Pin Configuration and Output Behavior
lifewouthumans
I’m currently working with the MPX2200GP pressure sensor, but I’m a bit confused about its pin configuration. I couldn’t find a datasheet specifically labeled for the MPX2200GP variant. However, I did find the general MPX2200 datasheet, which indicates the following pinout:
Pin 1: GND
Pin 2: +Vout
Pin 3: Vs (Supply)
Pin 4: -Vout
Can you please confirm whether this pin configuration is also applicable to the MPX2200GP variant?
Additionally, I have a few more questions:
1. Differential Output: If I supply 10V to Vs (Pin 3), what voltage range should I expect between +Vout (Pin 2) and -Vout (Pin 4) when measured with a multimeter?
2. Relative Output: What voltage should I expect if I measure between +Vout (Pin 2) and GND (Pin 1)?
3. Calibration: The datasheet mentions that the sensor is factory calibrated at 10V. Do I need to perform any additional
calibration before use?
RafaR
Hello lifewouthumans
Here's the official datasheet for this NP. I don't know if this is the one you were using.
In response to your questions:
0.- Yes, that is the correct PIN distribution
1.- The voltage difference between +Vout and -Vout will range from approximately -1 mV to +41 mV, depending on the pressure applied (0 to 200 kPa)
2.- Likewise, you would have a maximum value of up to 41mV, but I personally recommend that you always measure +Vout and -Vout, considering that this way you will have greater precision.
3.- No, as long as it is not exposed to temperatures and pressures outside those recommended, recalibration is not necessary.
I hope this information has helped you, please let me know if you need help with anything else.
Have a great day and best of luck.
%3CLINGO-SUB%20id%3D%22lingo-sub-2148650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EClarification%20on%20MPX2200GP%20Pin%20Configuration%20and%20Output%20Behavior%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EI%E2%80%99m%20currently%20working%20with%20the%20MPX2200GP%20pressure%20sensor%2C%20but%20I%E2%80%99m%20a%20bit%20confused%20about%20its%20pin%20configuration.%20I%20couldn%E2%80%99t%20find%20a%20datasheet%20specifically%20labeled%20for%20the%20MPX2200GP%20variant.%20However%2C%20I%20did%20find%20the%20general%20MPX2200%20datasheet%2C%20which%20indicates%20the%20following%20pinout%3A%3C%2FP%3E%3CP%3EPin%201%3A%20GND%3C%2FP%3E%3CP%3EPin%202%3A%20%2BVout%3C%2FP%3E%3CP%3EPin%203%3A%20Vs%20(Supply)%3C%2FP%3E%3CP%3EPin%204%3A%20-Vout%3C%2FP%3E%3CP%3E%3CSTRONG%3ECan%20you%20please%20confirm%20whether%20this%20pin%20configuration%20is%20also%20applicable%20to%20the%20MPX2200GP%20variant%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EAdditionally%2C%20I%20have%20a%20few%20more%20questions%3A%3C%2FP%3E%3CP%3E1.%20Differential%20Output%3A%20If%20I%20supply%2010V%20to%20Vs%20(Pin%203)%2C%20what%20voltage%20range%20should%20I%20expect%20between%20%2BVout%20(Pin%202)%20and%20-Vout%20(Pin%204)%20when%20measured%20with%20a%20multimeter%3F%3C%2FP%3E%3CP%3E2.%20Relative%20Output%3A%20What%20voltage%20should%20I%20expect%20if%20I%20measure%20between%20%2BVout%20(Pin%202)%20and%20GND%20(Pin%201)%3F%3C%2FP%3E%3CP%3E3.%20Calibration%3A%20The%20datasheet%20mentions%20that%20the%20sensor%20is%20factory%20calibrated%20at%2010V.%20Do%20I%20need%20to%20perform%20any%20additional%3C%2FP%3E%3CP%3Ecalibration%20before%20use%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2148650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EPressure%20Sensors%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2149431%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Clarification%20on%20MPX2200GP%20Pin%20Configuration%20and%20Output%20Behavior%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149431%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20lifewouthumans%3C%2FP%3E%0A%3CP%3EHere's%20the%20official%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fdata-sheet%2FMPX2200.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Edatasheet%3C%2FA%3E%20for%20this%20NP.%20I%20don't%20know%20if%20this%20is%20the%20one%20you%20were%20using.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22RafaR_0-1754694427348.png%22%20style%3D%22width%3A%20481px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RafaR_0-1754694427348.png%22%20style%3D%22width%3A%20481px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F351633i1CC5BF5E2FB1E478%2Fimage-dimensions%2F481x298%3Fv%3Dv2%22%20width%3D%22481%22%20height%3D%22298%22%20role%3D%22button%22%20title%3D%22RafaR_0-1754694427348.png%22%20alt%3D%22RafaR_0-1754694427348.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EIn%20response%20to%20your%20questions%3A%3C%2FP%3E%0A%3CP%3E0.-%20Yes%2C%20that%20is%20the%20correct%20PIN%20distribution%3C%2FP%3E%0A%3CP%3E1.-%20The%20voltage%20difference%20between%20%2BVout%20and%20-Vout%20will%20range%20from%20approximately%20-1%20mV%20to%20%2B41%20mV%2C%20depending%20on%20the%20pressure%20applied%20(0%20to%20200%20kPa)%3C%2FP%3E%0A%3CP%3E2.-%20Likewise%2C%20you%20would%20have%20a%20maximum%20value%20of%20up%20to%2041mV%2C%20but%20I%20personally%20recommend%20that%20you%20always%20measure%20%2BVout%20and%20-Vout%2C%20considering%20that%20this%20way%20you%20will%20have%20greater%20precision.%3C%2FP%3E%0A%3CP%3E3.-%20No%2C%20as%20long%20as%20it%20is%20not%20exposed%20to%20temperatures%20and%20pressures%20outside%20those%20recommended%2C%20recalibration%20is%20not%20necessary.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20hope%20this%20information%20has%20helped%20you%2C%20please%20let%20me%20know%20if%20you%20need%20help%20with%20anything%20else.%3C%2FP%3E%0A%3CP%3EHave%20a%20great%20day%20and%20best%20of%20luck.%3C%2FP%3E%3C%2FLINGO-BODY%3E
