Calculating Speed using Accelerometer
8,834 次查看
ashokfair
is it possible to determine an speed of Object using Accelerometer Sensor?
7 回复数
5,098 次查看
ashokfair
Hi Jose,
I tried the Accelerometer example for calculating Speed. But its not giving proper output (PositionX,PositionY) . Always i could see the variation in position for the data X,Y,Z from Sensor is constant. can i get any help?
5,098 次查看
reyes
If the acceleration of an object is known, we can get a proportional approximation of the velocity data if an integration is applied.
Unfortunately we do not have any updated document with information about how to do this with one of our new accelerometers, however, we do have an application note that mentions how to calculate velocity (and positioning) using the accelerometer MMA7260 (which is no longer manufactured), that can be used as a reference.
Application note AN3397 “Implementing Positioning Algorithms Using Accelerometers”: http://cache.freescale.com/files/sensors/doc/app_note/AN3397.pdf
Jose
5,098 次查看
ashokfair
Hi Jose,
Thank you!  Can i use MMA8451Q 3-Axis Digital Accelerometer (FRDM kit)? instead of the MMA7260
it can be possible ?
Ashok r
5,098 次查看
reyes
Hi Ashok r,
Yes, that’s actually one of our current bests accelerometers, you can even find an example code for this sensor on the following link:  https://community.freescale.com/docs/DOC-98836
Jose
5,098 次查看
ashokfair
Thanks Jose , let me try out the example code :-)
5,098 次查看
ashokfair
Hi Jose,
I tried the example code "https://community.freescale.com/docs/DOC-98836"  i am able to get 14bit Acc data. The same project i tried with process export it was working for 8bit Fast Acc data mode. But for 14bit mode i could not set the proper Configuration to Accelerometer.
res = MMA8451_WriteReg(MMA8451_CTRL_REG_1,  MMA8451_F_READ_BIT_MASK|MMA8451_ACTIVE_BIT_MASK);
      if (res==ERR_OK) {
        for(;;) {
          res = MMA8451_ReadReg(MMA8451_OUT_X_MSB, (uint8_t*)&xyz, 3);
          AccelX = xyz[0];
          AccelY = xyz[1];
          AccelZ = xyz[2];
how to configure for 14bit data ? in this above code
Ashok r
5,098 次查看
reyes
TomasVaverka Can you please take a look at this inquiry, please?
%3CLINGO-SUB%20id%3D%22lingo-sub-272721%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E8%AE%A1%E7%AE%97%E9%80%9F%E5%BA%A6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-272721%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%83%BD%E5%90%A6%E4%BD%BF%E7%94%A8%E5%8A%A0%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E7%A1%AE%E5%AE%9A%E7%89%A9%E4%BD%93%E7%9A%84%E9%80%9F%E5%BA%A6%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-272728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Calculating%20Speed%20using%20Accelerometer%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-272728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FTomasVaverka%22%20target%3D%22_blank%22%3ETomasVaverka%3C%2FA%3E%E8%AF%B7%E6%82%A8%E7%9C%8B%E4%B8%80%E4%B8%8B%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E5%A5%BD%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-272727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Calculating%20Speed%20using%20Accelerometer%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-272727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8CJose%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%22%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%2211146%22%20data-containertype%3D%2214%22%20data-objectid%3D%2298836%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-98836%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-98836%3C%2FA%3E%22%20%E6%88%91%E5%8F%AF%E4%BB%A5%E8%8E%B7%E5%8F%96%2014bit%20Acc%20%E6%95%B0%E6%8D%AE%E3%80%82%E5%9C%A8%E5%90%8C%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E8%BF%87%E7%A8%8B%E5%AF%BC%E5%87%BA%EF%BC%8C%E5%AE%83%E5%9C%A8%208%20%E4%BD%8D%E5%BF%AB%E9%80%9F%E5%8A%A0%E9%80%9F%E6%95%B0%E6%8D%AE%E6%A8%A1%E5%BC%8F%E4%B8%8B%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E4%BD%86%E5%AF%B9%E4%BA%8E%2014%20%E4%BD%8D%E6%A8%A1%E5%BC%8F%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E4%B8%BA%E5%8A%A0%E9%80%9F%E8%AE%A1%E8%AE%BE%E7%BD%AE%E6%AD%A3%E7%A1%AE%E7%9A%84%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20res%20%3D%20MMA8451_WriteReg(MMA8451_CTRL_REG_1%EF%BC%8CMMA8451_F_READ_BIT_MASK%7CMMA8451_ACTIVE_BIT_MASK)%EF%BC%9B%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%E5%A6%82%E6%9E%9C%20(res%3D%3DERR_OK)%20%7B%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20for(%3B%3B)%20%7B%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20res%20%3D%20MMA8451_ReadReg(MMA8451_OUT_X_MSB%EF%BC%8C(uint8_t*)%26amp%3Bxyz%EF%BC%8C3)%EF%BC%9B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20AccelX%20%3D%20xyz%5B0%5D%EF%BC%9B%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20AccelY%20%3D%20xyz%5B1%5D%EF%BC%9B%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20AccelZ%20%3D%20xyz%5B2%5D%EF%BC%9B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%20%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E4%B8%8A%E8%BF%B0%E4%BB%A3%E7%A0%81%E4%B8%AD%EF%BC%8C%E5%A6%82%E4%BD%95%E9%85%8D%E7%BD%AE%2014bit%20%E6%95%B0%E6%8D%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20class%3D%22r%22%20id%3D%22toc-hId-1454598670%22%20id%3D%22toc-hId-2026552755%22%3E%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EAshok%20r%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-272726%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Calculating%20Speed%20using%20Accelerometer%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-272726%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8CJose%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E8%AE%A1%E7%AE%97%E9%80%9F%E5%BA%A6%E7%9A%84%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E7%A4%BA%E4%BE%8B%E3%80%82%E4%BD%86%E5%AE%83%E6%B2%A1%E6%9C%89%E6%8F%90%E4%BE%9B%E6%AD%A3%E7%A1%AE%E7%9A%84%E8%BE%93%E5%87%BA%EF%BC%88PositionX%2CPositionY%EF%BC%89%E3%80%82%E6%88%91%E6%80%BB%E8%83%BD%E7%9C%8B%E5%88%B0%E4%BC%A0%E6%84%9F%E5%99%A8%20X%E3%80%81Y%E3%80%81Z%20%E6%95%B0%E6%8D%AE%E7%9A%84%E4%BD%8D%E7%BD%AE%E5%8F%98%E5%8C%96%E6%98%AF%E6%81%92%E5%AE%9A%E7%9A%84%E3%80%82%E6%88%91%E8%83%BD%E5%BE%97%E5%88%B0%E5%B8%AE%E5%8A%A9%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-272725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Calculating%20Speed%20using%20Accelerometer%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-272725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%95%E5%A1%9E%EF%BC%8C%E8%AE%A9%E6%88%91%E8%AF%95%E8%AF%95%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-272724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Calculating%20Speed%20using%20Accelerometer%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-272724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E9%98%BF%E8%82%96%E5%85%8B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E8%BF%99%E5%B0%B1%E6%98%AF%E6%88%91%E4%BB%AC%E7%9B%AE%E5%89%8D%E6%9C%80%E5%A5%BD%E7%9A%84%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E4%B9%8B%E4%B8%80%EF%BC%8C%E6%82%A8%E7%94%9A%E8%87%B3%E5%8F%AF%E4%BB%A5%E5%9C%A8%E4%BB%A5%E4%B8%8B%E9%93%BE%E6%8E%A5%E4%B8%AD%E6%89%BE%E5%88%B0%E8%AF%A5%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-98836%22%20target%3D%22_blank%22%3E%EF%BC%9A%20https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-98836%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E4%BD%95%E5%A1%9E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-272723%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Calculating%20Speed%20using%20Accelerometer%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-272723%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8CJose%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%20%20%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20MMA8451Q%203%20%E8%BD%B4%E6%95%B0%E5%AD%97%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%EF%BC%88FRDM%20%E5%A5%97%E4%BB%B6%EF%BC%89%E5%90%97%EF%BC%9F%E8%80%8C%E4%B8%8D%E6%98%AF%20MMA7260%3C%2FP%3E%3CP%3E%E5%8F%AF%E8%83%BD%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3CH3%20class%3D%22r%22%20id%3D%22toc-hId-1454598666%22%20id%3D%22toc-hId-219098292%22%3E%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EAshok%20r%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-272722%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Calculating%20Speed%20using%20Accelerometer%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-272722%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E5%B7%B2%E7%9F%A5%E7%89%A9%E4%BD%93%E7%9A%84%E5%8A%A0%E9%80%9F%E5%BA%A6%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%B1%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E7%A7%AF%E5%88%86%E5%BE%97%E5%88%B0%E9%80%9F%E5%BA%A6%E6%95%B0%E6%8D%AE%E7%9A%84%E6%AF%94%E4%BE%8B%E8%BF%91%E4%BC%BC%E5%80%BC%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E6%9B%B4%E6%96%B0%E7%9A%84%E6%96%87%E6%A1%A3%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%8C%85%E5%90%AB%E6%9C%89%E5%85%B3%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E6%88%91%E4%BB%AC%E7%9A%84%E6%96%B0%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E8%BF%9B%E8%A1%8C%E6%AD%A4%E6%93%8D%E4%BD%9C%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%8C%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E4%BB%AC%E7%A1%AE%E5%AE%9E%E6%9C%89%E4%B8%80%E4%BB%BD%E5%BA%94%E7%94%A8%E8%AF%B4%E6%98%8E%E6%8F%90%E5%88%B0%E4%BA%86%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%20MMA7260%EF%BC%88%E5%B7%B2%E5%81%9C%E4%BA%A7%EF%BC%89%E8%AE%A1%E7%AE%97%E9%80%9F%E5%BA%A6%EF%BC%88%E5%92%8C%E5%AE%9A%E4%BD%8D%EF%BC%89%EF%BC%8C%E5%8F%AF%E7%94%A8%E4%BD%9C%E5%8F%82%E8%80%83%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2Fsensors%2Fdoc%2Fapp_note%2FAN3397.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%20AN3397%20%E2%80%9C%E4%BD%BF%E7%94%A8%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E5%AE%9E%E7%8E%B0%E5%AE%9A%E4%BD%8D%E7%AE%97%E6%B3%95%E2%80%9D%EF%BC%9Ahttp%3A%2F%2Fcache.freescale.com%2Ffiles%2Fsensors%2Fdoc%2Fapp_note%2FAN3397.pdf%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E4%BD%95%E5%A1%9E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
